Question about Sharp CD-PC3500 CD Shelf System
The drawer for the cd player will not open. The whole unit will not shut down.
  • Sharp Master
  • 11,800 Answers
The unit is frozen - to reset it just unplug it from the wall for 1 hour - use this time to take off the sides of the main unit and pull out the tray manually to remove the disk.
Posted on Aug 29, 2010
How to open the cd drawer when the open/close button won't
Remove the lid, you will probably have to remove the whole cd mech and turn the gear underneath with your finger
May 22, 2014 | Marantz SA8260 CD Player
Cd has fallen behind disk tray and drawer won't close
Remove the metal case/top from the whole unit. See screws at back and any at sides. You should then be able to see and remove the CD upwards, without removing the drawer.
Dec 14, 2013 | Yamaha Audio Players & Recorders
Compact disc drawer on unit does not open
Drawer was jamed,It will have to be taken in to a repair shop, To be realigned, Unless the gears are jaming up, Then you might as well just look for a different one, You could take the cover off to see what it is doing,
Nov 04, 2012 | Denon Audio Players & Recorders
Sony CD player CE-415 Drawer will not open.
This will require a professional, the more CD'S this unit can take the more complicated the loading bay will be. The most common problem is gear timing where the system is knocked out of sync and often locks down the device to prevent further damage. Sometimes the gears will strip jamming whole mechanism.
Mar 15, 2012 | Sony CDPM400CS 400-Disc MegaStorage(r) CD...
My CD drawer is stuck and has caused the complete unit to shutdown. Digital display reads : ' DRAWER ERROR '. How do I get things up and running again ?
ok i had this same problem happen to me this is what i did to Fix the problem.
i fully shut down the computer removed the power cord from the CD player and reinstalled the unit also make sure nothing is in the CD player.
if this doesn't work give me some more info on how this problem happened.
Jan 23, 2011 | Computers & Internet
My CD drawer will not open or close
I had a mini system with the same problem, out of guarantee so was either fix it myself or bin it.
I opened the unit and removed the whole cd drawer assembly from it's housing. I then, not really recommended, plugged it back in and by pressing the open/close a few times the drawer finally opened. Put it all back together and it now works fine. I think what had happened is that I use the cd player once every couple of months and combined with the lack of use is the fact that there are several smokers in the living room and basically it got jammed by a build up of nictotine or whatever.
Apr 01, 2009 | RCA 5-cd 300w Stereo System Shelf System
Drawer opens when the player is switched on
hello marc you have a dirty laser,blocked sensor or even a misaligned condition try this clean the lens put a disc and turn it off with the tray inside wait about a minute and turn it on saludos
Jan 11, 2009 | NAD C521 CD Player
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
CD Player
WIthout knowing the specific model, I can't be 100% sure, but a number of models in that vintage had a problem with cracked ribbin cables that go to the drawer unit. Replacing the cable usually fixed the problem. What is the specific model number?
Dan
Jul 29, 2008 | Sony CMT-CPX11 CD Shelf System
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
Sharp CD-PC3500 CD Shelf System Logo
47 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
