Question about Car Audio & Video
Need a wiring diagram draw nup for me
Hello Hello I need a wiring diagram drawn up for me if that’s possible, ill try to explain what I need.
First I have two triggering devices (Open close switch n/o) that need to be triggered remotely by one switch via wires not remote control.
But I want it to have a number of options.
1/ when the remote button is pressed the triggers need to open and close automatically one at a time.
2/ have a variable speed rate. From 2 per second to 15 per second.(approx) For all these options
3/ have a switch to change from simultaneous to alternate for every option
4/ change the automatic setting to trigger only once when remote is pressed.
Ideally I wish to fit all this in as smaller box as possible, there is no load on the trigger switch as it a micro switch currently being used. The system runs off a 9v battery
Thanks
Dean Warnock
Work shop Manager
Outram Garage
Ps I have choosen this product only as i do not wist to disclose what im making as its a tool I wish to pattent it if it works
  • Anonymous May 09, 2008
    where do i hook the wires from the cd player to the amp
  • Louie  Role
    Louie Role May 11, 2010
    Based on your post, a couple of ideas:
    1. the "Open close switch n/o" would have to be replaced by relays;
    2. depending on the load, power source, the relay could also be a triac or an SCR;
    3. if a relay would be used, then the 9 volts would probably have to be 12VDC.;
    4. if the engaging of the switch/relay is time controlled as well, you would need an electronic timer. If the timing is not critical, then a timer IC would do, if on the other hand timing is critical then it has to be crystal based;
    5. if the engaging of the switch/relay is dependent on the status/condition of the other and "simultaneous to alternate for every option", then a logic circuit has to be custom designed. You would need to establish the conditions in a "Truth Table".
    6. if a logic circuit with variable time based would be used, then provisions for a +5VDC is also required;
    7. if the conditions are presets and would not change, it might be more appropriate to use a PLC.
    Sorry but I have to ask: If you are intending to patent this, is it not but fair that whoever designs the electrical/electronics share in the design rights? (rather than ask for it as a free help)
    Brigadier General:
  • 6,966 Answers
Thank you for using FixYa and good luck with your project.
Posted on May 12, 2008
Na I want to patent the final product as this bit is only a small part of it.
Cheers for your help
Posted on May 09, 2008
My car radio and AC fan are not working in toyota Avanza 2015, it started by fan running as soon the car is on immediately. May be is the fuse problem or what..
Hello Nceba Maqaqa,
We do not have a Toyota Avanza in the USA Market...
Looks to be a van/wagon style perhaps or Venza
would be close... (??).
In any case: IF...
the mechanical job (crank-shaft job) is related
to this incident... you NEED to be looking inside your engine compartment... for physical damage to your wiring...
POSSIBLY Your "MECHANIC" snagged a couple
of wires when pulling the engine ...
(and HOPEFULLY did a shabby job of repairing them..
(the shabbier the BETTER... EASY to find)).
A real "MECHANIC" would welcome the opportunity
to make sure you are a COMPLETELY SATISFIED
customer... Give that a try first.
ASK if there were any wiring "incidents" during the procedure
ELSE
You are left with tracing and toning out the wires: power distribution & possible FAN & RADIO cross-overs.
Tone tracing wires is a relatively EASY PROCEDURE...
(I use Klein tools - don't have time to mess with toys).
You do need wiring schematics... and you do need to
OPEN the circuit you are tracing (open = pull the fuse)...
to isolate the wire... (recommend FACTORY drawing).
2015 American market Toyota Venza schematic
drawings... are available FREE on BBB Industries site
(below)... REGISTRATION is required.
On the TYPICAL "entertainment" drawings found
for your year there are at least 3 and often 4 POWER
fuse circuits needed for your RADIO to function.
One (often two BATTERY sources, an accessory battery & an ignition battery.
I see no OPPORTUNITY for an EASY explanation
of your fan operating & radio NOT working... but
my first BACK trace would be of the FAN POWER... as
that logically would explain the fan symptom you described.
