Question about GE DSXH43EAWW Electric Dryer
When the start button is pressed there is a slight buzzing noise. Drum turns easilly and the belt appears to be connected.
  • GE Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
I have a Kenmore Dryer from Sears Model 97292100. It was working fine for several loads the other day, but when I went out to get the next load out, it had not dried completely. I set it to run again, but...
Is the belt tight around drum. If yes, then there is a tripable thermistor in the heat tube. Small button on it that slight push on it resets device. If belt is loose but not broken, then it is off the tensioner b
May 05, 2017 | Dryers
Drum will not turn and there is no heat.
This dryer has a circuit board that controls virtually everything. If it makes a buzzing noise when you press the power button to turn on the control panel, it's probably not going to be an easy fix. When you hire a professional, you avoid buying expensive parts that you might not need, such as a control board. If it makes a loud buzzing noise when you press the start button, it's possible that it could be a motor or belt problem. But again, I'd recommend a service call for this one.
May 25, 2010 | Whirlpool GEW9250 Electric Dryer
When pushing dryer start button, a slight buzz is
the noise is coming from the motor,if you can spin the drum by hand and it moves freely you have a bad motor and need to change it out,next time send model number and the brand name of dryer,if it doesn't spin,the belt could be jammed up or something stuck in the blower wheel,let me know how you make out
May 13, 2010 | Dryers
Whirlpool gas dryer wont spin
timer relay is bad
Feb 24, 2010 | Dryers
Makes buzzing noise when pressing the start button but doesn't always start
With the dryer off, try to turn the drum by hand 1/4-1/2 turn, then turn the dryer back on and push the start butteer and see if this helps.
Sometimes motors get a dead zone in them and this will help move it from the dead zone.
If this does not help then your problem could be a bad motor, broken belt, faulty start switch or faulty timer switch.
Hope this helps
Sep 26, 2009 | Maytag Dryers
I have a frigidaire FEQ1442ES and i press the start button and it makes a humming noise. The belt is fine.
the buzzing sound is the dryer mootor locking up,it is no longer strong enough to turn the drum,i see this all the time-mike
Apr 22, 2009 | Dryers
GE DSXH43EAWW Electric Dryer Logo
52 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
