Question about Hoover F7220900 SteamVac V2 Upright Vacuum
I lost the detergent container on my Hoover Model F7220-900. Its a small plastic bottle that sits on the back of the clean water tank. I called the help desk and they told me that they no longer make that part so I have to pay $55 to replace the whole tank which will come with a detertent container built in. The whole carpet cleaner was only worth about $225 new. I don't feel I should have to pay $55 for a part I don't need but the machine is worthless without it. Any good ideas to solve this problem?
Agent Don
  • 310 Answers
SOURCE: We used our Hoover SteamVac
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=639624
Generic problem for all Vacuums
Posted by medglen on Jun 01, 2008
We used our Hoover SteamVac F6207-900 for the first time today and it did not suction at all. Please help. It emptied all of the clean water/detergent as I cleaned the carpet, but no dirty water came up into the empty tank.
Thanks!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you may have a clog or a vacuum leak in the vacuum line. The suction should be able to pickup the water into the holding tank for you. So please feel free to contact your local vacuum dealer or you can use a wire coat hanger to try to unclog the vacuum but if that fails contact the factory or your local vac dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 02, 2008
  • 17 Answers
SOURCE: HOOVER F7430-900 STEAM VAC
I recommend to use the same detergent that came with the machine. Some detergents can cause problems such as damaging seals and causing build up. Hope this helps, post back.
Posted on Jun 27, 2008
reddevil6
  • 1673 Answers
SOURCE: Hoover Steam Vac Spin Scrub
Remove the brush block, is the shaft on it or broken off. Replace the block if broken off. Turn unit over, with brush block removed, handle tilted back, is the square hole turning, if not then the turbine is bad, this is what turns the brushes.
Posted on Sep 01, 2008
  • 294 Answers
SOURCE: height adjustment on Hoover Windtunnel u5755-900 no longer works
On this model it is only a single slide adjustment lever. have you trie to tilt the vac backwards (lifting the wieght off the front wheels) and then slide the adjustment lever?
If there is a mechanical issue with it. take the bottom plate and roller out, and then the 2 small screws which hold the cover on underneath. you should be able to see the problem from there
Posted on Jan 18, 2009
  • 51 Answers
SOURCE: hoover carpet cleaner F7458-900 issue
The pointed valve that is in the tank may need replacing. The two valves are a set. I just ordered some from www.usavacuum.com
Posted on Sep 06, 2009
Hoover floor mate h3000 will not suction water from floor when cleaning
Your collection canister may not be positioned tight enough in its place ment site. Tip machine back using foot pedal (as if you were going tio start using machine to clean) Insert collection canister (bottom container, then insert top canister with solution. The two canisters must be flush with machine side seams and must sit in position tightly. This is sometimes very tricky and may take a little elbow grease to make it click into place. Hope this helps
Jul 08, 2015 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover F7425-900 SteamVac V2
http://www.hoover.com/pdfs/manuals/F7452900.pdf Heres a link to the manual if you dont have one, Ive emailed them and they gave me the same solutions that are on page 17. ? Make sure tank is securely locked in position ? Clean water tank or detergent container empty ? Refill container according to instructions for surface being cleaned ? Recovery tank lid not on correctly ? Make sure lid is firmly in place ? Valve cap clogged ? Remove and clean valve cap (see following instructions) 1. Remove clean water tank. 2. Turn valve cap (A) counterclockwise and remove. Soak valve cap in warm water for at least 15 minutes. Wipe cap dry. 3. Align slots (B) on cap with tabs (C) in opening. Turn cap clockwise to tighten.
Sep 17, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Water leaks out of the clean water tank valve
This was a very common problem with the earlier tanks on this model. The newer tanks can be identified as a single clear plastic molding, and the older, defective tanks had a separate soap container glued to them, usually blue or green in color. If you look carefully, I think you will find the leak is due to cracks in the plastic beneath the valve. Purchasing a new tank should solve the problem. ( Part # 42272104 ). It is probably worth a call to Hoover, to try to get a new tank at no charge.
Apr 19, 2011 | Hoover F7431-900 SteamVac Vacuum
There are two containers, where do I put the water and solution
The upper tank holds the cleaning solution. Mix 5 oz. of Hoover detergent to 1 gal. of hot water. The line on the tank indicates 1 gallon.
Apr 10, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Top water bottle want stay in
The black base that the bottle sits in is broke. You can use hot glue to replace the bottle. I would suggest buying a new tank from hoover because the style of tank you have has a known design flaw. They have redesigned the tank to be stronger. You could trying calling the Hoover company and complaining. I know that has worked in the past.
Apr 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover V2 SteamVac
Under the detergent side, there is a metering plate,(located on the machine) which can be removed. ensure that this is installed. have you verified whether the machine will dispense detergent only without any water in the water tank?
Jan 03, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
I own a Hoover Steam Vac V2 deep cleaner with Auto Rinse feature. The Model Number is not available ex: was on the bottom of the machine and the sticker is completely worn off the machine. I am having a...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=641300
Posted by w_brennan on Jun 02, 2008
I own a Hoover Steam Vac V2 deep cleaner with Auto Rinse feature. The Model Number is not available ex: was on the bottom of the machine and the sticker is completely worn off the machine. I am having a problem with the bottle you fill with detergent ex: this bottle is separate from the main clean water tank. THE PROBLEM: The little plastic part that goes in the bottom of the bottle has an "O" ring ex: cone shaped with a spring.....it keeps falling out. Can you supply a part number for this component? The bottle has a number ex:36778-002. Thanks...Linda (504) 888-2120.
E-mail address: w_brennan@bellsouth.net
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hover SteamVac V2 with Auto Rinse feature. I would suggest because the model 3 and the serial 3 have been worn of the machine to contact your local vac dealer in your area and or the Hoover Factory Service or the Hoover Website for the Factory Model #, but the part that you are requesting is not very expensive and can be replaced. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jun 02, 2008 | Vacuums
Hoover carpet steam clear
Is this a V2? The F5914-900 just has a solution tank. The V2 has a small soap tan attached to he water tank. If you have a V2, the seal or plunger at the bottom may be bad and can be replaced. The reservior asm. that the tank sits on may be bad. You may have a problem with the tank in which case it will have to be replaced.
May 08, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Have a Hoover Steamvac Model #F7426-900 - Series AA12.0 On the bottom of the clean water tank and the detergent container, the gaskets leak and water constantly drips from the tank. How do you repair...
Inspect under the seals to see if the tank hasn't cracked, which is usually the problem. If it is a new seal that is needed, part #43513026. If a new tank is needed, part #42272104.
Apr 24, 2008 | Vacuums
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
133 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
