Question about Coleman Electrical Supplies
I have a nikota 3500, 6.5 hp generator where can i get an ignition coil?
    Problem Solver:
Caall cummins crosspoint 304-769-1012
Posted on Aug 31, 2010
Anyone know the part number or a cross ref number for the spark plug in a nikota 3500 w 6.5 hp generator
$14.95 for this one. If you take the plug out of it, the reference number will be on it. Put the number into Google and you will get the equivalents in other makes.
NGK Spark Plug Motor Parts For Niko Nikota 6 5HP 3500 Watts Generators
Dec 10, 2017 | Electrical Supplies
Take the plug to any small engine shop and they should be able to get you one that's compatible.
Dec 10, 2017 | HP Electrical Supplies
Nikota 3500 generator 6 hp engine gasoline wont stay running.will not idle when starting.need spring diagram for engine govenor
Depending on the type of governor the spring arrangement is fairly obvious if you remember the springs are intended to open the throttle and the governor is supposed to close the throttle as the speed rises until the two forces are equal at the governed speed.
The governor and the springs should not interfere with the idle in any way though a generator usually has no idle setting but settles at the governed speed as soon as it is started.
Unless the springs have been disturbed I suggest you concentrate instead on discovering why it won't keep running. It sounds very much like a fuel fault but that shouldn't prevent you servicing the ignition as well as per best practice.
Sep 14, 2017 | HP Electrical Supplies
Greetings: I have a 3500 wts 6.5 Nikota generator, turn on and off several seconds. The carburetor is fine, ignition, too. The shoot off well, I would like to give me an idea that can be
you saying it wont keep running
you have spark at the new spark plug
fuel is fresh and uncontaminated
could be
the coil or the plug lead
ok when cool ... fails when hot
the Governor setting
carby jet blockage
if a four stroke a valve adjustment might help
Oct 12, 2016 | Electrical Supplies
I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can check.
All Power America APG3535CN, 2800 Running Watts/3500 ...
www.amazon.com/...Power...Generator/.../B000U0OJ...
Amazon.com, Inc.I then call All Power and am told to give them one more day to get this worked out ....There is no styrofoam enclosure or crate to protect it, the generator is simply ...
NIKOTA 3500 WATT GENERATOR - YouTube
? 0:58
https://www.youtube.com/watch?v=NEeu9Y-0_KM
Aug 27, 2011 - Uploaded by mamasboypowersports
NIKOTA 3500 WATT GENERATOR. ... Diagnosing A GeneratorThat Has No Power Output. - Duration: 3:03. TheDIYGuyDOTnet 117,263 views.
I have a nikota 3500 watt generator and I am not getting any ...
www.fixya.com/support/t26062098-nikota_3500_watt_generator_am_not
2 hours ago - I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can ...
Generator outputs low variable voltage, ideas for troubleshooting ...
www.smokstak.com > ... > Generators & Motors General Discussion
Jan 20, 2016 | Electrical Supplies
My Nikota 3500 watt 6.5hp OHV Engine Electric Generator all of a sudden quit running. I am getting gas and fire to the plug,but it wont start. I am lost and need help.
replace the gas with fresh and treat it with Startron additive to fight against the ethanol in gas and keep it fresh. gas goes bad in a bout a month if not treated now. you might have to take the carb bowl off and clean the carb. good luck hope this helps
Feb 23, 2015 | Electrical Supplies
Nikota 06041
1/4" gas line can be bought at any Auto Parts place. Any generic shutoff can be bought there too.
Dec 09, 2013 | Electrical Supplies
I have a Nikota 3500 generator, and I had a shorted circuit in my cabin. Now the generator puts out only 92 to 103 volts. Is there something I can do to fix this myself? Do you think it may have knocked...
Usually a power surge (short) or sometimes an overload will take out the diodes. Like you have suggested I would say that you have just knocked out one... Test them and replace the bad one and you should be good to go.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 29, 2009 | Electrical Supplies
I have a Nikota electric generator 3500 watt 6.5 h.p. ohv - I need a part for the carburator base, where i find this parts?
I also have a NIkota 3500 generator, which had a carberator problem. I just ordered a new carb from Yilong-motor.com in China. They may be able to help you. RJL
Aug 20, 2009 | Coleman Electrical Supplies
Electrical Supplies Logo
321 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