Hope this helps
BBB Industries Premium Alternators Starters Power Steering Products
Extech TG20 Wire Tracer and Tone Generator Amazon com
Bussman fuse test & kit ($14.26 + FREE USA ship'n)
Amazon com Bussmann NO 43 ATM Mini Blade Fuse Tester Puller Kit Automotive
Carnac the Magnificent
Jun 08, 2017 | Toyota Cars & Trucks
Wiring diagram 2012 nissan versa sv
Alldatadiy .com. There are hundreds of diagrams for this car. Buy the program.
Jul 02, 2016 | Nissan Cars & Trucks
Why do my 2002 ford crown Victoria fuel pump shut off and comes back on
Could be dirty filter or pump about to fail. High amp draw can cause relays to overheat. Might try testing amps drawn while running, but likely you will need to replace pump and possibly relay also.
Feb 10, 2015 | 2002 Ford Crown Victoria
Necesito diagrama de cadena del tiempo de un suzuki aerio 2007 motor 2.3
this is a 100% USA English site, use translator, to post please,
here ill use Google translate for you, crossing fingers
Need diagram of a chain of time aerio 2007 suzuki engine 2.3
the book is online, for 4 dollars. USD , USA cars. we dont help or fix non usa cars.
it too is in English,
https://suzukipitstopplus.com/Products/1010-2007-aerio-service-manual.aspx
or
alldata.com (google that) for $15 the whole deal. log in and read.
now ill post the 1 or 3 drawing on topic.
we dont have large drawings here, so it will STINK.
25387164-e2r4w0fsyddzp0xv13arb1nl-3-0.jpg overall, above
then small chain, details
then guide drawing and all those words telling how to do it and not frack up.
Jan 28, 2015 | Suzuki Cars & Trucks
1984 ford f250 inline 6 Have replaced battery, alternator, starter solenoid, starter, and voltage regulater, along with battery cables. Battery is being drained when the truck sits more than 15 hours....
If you don't have any idea what to check next, maybe now is the time to take the vehicle to an auto electric repair shop that specializes in tracing wires. You may have a short to ground somewhere, or an accessory, that is drawing current when the vehicle is off, to the point of making the battery go dead if sitting more than 15 hours.
One check that you could do yourself, with the proper tool, is to check the amps being drawn when the car is off. If the amps drawn is above .2 Amps, then it's too high of a draw. The symptoms you describe sound like it is more like 2 or 3 (or more) Amps being drawn on the battery.
Try to remove fuses to various accessories to see if that reduces the amp draw on the amp meter.
I would use an Amp meter that is inductive and has a claw that opens and surrounds the positive or negative battery cable and measures current without having to actually remove any cables from the battery, and connect in between the battery terminal and the battery cable.
Let's say, for instance, that it was an accessory like a radio that was drawing an inordinant amount of electrical current. Then, if you removed the radio fuse, the draw should go from 2 or 3 amps down to below 0.2 amps. So, that's what I would do to try to narrow down the possibilities.
Good luck on this repair.
Jan 21, 2011 | 1984 Ford F 250
Graphing inverse equations
In parametric mode you are not drawing one function, but two functions X1(T) and Y1(T). If you use the DrawInv( command either on X1(T) or Y1(T) you get a syntax error.
However if you are drawing functions in Funct mode you can draw the inverse of the function that has been graphed.
Here is how you do it.
[2nd][Draw][8: DrawInv] [ENTER]
The command appears on the home screen, and you need to tell it the function it will act on. To do so press
[VARS] --> Y-Vars [1:Function]
and select the function you want, say Y1, if Y1 has already been defined.
DrawInv Y1 [ENTER]
Both Y1 and its inverse will be drawn.
Hope it helps.
Sep 02, 2009 | Texas Instruments TI-84 Plus Silver...
3 LIGHTS TO 3-GANG SWITCH
Feb 21, 2009 | Cooper Industries Cooper Wiring 2158V 3...
1996 gsxr 750 im trying to rebuildit how do i check to see if my wireing is correct and how to i test
hello mate tried uploading image but wouldnt have it so type in bike chat into google click on workshop click on manuals click on wiring diagrams your bike comes under the 1993-1995 your bike is the same wirng sorry its not in color but the wiring codes are all at the bottom good luck if you have problems leave your email add in the comment and ill send you wiring diagram ok
Jan 31, 2009 | 1996 Suzuki GSX-R 750 T
WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Oct 16, 2008 | Kenmore 64732 Electric Dryer
Car Audio & Video Logo
128 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
