Question about Kitchen Ranges
I am not getting gas from the propane tank to the grill, I can hear it flow but then it stops
  • Kitchen Ranges Master
  • 43,501 Answers
The common problem is the regulator...they go bad and will not allow the gas to flow...
heatman101
Posted on Aug 29, 2010
Gas grill no flow of gas
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 14, 2014 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Why wont my old grill work with new propane tank
Jul 13, 2014 | Weber Q Grill
Grill isn't flowing propane when tank is on. No smell of propane and starter is clicking. Tested 3 tanks on grill and no luck. Tested same tanks on another grill and they work fine so it's the
it could be the reg or a blockage in the line or open the taps on the grill then close them reconnect gas tank open slowly then tis if there is gas to grill
Mar 16, 2012 | Barbeques Galore Turbo STS 3-Burner...
Grill does not get hot. I have a fresh bottle of propane. Hose is not kinked. Grill is maybe 6 - 10 years old.
hi,
When a new or newly filled propane tank is attached to your gas grill, the OPD is usually at its maximum limit position above a tank filled to capacity. Propane may come through the valve too strongly due to the additional pressure of being full and the OPD displacement. The propane tank goes into check and limits gas flow when too much pressure hits the valve. Some grill manufacturers provide instructions for this in the users manuals but most people do not read the manual. Many grillers believe replacement parts are needed and burners, ignitors and regulators get replaced without reason. Depending on how efficient the grill is operating, some grills attached to a tank in check will not ignite and others will light but cannot reach cooking temperatures because the tank has limited the amount of propane released. Sometimes the food will be unable to exceed 200 degrees in temperature because the propane tank is in check.
Gas grill replacement parts are available and are sometimes necessary, low or no gas flow indicates a different typr of repair. Most grillers accept instructions and the problem is corrected in minutes -- but believe it or not I have had a few insist on purchasing replacement parts.
How do I fix grill?
To reset the check valve and get back to cooking on your gas barbecue grill, first
turn everything off. Turn off the grill, the rotisserie, the side burner and the LP gas cylinder tank. Once everything is turned off disconnect the propane tank from the gas grill regulator by unscrewing it or pulling the quick-release on older or retro-fitted propane cylinders. Now turn the grill on. I know, it is dis-connected from the gas tank but we want to ensure that the pressure in the gas lines or any gas in the burners is released. Leave all grill burners in the on position for 3 - 5 minutes before turning them off. Make sure. Most gas grill valves must be pushed in to turn them and if turning is attempted without pushing the knob, they will not turn to the "on" position. With the grill, et al turned off reconnect the propane tank and slowly turn the hand wheel to the open position.
Slowly. The trick here is to turn the hand wheel slowly. Propane in a new or very full tank will be under more pressure, especially with the OPD floating in position. The extra pressure will come through the tank valve stronger. Turn the gas tank slowly allowing small increments of propane to enter the grill.
Once this is complete, you should be able to turn the grill on high and ignite your gas grill burner. Your cooking heat should be back to normal and cooking times decreased. If the problem persists, try this process again to make sure you followed every step. The check valve exists to save your life if there is a leak in any of the gas fittings. Constant check valve issues could imply a gas leak and a visit from your local gas grill service technician may be necessary.
To find a leak, turn the grill valves to the off position and the gas tank valve to the full on position. This should pressurize the gas line. Spray soapy water on all the fittings and look for bubbles just like checking for the leak in a flat tire.
Do not attempt to correct a gas leak on your own. While a check valve error when your gas grill will not get hot or will not ignite is a user education error and an issue corrected by learning about your propane tank, a gas leak should be corrected by a licensed gas service technician. When you are grilling, turn the propane tank on first and then turn on your grill. When you are done cooking, turn the gas tank off first and then turn off the grill valves. The process releases the pressure in the gas grill hose and manifold which allows the gas tank to release pressure by filling these lines. Read the safety features of your gas grill, clean it when necessary and replace used and failing parts. Aside from that be safe, eat well and have fun.
thanks.
Jun 15, 2010 | Weber Genesis Silver B Grill
New Tank won't light Weber Grill
Try checking the regulator, this is the round metal piece connected to the gas line. If this is not level flat the valve inside will not let propane flow through.
Apr 15, 2010 | Weber Spirit? E-310 Propane Grill
Grill doesn't stay lit for the first 20 times, then does
regulator, is faulty, you need to replace it.
Apr 06, 2010 | Weber Q Grill
Flame not staying lit
This is a common problem with grills purchased after 2001. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
When the propane surges into the regulator (located on the grill hose) the 'surge protector' (inside the regulator) kicks on. When this happens you will not be able to get your grill lit, and if you do, it will be a small blue flame and the grill will not heat up.
So what to do if you trip the surge protector and can't get your grill to light or heat up?
Shut the tank off and shut the valves on the grill off. Disconnect the tank from the grill hose. When you disconnect the tank from the hose you will hear the excess pressure of propane release. This is an indication that you have re-set the regulator's surge protector.
Now that you have deactivated or reset the surge protector, reconnect the tank. Make sure the valve on the tank and the valves on the grill are in the closed and in the off position. After you reconnect the tank to the hose, SLOWLY open the tank valve (making sure the valves on the grill are in the OFF position).
Since you have slowly opened the valve on the tank, the propane did not surge into the regulator and the surge protector did not activate.
Now open 1 valve on the grill and light it. You should get a nice flame. If your grill has more than one valve, open each following valve in sequential order to extend the flames to the other burners.
Thanks for reading and I hope this helps.
Ben Gaetani
Tanks 2 You Propane
propanetanks2you.com
Tanks2youpropane@gmail.com
Mar 28, 2010 | Thermos Grill2Go Gas Grill 4656110
There is a high pitch that people over approx age 30 cannot detect. My son and daughter complained of a high pitched noise coming from our gas grill, but I could hear nothing. I turned the gas tank off,...
What they are hearing is the regulator. There is a diaphragm in the regulator that is vibrating due to the rush of gas flowing through it. This is easily corrected. First, the next time you light the grill, turn the tank valve only one quarter to one half of a turn and light the grill, once the grill is lit, if you have trouble bringing the grill to the temperature you want, you can open the tank valve more and the noise shouldn't start. The reason the noise won't start then is because by that time, the regulator's diaphragm is at the temperature of the gas flowing through it and, subsequently, will not vibrate. If the noise starts again, you can go to just about any home improvement store and get a replacement regulator.
Nov 18, 2009 | Kenmore 16322
How do i light this gas grill, it is a charbroil quantum....it was borrowed from our friend, who is now not picking up the phone...
Checklist:
1-Make sure propane tank has propane in it.
2-Turn regulator (valve attached to propane tank) on.
3-Turn burner dials on, usually there is a "light" or "ignite" position to let the most gas flow to start. If there isn't, just turn it/them to high.
4-Listen for the hissing, if you hear some hissing from the grill, it has gas flow.
5-Turn the dials back off and give 3-5 minutes for gas to clear.
6-Turn dials back on and hit the igniter button.
That should do it! :)
Sep 22, 2009 | Grilling
My grill won't light, and I don't hear gas running
sounds like a problem with tank valve. Try attaching back to grill. Open valve slowly, if you open to fast valve thinks it is leaking and shuts down. If this doesnt work try a differant tank, buy always open slowly.
Jun 12, 2009 | Weber Genesis Silver B Grill
Kitchen Ranges Logo
49 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
