Hello all, I'm working on a small project and was wondering if anyone had some insight or indepth knowledge of this peticular monitor or monitors similar to it.
Project: I'm in the process of mounting the LCD panel and controller card inside of a custom container shell.
The power supply / inverter with this LCD monitor is bigger than the space will allow for, therefore I would like to run the panel and controller card off of an existing variable controller card.
I already know that there exists a 15V and a 5V circuit between the power board and controller card, however, I'm not sure on the voltage coming from the P101 and P102 connectors on the board (the connectors that the LCD panel plug into). I guess more or less I was wondering if someone had that information. Thanks for any input :-)
I'm not sure about P101 and P102 but if this point is located on the controller card.But normally if connecter to LCD from controller
board then it should be a data cable and that to is not measure it.You've to really becareful for the cable that connect LCD backlight to inverter cos that is almost 1000 V!!!!
But for sure if you could mail me the picture.
[email protected]
goodluck,takecare.
