Question about MTX Thunder 1501D Car Audio Amplifier
Mtx 1501d i have a mtx 1501d. i have proper power source - 2 one farad rockford fosgate capacitors buss bar'd together and 1/0 gauge wire. it powers up normal and produces sound, BUT not sufficient sound. the gain is not making much difference in sound from minimum to max, and the only way you can tell is by turning up the EQ and frequency. it won't do anything, then you turn it up and gives some sound... but nothing serious for it's capabilities - maybe 200 or 300 watts worth of power. if you have all of the knobs - freq., eq, and gain turned down, it produces zero sound, but you can feel the current in the subwoofers. besides not producing enough massive power, i have another exact amp in a differ vehicle w/ the gain 3/4 of the way up and both the eq and freq. down and it goes crazy so i know something is wrong. can you help me any?
  • 47 Answers
ARE U USING THE CONTROLS THAT CAME WITH THE AMP?
USUALLY THE CONTROLS CABLE GOES BAD
Posted on May 13, 2008
Are the capacitors suppose to stay lit and will it kill my battery?
It should be turned off with the key. If it continues to stay on it is installed incorrectly to a constant power source.
Mar 30, 2011 | Rockford Fosgate Rfc2d 2 Farad Hybrid...
How do i charge it
To charge a capacitor:
connect it to a power source that has less voltage than the capacitor's tolerance.
Wait for it to be balanced with the power source's voltage.
The source must be DC.
Feb 20, 2011 | Rockford Fosgate 1 Farad Capacitor Cpc10...
What number of cable should use on rockford fosgate 1 farad capacitor thanks
If good brand name wire, jl rockford monster kicker, the 8 gauge wire will be fine. if buying it at walmart or somewhere, then use 4 gauage wire
Jul 19, 2010 | Rockford Fosgate 1 Farad Capacitor Cpc10...
It's beeping when turned on. Why?
I have read that if the polarity is reversed, or the connections are backwards, the Capacitor will beep. If this is not the case, it may need to be replaced.
Will my car handle a rockford fosgat 801s power load?
Hello dreww1005,
If your alternator and battery are in good condition, you probably don't need a capacitor. At maximum output, the 801S will need to draw a little over 30 amps at 12.8V. The specifications call for 8-gauge power and ground wiring and a 40A primary fuse. The Vibe's electrical system should be able to handle it OK.
Hope this helps.
May 08, 2009 | Rockford Fosgate Punch 801S Car Audio...
Reconnecting two amplifiers adn farad capacitor
run a fused + wire from your battery to the + of the cap ground the - of the cap to a good grounding place on your car run a wire from the + of the cap into a one in two out disburtion block make sre it is a fesud one.then run one wire from each or the two out side of the dis block to each amp then ground both amps to a good ground.what type of amps do you have
Mar 19, 2009 | Kenwood Car Audio & Video
Lost...
The 1501 is very similar to the 81000 but there are important differences. The 1501 is a better amp.
If you turn the gain up and down, does the woofer move in and out in direct relation to the rotation of the gain?
What do you mean by "you only feel current going through subs"?
May 09, 2008 | MTX Thunder 1501D Car Audio Amplifier
Any ideas?
CHECK YOURE EQ OR TRY TO BYPASS THE EQ FOR TESTING
May 08, 2008 | MTX Thunder 1501D Car Audio Amplifier
Clueless..!
You either are suffering from phase problems with the way you have your subs wired or you fried them and just don't realize it. I sell the TE1501D and these amps are not poorly made, they are however too powerful (1500+ @ 1ohm) for most subs on the market to handle continiously.
May 08, 2008 | MTX Thunder 81000D Car Audio Amplifier
Im not get any loud base, even with the gain at full turn
an orion 2500d requiers 2 4 gauge power and ground wires to work properly.
Aug 22, 2007 | Orion 2500D Car Audio Amplifier
MTX Thunder 1501D Car Audio Amplifier Logo
119 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
