Question about HP Pavilion dv6000z Notebook
Loose key hp dv6000
The zero key has popped up and is acting like a teeter tottle from left to right. it still functions but not sure how to get it back down normal like the other keys?
  • Spime May 08, 2008
    How difficult is it replacing the key after i order it and get it? Or is there a guide to do it?
  • Anonymous Aug 14, 2008
    The "L" key on my HP Pavilion Laptop has popped up and rocks left and right and will not go back down when I press on it - I've tried rocking it will pressing - nothing works.
    Genius:
  • 1,027 Answers
If the plastic scissor is broken or the end clips are broken you will have to replace it LINK
hp uses 4 or 5 different type of plastic key holder so if you need one be sure you order the right one
Posted on May 08, 2008
  • Mark Williams
    Mark Williams May 08, 2008
    There is a replacement guide that comes with it. Sometimes you can look under the key and see if the tab slots are intact if they are you should be able to depress the key and wiggle it to lock it in.
    On my dell i have a X scissor plastic piece a small gray cup and the key. place the cup in the center, the plastic scissor has 2 tabs on top and a clip on the bottom, clip the scissor in place then press the top into the tabs, place the key on top and gently press and it locks in place.
    each keyboard is only a little different, they use 4-5 types as standard.
    You could just order a whole new keyboard then have replacement keys on hand.
  • 502 Answers
The keys are available on ebay individually. Look at the key mechanism closely, sometimes it is not broken, just snapped apart. If you're brave you can take the cap off of a working key to see how it's supposed to be installed. You can repair it yourself or have a third party laptop repair service do it for you. You can try to replace the entire part yourself, it is available on any auction website. Also, there is a Laptop repair guide that teaches you how to install the keyboard urself.
Posted on Jul 24, 2010
Http://cgi.ebay.com/HP-Pavilion-DV2000-DV6000-DV9000-series-Keyboard-key_W0QQitemZ250365847744QQihZ015QQcategoryZ31568QQcmdZViewItem
Posted on Feb 23, 2009
Filter keys?
dv6000 or is it Paviliion G6-a1nnnnn
eg: G6-1a52nr or other numbers? w7 here.
what OS? XP? or w7?
pav G6.
what are you doing? tell what you are doing exactly
where are you in windows. (unstated OS )
ok you meant MS-WORD, processor.
the word Word' has 2 meanings. one is in english
the the other is slang for MS-WORD (processing)
microsoft office word, (mines version 2007 , what is yours.)
sound to me like corrupted OS .
best if a microsoft product of any kind acts odd
ask on a real Microsoft forum (google that find that?)
word processing is one of the most complex of major apps.
endless facts there.
there are 15 G6 series PC.as seen here, which one is yours>?
https://support.hp.com/us-en/products/laptops/pavilion-notebooks
is it still original or upgraded, in any way, we cant guess that ever.
same OS, same MS_WORD?
my guess is system has a virus.
did you create a new file and tell it what type you want first.
that is first, or MS-word will fail.
study filter types (google it)
Sep 16, 2017 | HP Laptop Keyboard for HP Pavilion DV6000...
Tip
How to Disassemble an HP Pavilion DV6000
The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the Pavilion DV6000 is a good all-around value for most users. Taking apart an HP Pavilion DV6000 is not an easy chore and if you plan to use the laptop again, it is important you know what you are doing or you have a large appetite for risk. If the above doesn’t describe you, consider taking the HP in for professional repair or upgrade. Otherwise, follow the steps below to disassemble the HP Pavilion DV6000.
18385245_1.jpg?w=200 1、Prepare a clear workstation. Turn off the laptop and remove all power components including the cord and the battery. (Turn the laptop over and you will find the tab to push and pop out the dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250 2、Turn the HP Pavilion dv6000 upside down and unscrew all the screws you find. Try to keep them separate by size so you can put them back in the same spot when and if you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the rectangular compartments. The memory is located in the central compartment (remove by spreading latches and pulling up), and in most HP models the hard drive is located to one side.
4、Remove the optical CD/DVD drive by pulling on the drive face to the left and out of the laptop. Remove the WiFi card by disconnecting the gold connectors on the antenna and pulling the card from its slot.
5、Turn the hp dv6000 back over and remove the keyboard and power panel/media touch pad. Carefully pry the power panel up with a piece of hard plastic near the power button on the left side. Be careful when pulling not to yank the power connection as you might accidentally rip out a wire. Pull back the keyboard to reveal the connections. Disconnect the connections by carefully pulling on the tabs with your thumb and forefinger. If they are tight, wiggle them back and forth while pulling on them to loosen them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling gently on them, wiggling them if they are stuck. Gently pull up from the right side of the motherboard and remove. The HP laptop is now fully disassembled.
on Jan 21, 2010 | Computers & Internet
I am having trouble figuring out how to enter problems to find logarithmic functions
Let me give you a general recipe to familiarize yourself with any calculator, if you are averse to reading the manuals.
