Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby ultimate g handle staying upright
My kirby handle won't stay upright and I need to replace the pivot assembly switch. I have the owner's manual and I have seen a diagram of the parts on the internet, but I am wondering how to crack the case. It seems like it's using hex keys, but I was wondering if there are specific instructions, or a manual, or special hex key tools or anything. I have found web site to order part, but don't know if the part comes with instructions . . . . .
nancys
  • 357 Answers
Please see my online guide for replacing the power switch. It will get you into the case. Just use this link....
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope this helps...
Marci
Posted on May 11, 2008
I replaced safety switch then transmission stopped working
common fault when customers do their own repairs, the handle pivot assembly is not sitting in the yoke assembly
Nov 26, 2012 | Kirby Ultimate G Bagged Upright Vacuum
G4 transmission does not engage going forward
The handle pivot is set too far back on it's slide. It will be necessary to remove the handle, switch plate, and upper motor shell to access the slide. Two large phillips screws hold the pivot assembly to the slide. The pivot must be loosened and moved ahead very slightly, while centering the slide in place.
Jan 13, 2011 | Kirby G4 Bagged Upright Vacuum
Regarding my Kirby Generation 3 upright vacuum cleaner: the handle does not lock into place, but rather falls to the floor. Any thoughts on how to get it to stay in place? Also, I lost my owner/operator...
The plate that catches the handle to lock has a hidden spring behind that plate.I would leave it alone for the unit is pressed together. Used ones are found most everyday on Ebay. The owners manual maybe found on this website
freemanuals.com
Mar 26, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Power button wont stay on. have to hold the power button manually for it to stay on.
Most likely you have to replace ON/OFF switch. look at detail instructions how to do it on our website:
http://www.goodvac.com/kb_results.asp?ID=18
If you need any parts or supplies for your Kirby sweeper you can find lowest prices on our website http://www.goodvac.com/. Everything is in stock and ready to ship same day.
Good Luck,
Rocky
Dec 30, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby model gd3
The "switch" refered to is probably the handle release button.
Sep 07, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Assembly
The handle just snaps into place on the top. there is a handle pivot, it goes in that. The bag, put over the exhaust hole on the right side, make sure it locks into place, the bag top will snap into the top part of the handle.
Jul 11, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Handle on kirby ultimate g won't stay upright
Just take the handle off, rermove the 2 screws on the front of the cover, remove the plastic piece on the back of the top, then remove the 2 screws and the top cover will come off. There are 2 screws holding the handle pivot on, remove those. Install the new pivot making sure that it alines with the transmissing on the left side, re-install the 2 screws and make sure they are tight. Then put the rest back together.
May 10, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby attachments instructions
Ok, the hose goes on the front. The light should lift up then, the front emblem rotates. this releases the belt from drive shaft. Underneath where the light was, there will be a release lever, which will release the entire front end where the brushes are located.
Once removed, you will see the intake fan and bar beneath it. The hose hooks to this bar. Then to the left of intake, there is a safety switch. The end of the hose has an arm that will fit into this safety switch.
Once hose is in place, the release lever that loosened the brushes will now tighten the hose.
The bag stays in the same place. If you have the 2nd handle attachment, you can use that to replace the upright handle. The release button on back side of handle.
I own a G4 and used to sell the G6 which was right before the one you own. The G3 thru Ultimate G are work in the same manner just different colors.
Hope this was helpful.
Apr 22, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Replace release button on kirby 3
I assume you are talking about the release on the handle pivot. Unhook the bag so it is out of the way, take the hanle off, take the top cover off, then there 2 screws holding the handle oivot asm, take them out, replace witht he new one, making sure that the the piece that hangs down meshes with the transmission. Then reasmble.
Oct 02, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Upright won't stay up right
I figured out that when mine did the same thing, it was time to change the bag. It was too heavy for the handle to handle! LOL Hope that helps. Tracy
Jul 26, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
202 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
