Question about Sekonic L-358 Flash Master Light Meter
I use the settings recommended by my L358. However, when I set my camera to those settings in manual mode, my photos are dark. Why is this happening?
    Brigadier General:
  • 3,006 Answers
The fault is either with your camera/lens or with the meter itself. Try the meter with another camera, if the exposure error is still present then check that the custom compensation feature on your meter has not been set by mistake (page 26 of the user manual). If this doesn't cure the fault then try fitting a new CR123A battery. If the fault still remains then you can either compensate for the error by always using a longer shutter speed/wider aperture than recommended or you will need to send the meter for servicing.
Good luck, and please take a moment to rate my answer.
Posted on Sep 12, 2010
Why Fuji Finepix XP20 won't take photos?
Check the settings of the camera. Put the recording mode for stills (photos) to auto, so the setting can't stop the camera from taking a picture. If you are in one of the manual modes, and the system calculates it won't be possible to make a picture (to dark, to light, or out of focus and so on) it won't react when you press the shutter release button.
Please use the manual, so you will be able to solve this every time it happens to you. The manual is still online.
Jul 22, 2014 | Fujifilm Finepix Xp20 14-megapixel 720p Hd...
Pictures too dark
just change the backlight and contrast settings in camera .....regarding flash try taking photos with new batteries ...
Aug 20, 2008 | Canon PowerShot A540 Digital Camera
Picturess are too green
there are advanced color correction modes,
Blue or dark pictures/videos
Keep your shooting distance inside of 2ft to 3ft, depending on
visibility and ambient light.
If you are using only one light, considering adding another light
(dual lights) or/and external flash accessory. The ideal
set-up is a combination of a light plus flash.
Consider purchasing the SeaLife Wide Angle Lens (SL975). The
fisheye lens allows you to get closer to the subject and fit more
into to picture frame.
For SeaLife camera with external light accessory (No external flash):
1) Set the camera's scene mode to Sea mode or Snorkel mode
2) Change camera's PHOTO and VIDEO White Balance
settings to DAYLIGHT.
For SeaLife camera with external light and flash accessories:
1) Set the scene mode to Ext. Flash mode
2) Change the VIDEO White Balance setting to DAYLIGHT.
For other underwater camera brands:
1) Set the Scene mode to "Auto" or "Underwater" scene
mode, as recommended by the camera manufacturer.
2) You may also need to change the White Balance setting to
DAYLIGHT depending on the camera's underwater color
correction or if pictures/video turns out red.
Mar 05, 2014 | SeaLife DC1200 Digital Camera
My nikon is takeing extremely bright photos. I have to change the settings ever time I want to photograph something. I have no clue what is wrong, but I need it fixed.
Do you have it in aperture or shutter priority modes? If so, do you also have exposure compensation set to overexpose? If you have it in manual mode, then you will, of course, have to make the adjustments each time.
If you have it in auto mode, it should be correcting the exposure for you, unless you have manually set the ISO to some very high level. Another potential issue would be that you have selected spot metering and you are metering on a very dark area, hence the camera is overexposing to make up for that.
I'd recommend setting the camera to auto-ISO and auto exposure and see how it works. If that checks out, then you can correct any settings in other modes.
Dec 13, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Sir i have purchased nikon p100 camera from croma stores belapur branch , the problem with the barrel and there were gear noise and on taking photos in dark back ground of moon there were several white...
You have to know the MODE your camera is in. If you have it in the wrong mode you may not be able to take a photo in some conditions. You typically cannot take a photo of the moon on any auto setting the moon will be a white blob. The moon almost has to be taken manually.
Search for Lens Error. There are many was to fix Lens Errors
Mar 15, 2017 | Nikon Cameras
Completely dark photo, only showing top 1/4 of pic, remaining 3/4 is dark, this only happened after I cleaned the mirror, which has been done many times before and had no problems in doing so, please
there is no problem with your cam for sure. you must have changed the setting of the cam adjust the shutterspeed and the aparture. and your problem will be solved... or dont keep the cam on manual mode.. keep it on automatic settings and it should work. also check out this link to learn more about how to use aparture and shutterspeed..... http://www.learnslr.com/slr-beginner-guide/digital-slr-learning-guide/av-mode-aperture-priority
May 10, 2009 | Canon EOS 400D Digital Camera
I use first time nikon d60.
it would depend on the lighting. you can lower down your shutter speed, or change the white-balance or aperture on the camera. make sure that your camera is set on manual. hit me back on the results.
Jan 30, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Dark pictures
There are several possibilities.
1) The camera store screwed up, and your photos are just fine. Have you looked at the photo files on your computer?
2) You accidentally set the camera into manual mode and with settings that don't work for the light. How do the photos look when you preview them on the camera?
3) This is the most likely problem: It sounds like you have accidentally set the "exposure compensation" value. This setting is used to help correct the exposure when shooting a scene that should be mostly white (e.g. in the snow, or bright sand at the beach) because otherwise the camera will make the scene be "medium gray". Check your user manual for instructions on how to set the exposure compensation and make sure it is set to 0.
If your photos are too dark when viewed on the computer and the preview screen, and EV is set to 0, then your camera may have a faulty light meter. If so, you need to send it in for repair under the warranty, or return it to the place of purchase as defective and see if they will exchange it for you.
Dec 31, 2008 | Nikon Coolpix S1 Digital Camera
Kodak EasyShare DX7630 Camera
Check the ASA setting - read up the manual
Jul 18, 2008 | Kodak EasyShare DX7630 Digital Camera
Canon eos 3000 wouldnt take photo
Set to ISO 800
Set camera to manual mode
Set Shutter to 125
Set Aperture to 5.6 or under
You're ready to go.
Too much grains, then lower the ISO.
atdlee@netzero.com
Dec 22, 2007 | Canon EOS 3000 Kit 35mm SLR Camera
Sekonic L-358 Flash Master Light Meter Logo
180 people viewed this question
Top Sekonic Cameras Experts
Steve
Are you a Sekonic Camera Expert? Answer questions, earn points and help others
