Question about Nintendo NES Console
I ripped my nes open and cleaned the prongs with Q-TIP and some water.. i made sure the Q-tip wasnt to wet just damp.. and i ran it across the prongs.. and dried it off theni put everything back together and i turned my nes back on and it still blinks red and the screen blinks red.. i have it plugged into my vcr with an rca cable i have yellow in yellow and red in red... i dont have an af switch if that has anything to do with it.. all it shows is a blinking screen.. i blew into the system and the game and moved the game around alittle to see if it would work.. none of the prongs are missing or bent.. they are all fine
  • Nintendo Master
  • 424 Answers
Well I think that the lockout chip is broken so there are videos on youtube that show you on how to remove the NES lockout chip.
Posted on May 17, 2012
2 Suggested Answers
SOURCE: DS nintendo lite
open it up and push the prongs back through- it happened with mine, but the screws have quite pain in the arse ends, so you will have to find the correct screwdriver. it looks kinda like this=
I
Posted on Aug 28, 2008
I am facing a problem in HP laserjet P1102. printer shows "Install Black Cartridge" when I have tried my best to resolve the issue. I am a technician and many printers come for this problem to me. I
#1-Remove the ink cartridge and use a q-tip and alcohol to clean the metallic portion of the cartridge. Gently slide the q-tip back and forth across the ink distribution openings, ink should cover the q-tip. dab dry with a paper towel and replace into the printer. #2-With the ink cartridge removed...Check the prongs on your printer that press against your ink cartridge when in place for connectivity. If covered with dry ink, use said q-tip and alcohol to clean. #3-replace the ink cartridge with a new one. Be careful, and gentle with your q-tip, rub easy, and let dry before proceeding. Be safe...and have plenty of paper towels on hand.....wear rubber gloves.....
Feb 17, 2015 | HP LaserJet Pro P1102
Tip
How to get those old NES,SNES and N64 games to work properly - NEVER BLOW INTO...
A very common myth i have seen over the years even since 1992 to present day has been to blow into the cartridge will get the games to work when you insert it into the Nintendo 64 even for all the other systems that used cartridges that preceded it (NES SNES etc) I don't know how many times i have seen this ritual before. That is not how you should clean your old game system cartridges, this is what you should do to clean your electronic devices:
1.Now, what you must do instead is to get some isopropyl 70% alcohol and a q-tip.
2.Pour some of the alcohol onto the q-tip so that it is soaked.Only a bit is necessary.
3. Now clean the copper metal contacts in cartridge, with the wet q-tip clean any dirt and grime that you can find on the these contacts (the metal areas on the part that looks like a computer chip). Keep on scrubbing away at the contact till it looks clean, repeat if necessary and apply as much force to scrub away at the dirt. Make sure it looks shiny.
http://static.howstuffworks.com/gif/n64-cartridge.jpg <<it is not necessary to open
4. Insert your game cartridge and enjoy!
5. You might want to try the same method of using alcohol and a q-tip for cleaning the contacts of the actual system.
If you were one of those who blew into the cartridge, all you were doing were spreading germs and bacteria and possible food onto the cartridge making it worse acting as an insulator and impurities. Electronic devices do not like impurities and must be kept clean of dirt, especially the contacts so that they can conduct electricity properly.
on Dec 22, 2007 | Nintendo 64 Console
Want to know how to manually clean printer head
You can, but the objective is to soften the dried ink, that blocks the tiny ports.
In my estimate the alcohol will dry too fast.
Printer UNPLUGGED from power, and you may wish to don some gloves.
(Dishwashing gloves?)
The ink likes to go everywhere.
Remove the ink cartridge/s.
As you can see, the copper metal strip area, on the ink cartridge; has TINY little holes in it.
I use a clean soft static free cloth, and soak the end I'm going to use; in as hot a water as I can stand.
Then reduce the water in the cloth, (Squeeze), so the wet area, is just damp.
Wipe across the copper area, and it's tiny ports.
Wipe across once, then find a clean area on the cloth; and do so again.
Keep wiping until cloth comes away clean.
