Question about Garden
Bolen 15.5 38' cut where is the spark plug located
  • 472 Answers
bolen 15.5 38' cut where - 98a4bdd.jpgOk do ya that black line its at the end of the of that wire
Posted on Aug 30, 2010
Repair and replace power module on bolens culivator 31cc engine
How old is it? Does it show a spark when you remove plug an hold against engine while pulling cord? Did you replace plug? It is the most common problem. Remove the stop wire an try to start, if it does or you see spark the switch is bad. I would check put these things before replacing module.
Mar 16, 2014 | Bolens 31cc 2-Cycle Gas Cultivator BL410
I have a Bolens BL110 Trimmer - it starts just fine, but won't rev up completely. Suggesstions?
Could be blocked spark arrestor or carboned up in the exhaust port.
May 06, 2012 | Garden
I have a bolens 4.5 HP/22" cut mower thats sputtering and sometimes stops working. Other than that it's not a bad mower but I need it to stop cutting out.
Check the air filter. Often people forget about that and when they get clogged the engine runs really poorly. If that checks out, check the spark plug and the quality of the spark. After that I would look to debris in the carburetor.
I hope this helps get you going soon.
Aug 17, 2011 | Garden
15.5 hp B&S engine on Bolens 42 in. mower will not
First off drain out oil and replace with new.
Second, remove carb, take off bowl on the bottom and remove the float, you need to do this because dirt has got under the needle and caused it to stick open allowing fuel to flow into your oil sump, once removed blow out gently, or wash with clean fuel and rebuild.
Once you have done the above, remove the spark plug and pull engine over about 15 times to blow out all oil and fuel that is sat in the top end of engine. Refit the plug and attempt to start her.
If the engine still wont turn over adjust valve clearances to 7thou, this will make the auto decompresser work more efficientley. to adjust the clearances, set piston to top dead center with both valves closed, back piston off 5mm ( guage this by putting a thin screw driver down the plug hole to touch the top of the piston, then turn top of fly wheel by hand untill screw driver moves in to engine by 5mm). check gaps on valves and reset to 7thou.
Valves are located under silver cover on the front of the engine next to exhaust pipe from cylinder head. The cover is located by 4 bolts, one in each corner.
Hope this helps,
Doc Scott
Jun 22, 2011 | Mtd Garden
The cutting head on my bolens bl160 2-cycle trimmer will not cut grass. The cutting head still turns, but when I try to cut grass the head will stop moving, but the engine is running fine?
The clutch is fouled with assembly grease. Separate the boom from the powerhead, then use a T20 screwdriver insert into the clutch drum. Remove spark plug and insert a small length of rope to hold piston, now remove screw in clutch hub. Slide off clutch hub and clean with soap and water. If excessive grease is on end of boom drive shaft remove the excess but leave a little. the rubber clutch shoe works by stretching with faster engine rpms.
Jul 29, 2010 | Garden
What is the spark plug gap on a 4.5 HP 21" cut
With out the model # of engine or plug not 100% certian but 99% of those mower engines run a .8 or .9mm plug gap you will be preety safe setting it at that
Regards
Brad
Feb 05, 2010 | Mtd Products Yard Machines 158CC Tiller
Lawnmower wont start
Are you getting spark first of all. If you are getting spark do you have good gas? If you have good gas most likely your carb needs some attention maybe you had some old gas sitting in there and something inside is gummed up it might need cleaning.
Sep 19, 2009 | Poulan "Poulan" Push Mower
Does Bolen's weed wacker BL100 17" cut 31 cc require a mix of gas and oil. Thank you
I was able to get information from someone's manual. I can't find mine. Would like a manual.
May 16, 2009 | Mtd Garden
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
