Question about Technics SH-GE50 Home Equalizer
I loss my manual I need to know how to wire up my technics stereo to all componets they are av control stereo receiver sa-g78, stereo graphic equalizer sh-ge50, cassette deck rs-tr180, compact disc changeter sl-mc59.
marsrover
  • 682 Answers
SOURCE: dont know how to connect everything so it all works
you need a small mixer from radio shack near you.
1-connect cd player to channel 1 in mixer.
2-connect tape to channel 2 in mixer.
3-connect mixer out to equalizer in.
4-connect equalizer out to amp in.
Posted on Nov 11, 2008
djproaudio
  • 515 Answers
SOURCE: Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Posted on Dec 18, 2008
djproaudio
  • 515 Answers
SOURCE: Hooking up audio components
This was answered here: http://www.fixya.com/support/t1371668-having_hard_time_connecting_various
- OPTiC
http://www.djproaudio.com
http://www.repairny.com
  • 47 Answers
SOURCE: I have a 1986 vintage Technics component system
Since you have all the model info on hand, go to the manufacturers web site, look for the support page. if it is an older system, you'll want to look under older products, legacy or OLDER equipment. If that does not work, then try google. If all else fails, just remember>>> the Equalizer is the last component that plugs into the AMP's INPUT.
Posted on Sep 19, 2009
gopakumarg43
  • 74136 Answers
SOURCE: DESIDERO RICEVERE MANUALI DELLO STEREO TUNNER AMPLIFIER SA EH790 e COMPACT DISC SL-STERE$O CASSETTE DESK RS- STERO SOUND PROCESSOR SH. INVIARE BMAIL A: prof.cufaro@alice.it GRAZIE MILLE
Hello
Please send me the Brand Name and Model Number of devices that user manual is needed. OK.
Posted on Dec 21, 2011
I have a Technics AV control stereo receiver sa-g78 Whenever I turn it up a little louder than normal..is says overload then it powers off...I need someone to tell me what I need to do...but dumb it down...
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 28, 2011 | Technics Audio Players & Recorders
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Need a new power cord....misplaced mine...
i did the same thing. replacement at radio shack.
Jan 17, 2009 | Technics SA-EX140 Receiver
Probleme with my home theatre...technics..av control stereo receiver- model SA-G76
just an idea maybe check the position of speaker select switch some models have
a or b
or a+b
Apr 24, 2008 | Audio Players & Recorders
I need help
Loose connection on "POWER-SUPPLY" and sometimes solder loose on "C I S BOARD" due to extreme - heat of amplifier. $137.51 repair done in 1HR as I waited at CENTURY SOUND ELECTRONICS.
Jan 19, 2008 | Audio Players & Recorders
Technics sa-g78 no sound from front speakers
This happens on mine also. My theory is a relay. If you turn the volume up (Waaay up) momentarily, you "burn through" the oxidation on the relay and the sound comes back - for awhile. Some day, I'll get in there and replace it with something more robust.
Aug 06, 2007 | Technics SA-AX540 Receiver
111 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