Most function will work in one of two ways.
1st way
Enter the number, then press the key,; the result is displayed.immediately.
Second way
Press the function key ( a left parenthesis may be displayed) enter the number (close the right parenthesis if there was a left one) press the = or EXE or ENTER keys.
Try the two ways described above to calculate the following values. The answers are given. Here log is he decimal logarithm and ln is the natural logarithm.
log(1)=0
ln(1)=0
ln(2)=0.693147181
log(2)=0.301029996
ln(100)=4.605170186
log(10)=1 (= number of zeros after the 1)
log(100)=2. (= number of zeros after the 1)
log(1000)=3 (number of zeros after the 1)
log(10000)=4 (number of zeros after the 1)
Aug 17, 2011 | Texas Instruments TI-30 XIIS Calculator
Laptop HP Pavillion dv6647nr (a dv6000 family) F11 key Problem
Did you format the drive or just repair it"??
Access BIOS and have a look in case that key stroke is disabled in there.
Sounds like the CD has overwritten that part of the HP registry....they have their own.
Mar 12, 2010 | Computers & Internet
How do you find the zeros of a function on a TInspire
Turn calculator. Use arrow to highlight the 2:Graph and Geometry application. Enter your function at the bottom of the screen. Use TAB to move focus on command line.
Press [ENTER] to graph.
While graph is drawn, press [menu] key. Select [5:Trace][1:Graph Trace] . An X appears on the graph screen. Use arrow to move cursor towards one of the zeros you see. At some point the calculator will pop up the label [zero]
Press [ENTER]
Use arrows to move the cursor near a second zero. When [zero] pop up text appears, press [ENTER]
The value of the secon zero is also displayed.
You can also the nSolve command
Use the nSolve( function available in main calculator application. Here some exemples of syntax
On the second command line, the small vertical segment after the right parenthesis is accessed by the key sequence [CTRL] [infinity, beta, degree] key, the one under [left arrow/clear].
Hope it helps.
Oct 26, 2009 | Texas Instruments TI-Nspire Graphic...
Side key functions on HP#5189 keyboard
Left side keys - moon-hibernating mode, club+hp - takes you to hp internet club (lots of resources,free classes, etc on hp), globe spinning-takes you to internet-yourhomepage, envelope-takes you to windows email, magnifying glass- takes you to windows live search, ?-takes you to help
right side keys- arrowup1-opens disk drive, arrow up 2-opens 2nd disk drive if you have two, solid dot-opens dvd suite, arrows left-rewind, arrow right -fast forward slow, 2 arrows right-fast forward fast, and solid square -pause these are all media functions
I discovered all of this by taking a chance and pushing the key to see what happened. really wish they put a manual, or screen showing functions for the keyboard. hope this helps someone else!
Mar 26, 2009 | HP Computers & Internet
My laptop sound not working
Try reinstalling the sound drivers to make sure you don't have a software problem. Download the drivers from HP here. Getting them from the manufacturer is a good idea since you'll get the latest version. (The link is to the page for the basic dv6000. Your model may have a different number but the whole series should use the same audio drivers.)
After installing the drivers make sure you have the sound settings properly adjusted in Control Panel, and that the volume is turned up. This should solve your troubles. If you still have no sound but all is right with Windows, you'll need to have your hardware checked out. The on-board audio may have failed, or it could be as simple as a connector that has come loose on the main board.
Mar 24, 2009 | HP Pavilion dv6000z Notebook
My hp pavilion dv6000 laptop does not turn on, the blue buttons light up, but the screen stays off
Try it without the rechargable battery connected sometimes the battery shorts and causes problems.
Do you have FN[function] keys at the left side. touch FN key with something else and see if screen comes back.Sometimes you can turn off the screen to send it to the back connected monitor.Connect (extra if you have) an external monitor to the back (vga) connector.If that shows, then you have to ""flutzz" with the FN(function) & F1-F12 keys
Nov 28, 2008 | Computers & Internet
My ibm thinkpad key ""Q" came loose
You have to work with it and don't be scared of it. If you easily take another one off you will see how it goes on. It is a puzzle. You might want to take it to a shop because you can't replace single key's. Not that I have found anyway.
May 08, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
2,116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
