Question about Tissot PRS 516 T91142651 Wrist Watch
Timex t28842 Its a nightmare. The second hand keeps stopping but the small one goes all the time
The small hand is the second hand the large one is for chronograph
Posted on Apr 26, 2009
My Timex Chicago watch just arrived, it works perfectly, but the chronograph second hand is not pointing at the 12th o'clock mark. Is there a way to fix that?
normally the watch chrono hands can be reset .
dependant on movement fitted.
*pull crown out to first position
* push and hold top right pusher.
* the second should start top sweep one complete revolution and then stop.
*when it stops use the lower right pusher to adjust.
*when at the 12 push the crown but in fully.
Aug 28, 2017 | Timex Watches
Second hand quits working (the small second hand)
the chrono second hand only works for one hour then stops,it's only used for timing purposes, see instructions on the link below ..
Apr 07, 2013 | Watches
mcdevito75 here, It sounds like the (larger) minute hand is leaning against the (smaller) hour hand, stopping the time telling past 11:20 while the seconds hand keeps going. You"ll have to see a Watch repair person and have them look at your watch. Best Bet, look for a small watch repair shop in your area.
Aug 25, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Hello, this may sound silly but I just bought a Timex Ladies watch and I can set the clock but it's not actually turning on when I push the side button in? It's a new watch direct from Timex so I...
mcdevito75 here, A brand new Timex quartz watch will come with a small piece of plastic just under the crown to keep the battery form working the watch, simply remove this small piece of plastic from under the stem (winder) push the stem in and your Timex will work. If your timex is push button you may have to hold down the Mode 2--3 seconds to see display.
Aug 02, 2010 | Timex 27191 Wristwatch
Timex T22202 Second Hand Stopping
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Read manual carefully and learn which is ordinary seconds hand and which is chrono hand and how it affects watch battery life and movement. Rate me, please .
Apr 13, 2010 | Timex Chronograph #T22202 Watch for Men
How to access older timex automatic watch second hand
You should be able to open the back by popping it off with a sharp knife blade. Sometimes, the lip where you'd open it is hard to see and usually under the band, between the lugs. The movement will just come out. If I read you right, you know how to do this, once the movement is removed. You can't just pull the hands off. Hopefully, you'll be able to just VERY EASILY bend the one that is causing the problem.
Feb 15, 2009 | Timex Watches
Battery replace lights up but does not keep time
This could be a problem w/the movement (not the battery). Timex's warranty covers the movement, so I would find the receipt and call Timex about this problem (they generally need info off of your receipt unless you have already registered your warranty). They will be able to fix it for you.
Dec 09, 2008 | Timex 27191 Wristwatch
Screen goes blank
I put a new CR2025 battery in my T5e671 Timex and it solved the problem.
The screen no longer goes blank at any time.
PS:Timex manual says "remove battery strap" to replace the battery.
But it doesn't say HOW.-& I couldn't google an answer to that.
Here is how:
The metal strap goes across the middle of the battery and then goes over the edge of it on both sides.
At both edges the metal strap goes over a nylon tab.
One of those nylon tabs is notched, if you put the end of a paperclip in the notch, you can release the metal strap edge that runs under it.
Oct 14, 2007 | Timex Ironman Triathlon 51931 wristwatch
Small hand on Millennia not keeping time
From your book, start from square one. Second hand to 12 Pull crown to stop second hand.Set sub hands to duplicate main hands (correct time) Push crown in. I'm not that clever , I got the jeweler to do it for me.
Nov 03, 2006 | Bulova Millennia With Vibra-Alarm 98A48...
Tissot PRS 516 T91142651 Wrist Watch Logo
408 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
