Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Have BOSCH diswasher model SHE44C06UC/22 and it continues to cycle but never drys
  • kaywhy Aug 29, 2010
    SO WHAT TEMP SHOULD THE WATER BE
  • Bosch Master
  • 43,501 Answers
That could either be a problem with the control module or the heating element...my first guess would be the heating element... as it is looking to sense it working and does not...
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 29, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Aug 30, 2010
    Water when washing should be 140+ maybe all the way up to 160 or so...
Bosch diswasher,model Sms68m02AU trips circuit breaker
rcd units trip from the milliamps that are in a short
it trips the rcd to prevent electrocution and acts in nano seconds besides being a circuit breaker for excessive current
the trip can be from moisture allowing a current leakage to ground or some other simple operation
I suggest that you get in a qualified electrician / bosch service technician to find the reason for the problem rcd
Sep 15, 2016 | Bosch Dishwashers
Bosch SHE44C06UC/22 won't fill with water even though you hear water running somewhere.
Check to make sure there is no residual water underneath the unit, they have a flood sensor and if it is picking up water in the motor area it won;t run.
Jan 24, 2014 | Dishwashers
I have a Bosch SHE4AM15UC diswasher. The rinse agent comes out at the gasget. The rinse agent light does not come on anymore windicating it needs more agent.
I would have to say the sensor may be fouled up and need to be cleaned if you are concerned about the light. If the rinse agent is coming out of the gasket I would look for small cracks around the dispenser, then the door panel may need to be replaced.
Sep 06, 2012 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
How do you run the diagnostic on a bosch dishwasher model # SHE44C06Uc/22. it counts down to one on the timer and runs forever. can't find it model # diagnostics anywhere. thanks
Resoldering the relay, regardless of how proficient one is at soldering, will not be a long term solution. The melted/burned solder joint is a secondary result of the initial failure, which is the relay itself. There is a solution that is more permanent and less costly than replacing the control with a new one.
Do a search for Bosch 266746 control and you will locate someone who has studied the problem and found a safe, long term solution.
Nov 16, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch she44c06 will not stop draining, what is key selection to reset and continue using machine
on mine I have to push 2 buttons at the same time for 3 seconds to cancel cycle.Check your manual under cancel cycle. However you may have a problem discussed at this link:
http://www.squidoo.com/Bosch_Dishwasher_Drainage_Problem_Fixes
Oct 31, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch SHX46A02Uc/21
it is likely a control module issue. I will take mine apart this weekend to verify what others have said: solder joint on circuitboard burns out from possible overheating, and DW doesnt go into rinse cycle. Try rinse and hold cycle to see if it stops on its own. mine does, but the other cycles which require the rinse to go to 156 degrees do not; the continue to run until I cancel and drain.
Feb 01, 2009 | Dishwashers
Bosch diswasher
check heater element for open circuit, if the dishwasher fills and empties and wooshes the water round, there is little else to go wrong
Oct 05, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch diswasher
If it is new- then the fishy smell is almost certainly the motor and circuit boards 'cooking' in- most motorized electrical devices have an initial pong. However if it persists after say 10/15 cycles begin to suspect an incipient fault.
May 14, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
274 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