I also do the same on the metal area, of the printer; that the metal area of the ink cartridge touches.
There are matching tiny port holes there also.
Keep wiping, adjusting for a clean area after each wipe, until cloth comes away clean.
I then follow with a can of compressed air for computers, and make sure the areas are DRY.
Q-tips, and Isopropyl alcohol, (Rubbing alcohol), sounds more intelligent, to me.
However the amount used may fill up a small bag, IMHO.
I know what you're thinking. Is this guy N-uts?
Water and Electricity do not mix!
(Actually they do. Water is an excellent conductor)
I watch to make sure there are no drips from the cloth, when using it. Have a dry cloth handy for the other hand, if they do.
I also make SURE the areas are DRY, before reinstalling ink cartridges.
I find VERY warm water helps break down the dried ink.
Always willing to learn something new, however.
For additional questions please post back in a Comment.
Regards,
joecoolvette
Mar 18, 2013 | E-Machines eMachines Desktop PC
How to clean a remote circuit board. Looks like some rust has got onto the board. The remote was working up until a few days ago. If the remote had got wet it would have been some time ago.
Okay well since it is already dry, you should clean off the "rust" or any film left from the dried water. I like to use a Q-Tip and a small amount of rubbing alcohol (isopropyl). I wet the Q-Tip with the rubbing alcohol and slowly and gently clean any film or anything left over from the water. Use only a small amount of alcohol on the tip, and you may need more than 1 q-tip depending on size. Then let the remote dry completely before you go ahead and try it. The alcohol should dry rather quickly but make sure it is dry. Now hopefully the remote hasn't been burnt out from the water, it will work fine.
Good luck!! EJ
Feb 10, 2010 | Televison & Video
How do i clean the laser
This laser is super sensitive. Do not touch it with your finger or anything that could potentially damage it or leave a mark.
1) Canned Air. Get a can with a mini straw and blow it out pretty good. If it's giving you problems, blow out the ventallation ports as well.
2) Disc Cleaner. Best buy makes a disc cleaner that looks like a DVD. This is not the best way to go but it might work. Ask an employee what they recommend using.
3) Q-tip. If you have already opened it; or are past waranty and desperate to get it cleaned, open up the console and with a Q-tip dipped in a very small amount of rubbing alcohol (make sure it's not wet, just damp) SUPER LIGHTLY give the laser one good rub.
Please make sure you're giving it a good means of ventallation and ensure to never put it on carpet.
Good luck and please rate my solution accordingly.
V/r,
Don
Jan 25, 2010 | Sony Playstation 3 (PS3) Console
I was wiping my keyboard and closed my laptop and when I opened back up about an hour later it looks like a faint water stain going right across the top can only notice it if you really look but really...
use a clean white cloth and plain water. open the laptop and dampen the cloth. do not soak it. clean the lcd. do not use windex or any other cleaner use only water and make sure it is only damp and not wet.
Nov 10, 2009 | Computers & Internet
I have an old nintendo and when i put a game in it just blinks an
Make sure the contacts of your games are clean, you can do this by using a damp q-tip with water and cleaning the contacts on both sides of the cartridge, then take another dry q-tip and clean off the contacts, then stick the game in and see if it works you may have to try different ways of putting in the game to see if it responds.
If you can't and multiple games are having the same issue, then your going to have to replace the connector in the NES. You can get them off of ebay like this one:
http://cgi.ebay.com/NEW-NINTENDO-NES-72-PIN-CONNECTOR-6-MONTH-GUARANTEE_W0QQitemZ370244485864QQcmdZViewItemQQptZVideo_Games_Accessories?hash=item56344a82e8&_trksid=p4295.c0.m299
That one costs around $7.00 and includes shipping.
Here is a guide that explains how to replace the connector in your NES:
http://www.nintendorepairshop.com/nes_repairguide.htm
Aug 30, 2009 | Nintendo NES Console
Oringal NES
It's still not getting full contact with the game cartridge. Try cleaning the contacts on the games with a q-tip and rubbing alcohol.
Dec 01, 2007 | Nintendo NES Console
Nintendo NES Console Logo
74 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
