I have a commercial Frigidaire Model FCCW3000FS0. It was unplugged yesterday while putting in a new dropped ceiling. It was not moved. When I plugged it in today, put in the proper number of coins, it would not work.
  • 3,740 Answers
It probably has sensed an off balance condition from being moved. Make sure the unit is level and the try centering the wash tub with the door and see if it will start after closing the door. You can rock the tub CCW and CW also to see if you can get the balance switches centered again. If that doesn't work just respond here and we can go from there.
Kelly
Posted on Aug 29, 2010
  • Kelly
    Kelly Aug 29, 2010
    Sorry I just re-read it. You said it was unplugged but NOT moved. Check out the coin slot using this manual to verify settings: http://manuals.frigidaire.com/prodinfo_p... pages 7 - 9. If nothing else verify the inital timer position. Ome more dumb question... did any one by chance happen to turn off or trip the breaker during the installation of the dropped ceiling? At least try checking power at the plug.
    Kelly
I have a frigidaire dishwasher 4000 series aqua surge with speed clean. The small spray arm on the ceiling of the washer came off. I found it sitting on top of some cups in the top basket. There is a...
The top arm snaps into place. Simply unscrew the retaining clip from the ceiling of the washer. Inside of there, you will find a small white plastic clip. Make sure the two prongs are pointed down and poking out through the hole in the bottom of the larger grey clip that you just unscrewed. Then press the prongs on the white clip into the hole on the arm and snap it back together. Then you can screw the assembly back into the ceiling of the washer.
If this problem persists, you will likely need to replace the white plastic clip. (which is where I am at right now with my washer).
Dec 01, 2010 | Frigidaire PLD4555RFC Dishwasher
I have a Frigidaire commercial freezer model # FFU1464DW2. It was bought brand new, used for a few months, then unplugged and sat. I want to sell it but i don't the resale value. Do you have any...
if the unit still works and looks new i would say knock off about 100 dollars of the price you paid for it and this should be good enough for some who wants it or at least sell it for 200 to 300 dollars
Jan 22, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Jacques Lemans 5015B model, drop my watch on floor yesterday, 2
You need a hand alignment at the very least. Sounds like your sweep arm is getting stuck on other objects in the face.
Sep 26, 2009 | Jacques Lemans Watches
Our icemaker is stuck on crushed (Frigidaire).
It's probably the solenoid which changes the action in the ice dispenser. It's bad or there is a bad switch, etc.
If you don't have appliance repair experience, probably ought to call service.
More hellp?, let me know.
May 09, 2009 | Traulsen Commercial 2 Door Cooler /...
Mountain of ice in walk-in(floor), around the parts(ceiling)
No choice but to move your food to a secondary unit & defrost the walk-in. If you go chipping around your condenser you risk more damage. Hopefully you have seperate breakers for you walk-in vs other cold storage areas.
Apr 22, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Can't Put Belt On
You have to remove the front of the dryer to
access the drum. First unplug the dryer.There are screws at the bottom of the front to remove the lower section. Once you remove that you can get to the screws for the door section. The front of the drum rides on the inside of the front panel so when you remove the panel the drum will drop down. Try to keep the drum in place with something to hold it up. Remove the old belt and place the new belt around the drum. Slid the belt back to where the belt used to ride and then loop the belt around the motor and the tension wheel. Make sure the tension wheel is tightening the belt. Hold up the drum and put the front panel back on. You may need a helper to hold things while you do this. Rotate the drum by hand and make sure it moves smoothly. Plug it back in and give it a try. I hope this helps. Any questions feel free to ask. Please rate me so I know if I'm Helping. Thanks.
Dec 30, 2008 | Frigidaire FEQ1442ES Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
