Question about Whirlpool RF263LXTQ Range
Oven will randomly shut off and won't come back on. Sometimes oven works fine.
  • Whirlpool Master
  • 43,501 Answers
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Aug 29, 2010
Jenn-Air oven shuts down after FC and F5 errors
Their was a good possibility that the solder could have been lifting of the contact points on the board, if the symptoms return i would check this, along with the said cleaning method :)
Mar 15, 2014 | Jenn-Air SCE30600 Slide-In Electric...
Range works fine, but oven takes forever to heat up. sometimes i will shut it off and back on to see if it will work. what do you suggest
There is a thermostat inside the oven sometimes on the upper left corner. When the element to the probe goes out the oven doesnt know how to heat up anymore. The element is very inexpensive to replace and easy to do. It should have 2-3 small scres holding it in and it can be pulled out for replacement.
Jul 08, 2012 | GE JGSP23 Gas Kitchen Range
WHEN YOU TURN OVEN ON AND PUSH BAKE BUTTON AT 400 AND PUSH THE BAKE BUTTON AGAIN THE PANEL WILL SHOW 400 AND BEEP AS IF READY BUT OVEN NEVER HEATS UP. SOMETIMES THE DISPLAY WILL RANDOMLY FLASH DATE. ...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Maytag MERH865RAB Electric Range
Oven shut off - no power- checked circuit breaker no problem. oven came back on thye next day and is working fine. is this an overheat problem -is there a circuit breaker on the oven that resets? what...
This sounds like the thermal overload operated and turned the oven off. The overload is generally located in the top of the oven cavity. Remove the top cover and you should find it. Sometimes it open circuits the active supply and sometimes the neutral. Sounds like it may need replacing.
Feb 15, 2011 | GE Profile JTP18 Electric Single Oven
When I turn the GE oven on sometimes it works fine other times it will shut off. When it shuts off it will give the F2 or F3 error sign.Can you please tell me what this means? Thanks
Hi, the F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
The "F3" error code means the oven sensor is open, I suggest you flip breaker off then back, on Re check for error, if OK fine if not turn back off and fix or call for service man...
Oct 06, 2010 | Ovens
FAN WONT SHUT OFF
My Kenmore microwave oven fan has been turning on and off, almost every hour. Sometimes 3 or 4 times in one hour. It's very random. Model No. 721-80593401 Serial No.503TA03208
Please help!!!
May 31, 2009 | Kenmore 62642 / 62644 / 62649 Microwave...
Oven shuts off while in use.
Did you ever resolve this problem?
I have the same oven and I am having the same problem.
Thanks,
Jamie
May 03, 2009 | Ovens
JENN-AIR Oven shuts off and comes back on after several minutes
they are equiped with a heat sensor it could be a bad thermastat(sensor) or
ventalation problem
Nov 20, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Whirlpool RF263LXTQ  Range Logo
101 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
