Question about MagLite Mag Instrument Mag Lite 2 "D" Cell Flashlight Black # S2D016
We have a maglite that holds 5 or 6 D batteries and some liquid in rubber has now caused the on/off switch to no longer work. Is there something that can be done?
    Guru:
  • 479 Answers
You could leave the torch in the cupboard near the hot water tank for a few days and the switch might dry out .The contacts have probably corroded at this stage though
Posted on Sep 04, 2010
Where can i buy parts for mag light 3d size flashlight , the parts that i need is a switch and rubber cap .... thanks
Hi and welcome to FixYa, I am Kelly. Please see this link for the parts you need:
http://www.maglite.com/anatomy_spare_D.asp
Rubber cap is item 7 The barrell with switch is item 6. (mouse over the item numbers and the part number is on the right. If you order the barrell with switch you probably do not need the rubber cap.
The phone number contact page is here:
http://www.maglite.com/spareparts.asp
They may be able to tell you a retailer that sells spares close to you. For sure they can get you the parts you need.
Thanks for choosing FixYa,
Kelly
Dec 11, 2010 | MagLite Mag-Lite& Flashlight
MAGLITE D- Cell : Push button off/on switch is stuck in the on(down) position and won't release to the up(off) position. Any suggestions? Thx!
Try gently pulling up the rubber cover for the switch. use a butter knife to gently pull it free. Then you should be able to see the switch button itself. Try a *small* drop of a plastic safe lubricant. Or try a small spray of silicone lubricant. This should free it up. If not Mag Light has replacements, and they do offer a lifetime warranty. Here are the switch replacement instructions
Nov 27, 2010 | Hand Tools
Can't open the flash light to change the batteries? Does the bottom open up? Do the batteries get replaced from the top by removing the bulb first?
The back, tail cap, should be unscrewed from the maglite to replace the batteries. It can be pretty hard to open as they are generally not opened very often and there's a rubber seal to keep it water-proof. You could try using a pliers or vice but be careful not to squeeze it out of shape.
There's also a possibility that if the batteries are in it a long time that they have leaked and the leaked chemicals have sealed it. If this is the case you may be able to get the maglite replaced depending on what brand of batteries were in it. Maglite have an agreement with the makers of Duracell, Ever-Ready and Ray-O-Vac to replace the Maglite if one of their batteries leak in it.
Details are on the bottom of page at http://www.maglite.com/faq_details.asp?faqProd=C
Nov 01, 2010 | MagLite 4 Cell C Flashlight Black
No light
Ok... You've put batteries in it, right? And they're fresh? Good.
The end cap is screwed in nice and firm? Finger tight is right.
You can see a globe in the lens? There's usually a replacement in the end-cap on these maglites.
The big black rubber button near the light end of the torch is an on/off switch. Press it! (Or if you want to test it, drive over it with a truck like they do in the commercials!)
Very occasionally the switch fails but they're tough and well designed. It is not a common problem.
Jul 28, 2010 | MagLite Mag-Lite& Largehead Flashlight
Cycling through the modes with a Mini-Maglite
I've had the same problem, even took a new Mini Mag back to the store, only to get another one doing the same thing.....finally realized that the batteries that came with the flashlight were not good. Fresh new batteries solves the problem.
Apr 08, 2010 | MagLite Mag-Lite& Flashlight
2AA LED Maglite not working
The Led are most likely not burned out they last 10,000 hours or more. Sounds more like defect.
Sep 23, 2009 | MagLite Camping, Backpacking & Hiking
Don't know how to replace AA batteries in Maglite AA.
they either unscrew from the back end or they unscrew from around the thick light end , then just pop in some new batteries making sure that they are pointed in the same direction
Jun 02, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
I have replaced batteries and bulb in maglite flashlight. Problem is still the same. The light comes on but immediately dims to very poor light. Can't get at switch ---it's a maglite.
Sounds like a bad switch, but if you live in the US, you have a limited lifetime warranty on your light.
Contact Maglite at: http://www.maglite.com/feedback.asp
You should also consider installing a LED bulb in your light. If you use it much at all, it will quickly pay for itself in battery life and the light is a lot whiter.
May 13, 2009 | MagLite Mag-Lite& Flashlight
Mini Maglite not working
You could have dirty contacts if the batteries were in for a long time and you never used it. The contacts are: (1) the tip of the spring and (2) where the positive end of the battery touches way inside the flashlight. You can try and clean them with alcohol. If you think it might be the bulb, try the spare. There is a spare bulb under the spring you see at the base of the flashlight when you install the batteries, you have to pull the spring out and then snap it back in after you get the bulb out. And yes, positive end goes in first in the Maglite. Hope this helps.
Jan 07, 2009 | MagLite Camping, Backpacking & Hiking
MagLite Mag Instrument  Mag Lite 2 "D" Cell Flashlight Black # S2D016 Logo
69 people viewed this question
Top MagLite Electrical Supplies Experts
Karl Kittsteiner
Judi McInnes
Level 1 Expert
lakeareaserv
Are you a MagLite Electrical Supply Expert? Answer questions, earn points and help others
