Question about Fisher and Paykel Health & Beauty
Fischer & paykel hc254jhu cpap unit isn't working. the code E49 is showing on display. what does that mean?
SOURCE: Error code F32 for fisher
Got the same error here, called Fisher Paykel and the said it's an error related to the water line. They recommended running 3 L of water and see if code disappeared. If not, call service, they gave me a local company. Error code has disappeared, for now.
Posted on Nov 09, 2008
RescueTech
  • 145 Answers
SOURCE: problems with fischer paykel self cleaning oven
Hi and welcome to FixYA.com!
Here are links to the two most popular Fisher Paykel Wall Ovens:
OD/OS301:
http://www.fisherpaykelparts.net/partmanuals/545619C_Aerotech_UGM_USw1.pdf
OD/OS302:
http://fisherpaykelparts.net/partmanuals/599194C_Aerotech_ugm_USw.pdf
If neither od these is your model, let me know which one you have and I will locate a use and care guide for you.
Hope this helps and Happy Holidays from the FixYa crew!
Posted on Dec 15, 2008
desayres
  • 10 Answers
Sounds like Clothes Washing Machine To Me!!--Methinks You have "Posted Incorrectly"--Stay Upright --Des.
Posted on Jan 17, 2009
  • 713 Answers
SOURCE: Fisher & Paykel Washing Machine WL80T65CW1 Fault 9
sounds like a size error . when you changed the display did you size your machine to the new display module?did you get the re-size set of instructions with the new display board? ring up where you brought the display from and i"m sure they can help. if not reply back and i will guide you thru it.
Posted on May 27, 2010
Jahn27
  • 1554 Answers
SOURCE: Hi! we have a GW609au
It's error code 37 and it means pump blocked error. The machine does not spin because water is not drained prior to the spin cycle. Either the drain hose is clogged or kinked, the diverter valve has failed, or the pump itself is restricted or not working at all. Check to make sure that the drain hose is clear then disconnect power and lay the machine on its front on a cushioned surface to access the drain pump and the diverter valve. Remove the pump's inlet and outlet hoses then check and clear them from any debris that may prevent water from draining out. Check the impeller for any damage or restriction. Make sure the impeller is not frozen or blocked.
Also check the diverter valve for the same condition as the pump described above. The diverter valve is where the drain pump and the recirculation pump inlet hoses are attached from. Make sure the diveter valve is in the drain position while the drain pump is working. Replace the drain pump and/or the diverter valve if deemed necessary.
Posted on Dec 29, 2010
Testimonial: "Thanks Jahn27. We did all that and found 2 hair pins and a wad of lint restricting the pump. All good now. Saved us $??? Thanks heaps!"
Showing Error Code E1
If you wish to get some details; check the site linked here. Pull up older posts.
http://homenol.blogspot.com/
Aug 31, 2016 | Fisher Paykel Fisher & Paykel SleepStyle...
Can anyone tell me the age of my Fisher & Paykel refrigerator? (model E442B, sn: MYQ784484)
Possibly upto 7 years old but call Fischer & Paykel with the serial number and they should be able to give you the day month and year of production, the only number i can find for customer services is : 08000 886 605
Sep 20, 2014 | Refrigerators
I only have a hose attached to the cold water tap and inlet valve of my Fischer & Paykel top loader washing machine as I only do cold washes, this hadn't been a problem until recently, when th
it could be that the water level got to high and came out of the valve you could try putting a cap on the valve and see if that works and if it does not then it might be a bigger issue.
Dec 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
My dishwasher is not working and has an error code of F2. How can I fix this problem?
F2 means that your rotor isn't moving properly and will need to be replace or it needs to be removed and check for something blocking it. Below is a link to a video that will show you how to take your dishwasher apart and repair your Fisher and Paykel unit.
Good luck.
May 05, 2011 | Fisher and Paykel Dishwashers
Fischer Paykel fridge freezes then stops
sounds more like a defrost problem, check your defrost timer, defrost heaters.
Feb 21, 2009 | Amana ABB1927DE Bottom Freezer...
Problems with fischer paykel self cleaning oven
Dec 15, 2008 | 2006 Fischer MRX 650
OD/OS301:
OD/OS302:
Dec 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Health & Beauty Logo
216 people viewed this question
Top Fisher and Paykel Health & Beauty Experts
Robin Hill
Robin Hill
jeff tilburn
jeff tilburn
Are you a Fisher and Paykel Health and Beauty Expert? Answer questions, earn points and help others
