Question about Princeton Digital VL2018W Monitor
Princeton Monitor not receiving signal from signal cable.
  • 11,361 Answers
First we need to make sure it is not the signal cable or the PC's Video card problem, you need to try it on another PC, we do not want to take the monitor apart unless we have to.
This model has problem with DC filter caps as shown in my picture here which you may want to check them out in the futre also.
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 29, 2010
  • ksuemiller Aug 29, 2010
    Thank you. Will try monitor on another pc and see what happens first. Thanks a bunch
  • cash4jenn Aug 31, 2010
    I'm having the same problem with the same monitor. If I unplug it from the power source wait 5 minutes, plut it back in, the screen comes up. If I shut the monitor off, then turn it back on later, it flickers and turns black. It does the same on my other computer. When it is plug in and turn it on, it says No Signal, Check Signal Cable. It has done this since I bought it, but always turns on. Help.
Computer monitor not receiving a signal
Check whether the monitor is turn on and if the same issue check the monitor by connecting with other PC.
Regards
Jyothish
Feb 24, 2013 | Computers & Internet
Princeton Digital (VL1916) 19" LCD
Try to decrease your screen resolution. see attach picture: or restart your computer then if windows xp booth press F8 then choose ENABLE VGA MODE. press enter. jimmyverdade_4.jpgjimmyverdade_5.jpgjimmyverdade_6.jpg
May 27, 2011 | Princeton Digital VL1916 19" LCD Monitor
Princeton vl 1918 monitor on screen it says check cable no signal. how do you obtain signal?
You need to verify to find out if it is the monitor is bad or the PC is not sending the video signal to the monitor. Try another monitor with the PC, if you still have the problem then you need to fix the PC, if it works OK then it is the monitor problem.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 08, 2010 | Princeton Digital VL1919 19" Monitor
Screen monitor self diagnostics show
that means no incoming signal, but some problem i encountered related in vga cable and lost connection on ckt board. as long that the cpu is working and the monitor show (no signal) focus trouble shooting on that parts. replace cable if possible( same port configuration)
Apr 20, 2010 | Princeton Digital VL2018W Monitor
"no signal"
"no signal" means that the monitor is not receiving a video signal from your computer or laptop. This is normal if the compouter is OFF and the monitor is ON. Is the computer still on and connected to the monitor?
Mar 27, 2010 | Princeton Digital VL1514 Monitor
Princeton VL2018W stopped working. Getting popup "no signal- self diagnostics- check signal cable" When hook up to pc the initial screen showed computer specs than started the popup. Tried changes power...
1. Take this Monitor and attach it to another working computer to see if it works
2. If it works, it means the video card on your pc needs to be replaced
Mar 16, 2010 | Princeton Digital VL2018W Monitor
The monitor shuts off. Turning the power off
the monitor is going into power saving mode ... it can happen if it is not receiving any signal from the pc ( pc is not running or booted properly, bad video cable connection monitor to pc) or the pc is itself in suspend/standby mode.
Aug 08, 2009 | Princeton Digital Computers & Internet
Princeton Monitor is "out of range"
The monitor is not getting a video signal. This is probably an issue with your computer. It could be a memory, hard drive or motherboard issue.
Make sure you are getting power to the pc (fans running, hard drive spinning...etc). Then check your memory. Try switching memory slots, or try different memory.
Turn on computer and see if you hear any bios beeps.
Try a different hard drive if you have one.
Good luck,
Hank
Aug 04, 2009 | Princeton Digital VL1916 19" LCD Monitor
Princeton Digital VL1716 Monitor "No Signal Message"
Roxio Changed Your display settings on the dual display.
Right Click on desktop>goto Prefences>
You should see both monitors indentfy the one and change it to a lower resolution.
Apr 28, 2009 | Princeton Digital VL1716 17" LCD Monitor
No signal on startup
if monitor is gave no siganl .Firstaly Check monitor Signal Cable For connected of ur system vga port. if Siganal cable is connected ur pc then Check ur System IF system is gave the Display anthore monitor . Then Proble is ur monitor signal Cable .So Plz Change Monitor Signale Cable.
Dec 29, 2007 | Princeton Digital VL2018W Monitor
Princeton Digital VL2018W Monitor Logo
82 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
William Ward
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
