Question about MidiLand IRS 858 Consumer Headphones
Midiland ir-hf1 right speaker broken
I recently bought the these wireless headphones but the right speaker doesn't work at all. Sounds good through the left but absolutely no sound through the right speaker. I've tried numerous devices with the same effect, any help please?
  • 1,512 Answers
Hi evtan
The only thing I can suggest you do is to swap the right and left inputs to the transmitter base over whilst wearing the headphones. If the fault transfers to the other channel, then you have a faulty interconnect lead that needs to be replaced. If it stays with the same channel, then the headphones or the base staion will be faulty. Best bet then is to return it to the place you purchased it from and request a replacement unit,. Thanks for using FixYa....a FixYa rating is a great reward from you to me for helping out :) Cheers
regards
robotek
Posted on May 08, 2008
Toshiiba satellite p205 Internal Harmon Kardon Speakers Do Not Work
Most likely its a nardware problem.
If Device manager shows the audio driver is working and enabled and when you plug an headphone into the headphone/audio out and you only get sound from the right headphone then the audio amp chip is faulty.
If the headphone sounds OK then the easiest solution is to connect a set of powered speakers to your laptop.
May 03, 2012 | Harman Kardon HK695 Computer Speakers
I just bought a microsoft wireless keyboard 3000 and inserted the USB into the hub. But now when I play a youtube video the sound comes from the laptop instead of the external speakers like it used to. ...
First, you can try unplugging and replugging the speakers. If that doesn't work, right-click on the speaker icon in the taskbar (lower right-hand corner) and select "Playback Devices". When the window opens, you should see your internal and external speakers listed. (Maybe Internal Speakers and "Headphones") Just right-click the option that says corresponds to your speakers and select "Set as Default Device". Close your web browser and re-open it. This should fix the problem.
Aug 27, 2011 | Computers & Internet
Only right side works
hello rrwunsch!
please check wiring first to find out if headphones broken or it is a connectivity problem. for that, if you connect with rca plugs - change right to left and vice versa. if still left headphone has no sound so the speaker is blown. hope it is only wiring problem.
regards
Feb 20, 2011 | Sony (MDRRF925RK) Consumer Wireless...
Logitech cordless headphones model #A-00006 has problem with left headphone cutting out. Please help.
Hi All,
I have a
are Logitech Model # A-00006 and the wireless antenna unit is Model # A-00007.
Recently I am noticing that what is normally a stereo experience of listening while I am in on a Beacon conference call is becoming a mono experience (only the right earphone). Not sure if this is because of bandwidth fluctuations or a problem with beacon or a problem with my headset, but it doesn't seem to do it when I'm in a 1:1 call.
Odd thing is I don't hear it cutting out when I am making a direct call - only when it's a multiparty Conf call.
Thank you inadvance,
B1L
Jan 08, 2011 | Logitech (980174) Headset
I simply have no sound. my speakers are hooked up but it says there not detected
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 09, 2010 | MidiLand MLi 170 Computer Speakers
I have this set of speakers hooked to a Dell 3000 running under Windows XP Pro. I recently had to change offices and when I hooked up the speakers, the subwoofer wouldn't work. I've tried reinstalling the...
Please check the cable using a multimeter. Check if the cable is broken.
Just by shifting the system, I fear if you could have an issue like this. Also check the Subwoofer box if its working or not. Good Luck.
Jun 04, 2010 | MidiLand MLi SW190 Computer Speakers
Problem with Motorola S9 Wireless Headset.
Check:
  • Your sound card's Mixer Panel to ensure you have left/right adjusted properly
  • Your sound card may have a speaker-test function, my RealTek tests with "Left" "Right" speech
  • Check your connectors (head phone & speakers) to ensure they are compatible with your sound card
  • Make sure the plug is FULLY inserted in the speaker card socket, it doesn't take much NOT to be fully inserted
dont forget to rate me.......
good luck......
Apr 15, 2010 | Motorola Mobility S9 Headphones
Trouble w ir headphones
check the batteries in the headphones
Jan 22, 2010 | Audiovox Car Audio & Video
Headphone jack loose?broken?
You need a new one not worth fixing
how old is it when did it stop working
if you just bought it then
you need to return it and have it exchanged
there obviuosly is a defect.
Feb 12, 2009 | Dell Inspiron 6000 Notebook
MidiLand IRS 858 Consumer Headphones Logo
156 people viewed this question
Top MidiLand Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MidiLand Audio Player and Recorder Expert? Answer questions, earn points and help others
