Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
The blade/motor does not run, it only does run once
In the while but when I turned my lawn mower upside down or its side the blade runs fine
  • Anonymous Apr 02, 2009
    where to buy the switch ( does local store carry it?)?
Same thing happened to mine it was a short in the switch (replace switch) make sure to take note of which wire goes to each terminal before replacing
Posted on May 13, 2008
Blades turning in wrong direction on 48"zero turn 18 hp husqvarna.Any solution
Yes take it to the dealer and have them check the pump since it uses hydraulic motors, it sounds very much like the pump is running backwards or is it possible the blades are on upside down
Oct 10, 2016 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How to replace plastic blades on a challenge mower
Dave, Remove plug wire, raise mower, or tilt on it's side to access blade. Remove center bolt holding blade on, noting the position so as not to install new blade upside down. Install new blade correctly and tighten blade bolt tight. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change Lawn Mower Blade
Lawn Mower Repair How to Remove Lawn Mower Blades
What Direction Do Turn the Nut to Change Mower Blade
Jul 28, 2016 | Garden
I have had my Masport mower serviced plus new blade but it dose not cut the grass
What is the problem?? Is there not enough power or does it run okay but just not cut the grass in which case maybe the blade in upside down.
Oct 12, 2014 | Garden
I was mowing and the blades stopped turning. I disengaged and re-engaged the blades a few times and they started back. Then a few minutes later the blades stopped again then the motor stopped and will...
I have no idea what type or model of mower you have but if I was to guess I would say it has an electric pto clutch on it, if so remove your pto belt and clutch. I would bet it is burned out and locked up preventing your motor from turning over. Once the clutch is removed I will bet it will start and run fine. This is not a cheap fix but relatively easy one. Hope this helps.
Aug 21, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
Replace blade on electric lawn mower
IF IT IS A CORDED MOWER MAKE SURE IT IS NOT PLUGGED IN -
IF IT IS CORDLESS, MAKE SURE SAFETY DEVICE (KEY) IS REMOVED
If you have a work bench, place your mower on the bench on its side or upside down where you can see what you are doing. If no bench, the floor of your garage or your driveway will work too.
Get a small 2 x4 block, a C-Clamp or some other device to keep the blade from spinning.
Get a ratchet or breaker bar and socket to fit the bolt in the center of the blade.
After you are sure the blade is blocked from spinning, turn the socket and ratchet to the RIGHT (clockwise) to loosen the nut until you can completely remove it.
When you install the new blade, look at it to see if it is marked "grass side" if it is not marked, the sharpened area on the blade should have the "beveled" edge toward the housing and remember the nut will turn to the left (counter-clockwise) to install and tighten. (Electric mowers have LEFT HAND THREADS due to the rotation direction of the motor.)
Oct 08, 2009 | Black & Decker 18", 6.5a Electric Mower
Lawnmower blade turns but does not cut
You have either bent the blade and its to high to cut or you need to sharpen the blade with a grinder.
Aug 01, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Problem mowing my lawn.
I had the same problem and I already found those recommended solutions\ causes on the web:
1. The motor isn't on full throttle.
2. The blade is upside down.
3. The grass is too high when cutting it.
4. Overlap your cuts.
It helped my problem/ I hope it will help yours too!
Sep 01, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
