When the Samsung YP-3U is plugged into the USB port, it registers as disconnected and the computer can't find driver files for it. The computer has been fully updated and is running Windows XP with SP3.
  • shandy_boss Jun 24, 2008
    i plug it in the usb port and it just registers as discounected. I have tried to format it through the computer and the device but nothing seems to work help me. I dont want to have to throw it away its so useful.
Posted on Jun 22, 2008
I need a charger for my samsung yp-k3 2gb mp3
The MP3 player is charged by connecting the supplied USB cable to the MP3 player and then plugging the other end of the USB cable into the USB port of a working computer.
This cable is also used to copy music files, video and photos to the MP3 player from the computer.
Dec 28, 2011 | Samsung YP-K3 MP3 Player
Why when i plug the MP3 player (YP-T10) into the computer, the computer says 'One of the USB devices attached to this computer has malfunctioned, and Windows does not recognise it'?
Here are a few things you can try:
1) Plug it in to other USB ports of your PC/laptop. The port might be faulty. 2) Replace the USB cable 3) Download the latest driver from Samsung's website here:
http://www.samsung.com/my/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=YP-T10AB/XME&srchword=YP-T10
Click on "Downloads"
Mar 07, 2011 | Samsung YP-T10 Digital Media Player
Samsung YP-U3 is not recognized by computer
it is not appering in my copmuters but it is charging.
Jul 23, 2009 | Samsung YP-U3 MP3 Player
My mp3 doesnt connect into my usb it just disconnects and starts to charge can you help me
I assume from your description that either you are running a version of Windows older than XP/2000 or you need a special driver. Here is a link for the driver(s) you will need. Just enter your model number and select your version of Windows. Download and run the file and you should be up and running shortly.
May 30, 2009 | Samsung YP-U3 MP3 Player
My yp-u3 wont connect
no reconoce el dispositivo
Nov 06, 2008 | Samsung YP-U3 MP3 Player
MP3 can't work normally
With the YP-u3 connected to the USB port and internet connected, start Samsung Media Studio software, you should get notification of a firmware update to download which fixed the recognition problem for me
Sep 13, 2008 | Samsung YP-U3 MP3 Player
Samsung YP-U3 MP3 Player Problem connection
Found the solution on another site (http://www.everythingusb.com/forums/showthread.php?threadid=11238). To quote user AFHavemann :
"* Plug in the player so the USB bus can see it.
* Once it’s recognized (i.e., the device screen reads "Charging" and "USB Disconnected"), go to the Control Panel and click "System"
* Choose "Hardware" then "Device Manager" tab.
* Look for the name of your device under “Portable Devices” in the list
* If the name of your player is under “MTP Device” then the correct drivers are probably loaded
* Right-click on the name of your device and click "Properties"
* Click “Update Driver”"
Then follow the prompts from there. The computer searches for the driver software, etc., and reinstalls/resets information related to the device, which fixed things such that the computer will now recognize the device. I'm not sure what causes the problem, but this solution seems to reset whatever's gone wrong.
Sep 03, 2008 | Samsung YP-U3 MP3 Player
S3 won't allow file transfer.
SOLUTION FOUND!!! NO DRIVER PROBLEM ...Right click on my computer,go down to properties ..next window click the hardware tab,then click on device manager...right click and goto properties on ALL your "usb ports"...goto power management and uncheck the power saving box for every usb port,and click ok,then restart.!
Aug 09, 2008 | Samsung YP-S3JAB Digital Media Player
U3 mp3 player
I bought a Samsung YP-U3 . It had the installation cd .When plug to usb port It's charging but it shows disconnected...the samsung media studio and my pc don't recognise it, allways ask new samsung YP-U3 found. when i give the path to cd it dint get. Please help me....
May 13, 2008 | Samsung YP-U3 MP3 Player
Connection to my computer
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Doodles1
Dec 31, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
456 people viewed this question
 Grubhead
Grubhead
