Question about Samsung MW630WA 600 Watts Microwave Oven
The microwave stop working today, will not come on
Door of sharp microwave will not open
Take it back, if this becomes a problem then you will have a harder time getting customer satisfaction.
Jul 09, 2012 | Sharp R-930AK Convection/Microwave Oven
I have a sharp microwave sometimes it works for 10 or 20 seconds and then stops with error ee2, other times it works fine. Today it did the same but stopped with error ee1!
This sounds like a keypad problem, sometimes a short developes in the keypad controller causing all kinds of intermittent problems, on the back is the microprocessor circuit board which controls vital areas of the microwave oven. The cost to repair will be high and consideration should given to looking at a replacement.
Feb 17, 2011 | Microwave Ovens
My microwave keeps shutting off when i am cooking but then it turns back on? sometimes it turns back on right away and sometimes takes up to a half hours?? can you help?
I was having the same problem today. Our microwave dish was off the track and would not turn, so it stopped the energy to the microwave. Now, it works great! Good Luck.
Jan 30, 2011 | Whirlpool Microwave Ovens
My Microwave stopped heating today but everything else works fine. Any idea what the problem might be? Thanks.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jan 09, 2011 | Kenmore 62702 Microwave Oven
My Panasonic Inverter S333 just suddenly stopped working. I get a "refer to manual" message. Manual has no help to offer. Even the "signal bell" sounds a little off. Up until today, it was working just...
My Panasonic Inverter S333 just suddenly stopped working April 30 after I used it for only two years, no showing in panel. It will run only when I open the door, it is strange.
Apr 19, 2010 | Panasonic NN-T694SF Microwave Oven
Microwave stopped working last night
If the microwave worked for a little while after you plugged it in again then it is just overheating.It is usually just dust/dirt collecting on the vents.the fan,and the magnetron(the thing the fan blows on).If cleaning all these doesn't solve the problem you may have a bad high temp overload sensor,and need to replace it.(this sensor is usually mounted directly on the top of the magnetron.The magnetron is the part that actually puts out the microwave signal.I've never seen a reset button.The high temp sensors reset themselves automatically.
Jun 23, 2009 | Panasonic NN-T654SF Microwave Oven
Microwave stopping working
check the fuse on the microwave. if its busted, something shorted out in the oven that tripps off your breaker. it could be your inverter.
Feb 19, 2008 | Microwave Ovens
Samsung MW630WA 600 Watts Microwave Oven Logo
29 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
