Question about Frigidaire ATF6000ES Front Load Washer
Drum bangs while turning - Frigidaire ATF6000ES Front Load Washer
  • Frigidaire Master
  • 2,341 Answers
If the tub is banging all around and very noisy in the spin cycle it's time for a new washer.the spider gear is broken,this happens from using to much detergent,the front load washers use very little water so you should only be using very little detergent and it should be H.E. detergent.the spider gear costs around 500 bucks and the detergent eats at it like acid,let me know how you make out
Posted on Aug 29, 2010
Whats wrong with Dryer
The drum slides at the front are made of felt. Yours have worn away. The drum is banging up and down. If you open the door you will find that you can lift and lower the drum. If you drop the drum, you will hear it bang. They are easy to replace if you can get the front off the machine.
It could also be that the rear drum bearing is worn, but that doesn't normally make a banging noise. It is a metal spindle attached to the drum into a nylon sleeve in the back of the machine.
Nov 04, 2015 | Dryers
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
Drum not turning properly
Sounds serious! If the drum is floppy, it probably means bearings on rear shaft.Or there may be something caught between the tank and the wash basket.Check for wire or similar caught in holes in was basket. Try turning the was basket slowly by hand to see if the banging happens at the same place......Nomess
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Loose drum bangs during spin cycle turn by hand with nothing in drum and still bangs?
your front drum support blocks have failed. remove the tub and, replace or, rebolt them in place so they hold the drum front in place.
Jan 25, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Washing machine was making a loud banging/tapping niose when the drum was spinning. It doesn't sound too good when turned manually. Is it the bearings and are they easy to fix?
banging may happen due to low load also, as cloths form a ball shape at one place.
otherwise it might be bearing or bearing housing. bearings are very difficult to replace as whole drum need to open. if bearing housing got loose in drum then drum needs replacement, also very costly.
Nov 18, 2009 | Ariston Technologies Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Turned drum by hand, heard loud bang. Drum will not turn anymore. How do I fix it?
your belt probably broke the bang evidentally was the pressure being taken off your belt tensioner when belt gave out take frt cover off then top cover both will need to be off to repl belt anyway if that was it
Jul 13, 2009 | Kenmore Dryers
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Hotpoint VTD00 Banging loudly once per rev
I think the bearing has gone in the drum !!!
Dec 31, 2007 | Dryers
Frigidaire ATF6000ES Front Load Washer Logo
233 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
