Question about Everex StepNote XT5000T Notebook
Everex laptop is running but screen stays black
  • Everex Master
  • 1,606 Answers
This sounds like the back light could be out or the display is switched to external.
Heres how to check. Boot it up and let it run. While it is doing this look from the side of the screen. Sort of off centre. You may have to get close and may even have to use a flashlight. What you should see is a ghost image of your normal desktop. When you move your mouse you should be able to see the movement. Might be hard to see but you should see it move. If you see the movement that indicates the backlight or it power supply is out. If you don' tthen it can be the video or just set or forced to an external monitor.
So to check for that you need to use a monitor. The laptop will have a place to plug in the monitor. Plug it in, turn it on. Now turn on the laptop. If you see the screen normally then the problem is back lighting. If you still don't see anything then the problem is the video section. If you press the FN key (lower left) and the function key with the monitor usually F9. This should cycle it through the outputs ie normal screen, external monitor or both.
This is repairable but you really have to watch the cost these days. A back light can be replaced for under $50 in parts plus labour. The video section would require a new main board which will be about $150 and up.If you have warrenty both the backlight and mainboard are covered under that. If you don't then you need to get a couple of estimates for the repair. Compare that to the replacement cost and use that to decide if its worth fixing.
Posted on Aug 29, 2010
My Everex 3500 motor is running but the screen is black
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Aug 27, 2010 | Everex NM3500 Laptop
I have a everex stepnote XT5000T and the it turns on but the screen stays black.what could be the problem?
It may be that the display output toggle has been set to "external monitor" ... try Fn+F3 .... to toggle it from your screen, to external monitor to both ... and see if the screen works.
If this doesn't work, connect an external monitor to your computer, and toggle it, to see if the monitor displays the screen contents. If this works, then it's possible that your LCD screen is faulty ("fried")
Aug 11, 2010 | Everex StepNote XT5000T Notebook
I have a everex laptop and its running vista premuim...the fan comes on and it seems to load but nothing shows on the screen any suggestions on how to fix this problem
Depending on your laptop some have a small platic pin that stick up just in front of the screen, if this pin is not coming up your screen will stay off.
Mar 25, 2010 | Everex StepNote VA4300M Notebook PC
THE SCREEN IS BLACK ALL THE LITES COME ON THE
man just go to google . man how dum are you
Dec 21, 2009 | Everex StepNote NC1500 Notebook
Stuck on startup screen
Sounds like you are not getting past the BIOS
You need to boot from a floppy or cdrom/dvd that has some type of startup files.look for fdisk run it but be careful
what you are looking for is a partition that is marked as innactive.
maqke sure that it is marked as active.
Nov 15, 2009 | Everex StepNote NC1500 Notebook
Problem with an Everex
this is hang-up on your Everex, check how many beeps you hear and we will identify the problem on your Everex 1500. See to it that your hear the Beeps on your Stepnote, good luck!
Jul 22, 2009 | Everex StepNote NC1500 Notebook
My Everex XT5000T laptop only turns on after I let it heat up
they are correct its the motherboard and the system nees to be reurned to the factory ASAP, as you have a serious and possible dangerous situation and it needs immed. attention, or the computer replaced
Jun 21, 2009 | Everex StepNote XT5000T Notebook
My everex stepnote wont turn on, fan runs but it wont boot
I have a Everex StepNote Laptop VA4101M. Model Number VA250W. I can turn the power on the laptop but the screen is black. I have already try taking the battery out and the power cord out and nothing.WHAT DO I DO?!?
Mar 19, 2009 | Everex StepNote VA4103M Notebook
Laptop is running but screen constant black
it seems the sudden loss of power fried the screen...or it could be the video card that might have downed.  always try to use keyboard combos like crtrl+alt+del or alt F4 before resorting to such violent measures :(
Feb 04, 2009 | Everex StepNote VA4300M Notebook PC
Everex StepNote XT5000T Notebook Logo
113 people viewed this question
Top Everex Computers & Internet Experts
k24674
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
