Question about Microsoft Xbox 360 Console
Will not plat any disc says to open door then reading then tell you to open door for disc then to close door
    Novelist:
  • 142 Answers
If your console wont read your disc then there is an issue with the disc drive in your xbox 360. The most common failure responsible for this issue is the laser going bad. If your xbox 360 is still under warranty than you can contact Microsoft directly regarding the issue. If not you can replace the laser manually. Below is a link to a Youtube walk through on how to do this.
http://www.youtube.com/watch?v=5XiYSV9ztVU
I hope the info listed above has helped in some way.
If possible please rate this solution.
Posted on Aug 30, 2010
Dvd door will not open or close when eject/open button is pushed. I can open door and slide tray out by hand, howevery when disc is inserted in tray and pushed back in, system does not read disc as being...
The low humming sound is the motor that opens and closes the drawer. It is moving, but the movement is not being transferred to the door by a pulley, a belt or a gear, When you open the drawer completely, it should stop. When the drawer is closed completely it continues to run until the disc is in the proper position to play. As long as that motor is running the DVD will not work because the disc is not in the proper position,
Feb 03, 2018 | Panasonic PV-D734S DVD Player/VCR
Sony dav-dz555k home theatre system-dvd tray keeps opening and closing, wont read disc at all. have to manually push tray closed and change setting from dvd to something else to stop it.
You seem to be having a door sensor problem. When the CD tray closes a small switch under the loading tray shorts telling the microprocessor the door is closed and to stop the motor (either way when it opens or when it closes). A malfunction in this switch causes this symptom.
Mar 14, 2011 | Sony Audio Players & Recorders
Dreamcast is not reading disk says please put in disk
There can be 1 or 3 problems with this
1 The laser lens needs to be replaced
2 The motor that spins the disc needs replacing
3 The motor that drives the laser carriage needs replacing.
90% of the time its the laser lens
Jan 25, 2010 | Sega Dreamcast Console
Disc door will not open
The magnetic weight thats mounted on top of the dvd drive on the inside has came loose and jamming the door. Also it wont read the discs if this happens. I repair drive issues in PS3 and 360's with 99% success
Jan 22, 2010 | Microsoft Xbox 360 Console
My dvd player won't read disc, the door keeps
change the motor belt charge it´s located downside the disc tray
Nov 09, 2009 | Apex Digital AD-500 DVD Player
I bought a gamecube online and it wont spin the disk
Sounds like you need the Gamecube sensor switch replaced. That is a small door device for detecting when the Gamecube DVD door or lid is closed allowing disc initiation to begin. When your Gamecube doesn't detect disk at all and simply continues the message: "Please insert a NINTENDO GAMECUBE DISC," this is the problem. You can test this by inserting a game disc, opening the Gamecube door, and then closing it. If the message "Please insert a NINTENDO GAMECUBE DISC" remains unchanged, and there is no spinning of the disk, then your GameCube lid closed door sensor is probably broken and should be replaced. You can search Google for Part GCPT032, or for GameCube Lid Closed Door Sensor.
An easy fix if you know how to open the Cube. It's cable simply plugs in, and it is held by one tiny screw.
Sep 05, 2009 | Nintendo GameCube Console
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
Cd drive door will not open. when opened manually and disc inserted door will not close automatically and will not read a disc
Is there any power to the drive? IE is there a green light on the front when trying to read the disk?
It may not have the power in, or may have blown a power circuit.
IF it was just the door not opening and the unit has power, i would suggest the little rubber band is having issues and not opening or closing the door.
Dec 18, 2008 | Computers & Internet
How do we adjust an aluminium door?
the door has a cam that has to be adjusted to force the pin up
call a local glass company and ask them where the adjustment is located
there is usually some type of access plat near the bottom of the door frame close to the hingee on the inside close to the bottom
Nov 26, 2008 | Locks & Locksmithing
Microsoft Xbox 360 Console Logo
44 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
