Question about Sharp XR-32X Projector
When I try to turn on the lamp I get one beep and then two beeps and the lamp doesn't light
  • rts1121 Aug 29, 2010
    Thanks fo the get back. I don't have a manual. Yes I get a beeping light on the top of the set.and no lamp.
  • 666 Answers
This mean your main board has fried or several circuits are no longer functioning it will require replacement parts and labor to fix if under warranty I would say purchase another one
hope this helps
Robb
Posted on Aug 30, 2010
    Genius:
  • 1,478 Answers
Make sure the outlet in which the projector is connected has power, and that the projection lamp is good. Some projectors also have "indicator" or "status" LED lights on the control panel. If this light is on or flashing please refer to your owner's manual for solutions and explanations.
Note, Average lamp hours range from 1,500 to 2,000 hours although new lamp technology promises 6,000 hours. The lamp life of different projectors varies. Most projectors use a lamp hour counter to track the number of hours of lamp use. Check the projector's on-screen menu to determine the number of lamp hours used. After so many hours of use, the lamp life LED on the projector illuminates or the projector simply will not ignite the lamp, indicating that the lamp should be replaced.
Take care.
Posted on Aug 29, 2010
Samsung HLS5687.Replaced lamp,turned on TV the light goes on turns off. The projector boards continues to beep then tv powers off. Color wheel does spin. Not sure what the beeping is.
Did you check the ballast for the lamp? It provides the high voltage/energy to excite the lamp (no filament) into operation. If it does not work properly neither will the bulb.
Great set - I have the 5685.
Mar 06, 2016 | Samsung HLS5687WX/XAA
The status light is on our NEC MT850 and the bulb looks fine. What other problems could it be?
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
turn on the projector ,at the same time ,if you can hear a continuous beep beep sound (the ballast igniting the lamp)
means the lamp may be fault,and other parts is working well
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 19, 2012 | NEC MT850, MT1050, MT1055, MT1056...
Sanyo split 4 beeps and doesn't work
OPERATION lamp blinks and airconditioner does not operate.
Trouble in system.
Contact service center.
Aug 06, 2012 | Televison & Video
How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
May 12, 2012 | HP Pavilion ze2000 Notebook
CND UV box beeps and turns off
the bulb times needs to be reset. push and hold the reset button until it beeps 3 times and displays 100 and you should be good to go.
Nov 22, 2011 | Creative Nail Design Pro Dial U.v Lamp Cnd...
Amber light on the motherboard is on i hear several beeps and it doesn't boot up
Usually beeps emitting from the computer indicate a memory error.. Try to re-seat the memory modules. If that doesn't work then try removing 1 module at a time to see if you have a bad memory stick.
Aug 21, 2011 | Dell OptiPlex GX520 PC Desktop
VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 06, 2010 | ViewSonic VA1703wb Monitor
No picture, no sound?!?!
This could be a number of things. Your lamp could be bad or it needs to be reseated to the ballast. The lamp is trying to light and it will make the ballast flicker (that is the clicking sound) or your ballast is bad and it needs replaced (it will flicker and click too). Or your color wheel is broken and it will make a clicking sound when turning. If the color wheel is not spinning or broken it will not light the lamp. No lamp no picture.
Dec 12, 2007 | Samsung PCN5425R 54" Rear Projection...
Sharp XR-32X Projector Logo
106 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
