Question about Electrical Supplies
2ooa squ. d main braker. lousing power on one side of house.
  • 565 Answers
The usual cause of this is the main breaker is not making good contact where it plugs into the busbars. Eventually it burns itself clear (open). The main breaker most likely needs replaced. Sometimes the busbars are damaged enough (from heat caused by the bad connection) that the entire panel needs replaced.
While replacing the breaker is not a difficult task, it's best to have this done and the busbars inspected by a qualified electrician, as one must be fully aware of the hazards involved.
Be prepared for sticker shock on the price of the new breaker, probably $100 to $150 just for the part.
Posted on Aug 30, 2010
Sparking in power box when we use the generator and trips the braker
When you say "power box" do you mean the main breaker box in your house? Is the generator hooked up to the breaker that you say trips when the generator is on? There is a short somewhere. First check the generator. Is it running OK. In other words if you plug something into the generator receptacle directly, does it work? If the generator itself works properly, then check the wiring from the generator to the circuit breaker. DO NOT use the generator until the problem solved = safety first.
Jun 12, 2014 | Cars & Trucks
Kenmore model 970-506021 no power to burners or oven but display works
Did you reset the house circuit breaker to the oven. If the stove is only getting 120 volts instead of 240 the display will light but no heat. A remote possiblity could be a burned wire at the power connector where the main powewr comes in to the stove of a bad comnnection in the junction box.
Feb 06, 2014 | Kenmore Ovens
MY PRODUCT HAS BEEN BEEPING EVERY 10 SECONDS AND GREEN LIGHT FLASHING. NO OTHER LIGHTS ARE BLINKING.
if it is plugged in and the power circuit live then check to see of the 2nd light from the left is lit.
this means the battery needs replaceing.
if that is not it turn the unit off and back on... you may need to hold the button for 5 seconds to turn it off.
doubble check the circuit braker on the back of the unit and the main for the office or house.
Aug 29, 2011 | Minuteman PRO700E...
Do these a/c units come with cables to plug in the inside unit into a receptacle
they are usually powerd from the mains power board in your house on a single separated circuit braker. they rarely are plugged in from the indoor unit into a power outlet
Nov 09, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Fridge wont get cold
Check your brakers, on your house braker panel, it should be a 20 amp, pust it all the way off, then all the way on to reset
Jul 04, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Blown Fuse
Find the main braker to the house. Pull it out, or flip it off. It's probubly right above the fuse. Plug some thing in several outlets, to make sure all power is off. Then use a pare of needle nose pliers, to get the fuse out. Make sure all power is turned off to the house!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jul 04, 2010 | LG 22.4 Cu. Ft. Side-by-Side Refrigerator...
Dryer made a cracking noise as wife attempted to turn on, dryer won't work as well as washer stopped at same time. have reset circuit braker no luck.
does the dryer use a 240 volt plug in there are two brakers one for heat and the other to run dryer look for two 60 amp brakers they may be at pannel or located out-side depending how old house is.
Dec 16, 2009 | Maytag Neptune MLE2000A Front Load Stacked...
No power on kenmore range
Make sure there's power getting to your range, oven or cook top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
If everything above is ok, move on to the power cord junction point. make sure the power cord has not separated from the junction point on the backside of the unit.
Jul 16, 2009 | Kitchen Ranges
2000 Blazer. No power to the orange wire for either front seat. Which fuse or relay controls the frt power seats? Its not listed on the fuse box covers and I do not have an owners manual.
The orange wire is the power wire for both seats.It gets its power from the power seat circuit braker (20 amp) located at the body relay block.It is located behind left side of dash near fuse block. Remove circuit braker and check for power in body relay cavity that you pulled the relay out of if power is on one side change circuit braker and if no power on either side then you have a bad main fuse near battery or under hood in main fuse block. Joe ASE Master Tech
Mar 05, 2009 | 2000 Chevrolet Blazer
Lg lcd 32ins
if you are handy with tv's you can open it up. there is a yellowis color board, that is the main power board and there is a fuse, try changing it out and test it.
Apr 30, 2008 | LG 32LX3DC 32 in. LCD HDTV
Electrical Supplies Logo
47 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
