Question about Tripp Lite TRIPPLITE INTERNET350U USB Internet Office UPS System (TRPIO350U) UPS System
How can i disable the beep alarm of my UPS its a internet35ou model ive installed the power alert software but i cant find any option to silence that alarm, its very anoying it beeps at least once per minute
5 Suggested Answers
  • 5 Answers
SOURCE: UPS Internetoff700 keeps wont stop Beeping
this is normal when especially when we have short flow of power,or power spikes,surges and sags.it is not overloaded at all i had such a problem some times back en ma technician told me it is ok
Posted on Feb 10, 2008
kershk
  • 106 Answers
SOURCE: My Powercom UPS overload
remove all loads, unplug it, turn it off, wait 1 minute, plug it in, turn it on, apply loads. if this does not solve the problem, replace it.
Posted on Jun 09, 2009
SOURCE: my smart ups 1500 beeps when connecting to AC powe...
I have a 1500 smart APC installed for my Server. I frequently have power problem so I switched off the beep. But owing to some recent development, I want the beep to be back, what can I do to bring the beep back? Thank U
Posted on Jul 19, 2010
epettingill
  • 175 Answers
SOURCE: The power went off and now the UPS is beeping at
You have bad batteries. Replace and the beeping will go away.
Posted on Aug 24, 2011
My 170 hummingbird beeps and wont stop even when i go through the menu and turn the alarm off on everything is this another piece of junk ????
Doesn't it show the cause of the alarm on screen? It might be the low voltage alarm which on some units can't be turned off, but can be adjusted to a lower voltage if it's alerting unnecessarily.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
Jun 15, 2015 | Cars & Trucks
How to stop beeping
If there is no alarm silence button. Most likely the unit have develop some internal fault
Mar 18, 2013 | Powerware 5110 UPS System
SO bad, and a bad response... I have 2 UPCs one started beeping for no reason, and will not stop...even when plugged into the wall with the battery disconnected... The other one is still silent. SO the...
These beep error codes may help you.
1. Four beeps every 30 seconds (On Battery LEDwill be illuminated)
This alarm indicates that the Battery Power Suppliedoutlets are now supplying battery power as opposed to power from the utility.If the UPS determines that the input utility power is unsafe for your computerequipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Battery condition hasbeen reached and that the UPS will soon shutdown. Once the UPS transfers to OnBattery operation, it can only stay on battery for a limited amount of time.The UPS will sound this alarm about two minutes before the batteries aretotally exhausted. Once exhausted, the UPS will shutdown and turn off itsoutput power to your equipment. If you hear this tone you should immediatelyshutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPSOFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overloadcondition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload was detectedwhile the unit was on-battery operation. This tone will continue to sound untilthe unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-powered outletsare overloaded.
6. Continuous Tone (On Line and On Battery LEDsflashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault hasoccurred.
Feb 28, 2011 | APC Back-UPS Pro 650 UPS System
HOW DO I MAKE THE ALARM SOUND STOP??? I HAVE THE ULTRA BATTERY BACKUP IN MY 911 CENTER AND THE COMPUTER ROOM DOES NOT HAVE ANOTHER AVAILABLE AT THE MOMENT, BUT THE ALARMS IT IS TRANSMITTING ARE INTERFERING...
From the User Manual:
When the UPS is in "Backup" mode, press the power switch for less than 1 second to silence the audible alarm.
(This function is disabled when the UPS is under condition of "LOW BATTERY" or "OVERLOAD".
Hope this helps.
Jul 19, 2010 | Ultra (ULT31502) UPS System
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
How do I stop the beeping on a Hinari Microwave?
Unfortunately, its programmed into the software. Ive never really seen a microwave thats given the operator the option to silence the alarm.
Oct 14, 2009 | Microwave Ovens
Minuteman Pro320 beeping
If the UPS has the serial or USB cable attached to a computer of any kind, you can use the UPS management software to disable the alarm until you can replace the battery. You should schedule the battery replacement for after hours just to be safe. If your phone system has redundant power supplies or two power cords, you can plug the system into wall power to replace the battery and then go back to battery power when you're done.
Jun 02, 2009 | Minuteman Pro 320 Battery Backup...
Opti-UPS 1400ES UPS unit - Beeping 14 Times, stops, Beeps Again.
you can try this asia systems technologies look for our sale person william +65 65478990 william@asiasystemstech.com i suspected that now that u UPS is have hardware issue.. to determine if the unit is really the problem it hav to be do a further diagnos..
Mar 04, 2009 | Opti -UPS PowerES 1400 UPS System
Turn off beeping alarm when the coffee maker is done brewing
you can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
Mar 23, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Patroit 425 UPS
Have you tried holding in the power button for about 10 seconds then releasing? If this doesn't work, try testing the UPS in a different outlet. Also, try looking for the panel containing the actual battery. Remove the contacts on the battery, and replace. Press
Aug 20, 2007 | Fellowes 99052 UPS 425VA Battery Backup...
Tripp Lite TRIPPLITE INTERNET350U USB Internet Office UPS System (TRPIO350U) UPS System Logo
538 people viewed this question
Top Tripp Lite Computers & Internet Experts
 Kevin Kershner
Kevin Kershner
Joseph Hoffmann
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
