Question about Microsoft Works 8.0 for PC
Upgrading microsoft works 4.0
I want to keep all of my existing works 4.0 files and upgrade to microsoft works 8.0 or 9.0. Will either one of these allow me to upgrade my 4.0?
  • shcc Sep 23, 2008
    My boss uses works 4.0 EVERYTHING he does is in works. I have been able to convert it but now can not! If he upgrades to Works 8.0 he will he still be able to change millions of files AND will it still be works? I think in 2000 works word processing files automaticallly became word files and he didn't like that so he just went back to the older works 4.0. Thanks
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
In order to use Works 4.0 files, they must first be converted using software that includes a text converter - Works 8.0 and several versions of Word include this. You can use 8.0, or use 8.0 to convert to that format, and then they would be usable in 9.0 as well. If you desire further detail, see here.
If you need further help, please post back. Otherwise, thanks for rating FixYa!
Posted on May 08, 2008
  • Cheryl Whalen May 11, 2008
    hkyer:
    Was there something else you needed help with? This response, I think, addressed the exact solution to the problem you posted. If there is something else in this regard that isn't clear or you need further guidance, I would be happy to assist. If not, could you please rate FixYa (excellent) rather than Helpful (average)? Thanks for your consideration.
Tip
How to fix a hanged/frozen/non responsive Pan Digital Novel E-Reader
If your Pan Digital Novel Reader... does not respond or hangs, it means the unit/device has frozen. This is a software/OS (operating system) problem.
Usually, resetting should do the fix. To reset, push the hole at the back of the unit with paperclip and the unit will reset. But if you have reset the unit by pushing the small hole at the back with paperclip (which means reset) and that seems not to solve the problem, then it means the operating system of the unit is corrupt. This is a software problem and to fix this problem, you need to install the firmware for your unit.
Firmware helps to remove the corrupt software and re-install a new one. Your unit will be as new once this is done.
Upgrade via PC
This option is for Windows PC only at this time.
With this method, you must connect your pandigital novel to a PC and then run a downloader program which automatically downloads the firmware to your device.
1. On your computer, go to www.pandigital.net/downloads.
2. Choose the "Upgrade with Your PC" option.
3. When asked to Save or Run, select Run.
4. Follow the prompts in the Upgrader window to download the firmware into your device.
5. After the download is complete, turn your device off.
6. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
7. Your device is upgraded and restarts automatically.
8. In the Language setup screen, tap Save with English selected (other languages will be available in future firmware upgrades).
9. In the Date/Time screen, if necessary, tap in the Time Zone, Date, and Time fields to set the correct time for your location. IMPORTANT: In order to connect with your Barnes & Noble online account, the Date and Time must be set correctly according to your location.
10. Tap Save.
11. The HOME screen is displayed.
Re-Upgrade
If you have previously performed a firmware upgrade to your device using one of the above methods, we recommend that you move the existing upgrade file into a different folder before performing another upgrade, which allows you to revert back to the existing version if desired.
1. Connect the device to your computer.
2. In a Windows Explorer or Finder window, create a new folder titled Firmware, and then copy the existing upgrade file into the Firmware folder. (The upgrade file is named similar to SYY_MM_DDK_PD_INX7E_ENG_6410POP.)
3. Perform the new upgrade using one of the methods above.
Revert back to Previous Version
2. In a Windows Explorer or Finder window, delete the upgrade file from the root, and then copy the upgrade file from the Firmware folder back into the root of the device.
3. Turn your device off.
4. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
5. Your device is upgraded again and restarts automatically.
6. Follow the prompts to re-set your language and date and time.
I hope you found the above helpful.
Regards.
on Sep 27, 2011 | Tablets & eReaders
I am loading up a new Dell computer with Windows 7 Pro, I have the upgrade for Office 2007 ( that I purchased) but only have upgrades since office 95. How can I load Office 2007 upgrade on this new...
Is the disk-drive from the old computer attached as a "slave" disk-drive on the new computer?
If so, then the "upgrade" utility should find the "qualifying" files, and allow the "upgrade" to proceed.
Is Office 95 listed as a "qualifying" product for the Office 2007 upgrade?
If so, then insert the CD-ROM for Office 95 when running the Office 2007 installer.
Or, insert the CD-ROM for the Office 2000/XP/2003 upgrade when requested.
Dec 01, 2010 | Microsoft Office Professional 2007 Upgrade...
I'm trying to upgrade from 64-bit Vista to 64 bit Windows 7. When I run the installation disk, I'm getting the following error message, which appears to be contradictory in my opinion:...
I have seen this type of problem before, the only real way around it is to install a fresh copy of windows 7 not to upgrade, you will receive a message that asks you if you want to keep the previous windows in a folder called old windows, from there you will be able to access all your old files and programs, be aware though some programs may not work on windows 7, and you may need to have updated drivers for the systems peripherals. So when you run the windows 7 disk choose clean install and go from there. i hope this helps
Feb 04, 2010 | Microsoft Computers & Internet
Same as above really
I have fixed my problem. I realised that the Microsoft Access Database DSN did not include the *.accdb driver. I deleted the existing DSN and created a new one. This allowed me to select the ODBC driver that worked for both file types.
I cameto realise that I was only having this problem on machines that have been upgraded to excel 2007 and not on machines with full virgin installations. On install both try to create the appropriate DSN but one with the same name already exists on the machines being upgraded and the creation fails.
I hope this helps others.
Jul 18, 2009 | Microsoft Excel for PC
Route 66 Mobile 8 Windows Mobile - software update creates error
To upgrade, use the website version of Route 66 Sync rather than the version on the disk or the upgrade file from the website, both of which do not work. The website version works in conjunction with Microsoft ActiveSync.
Dec 27, 2008 | Route 66 ROUTE EUROPE 2004 (601184407502)...
Problem upgrading to ver 2.04
You need to go into safe mode and on 'command prompt' need to copy and paste the file from Lifecam2.04.exe to the windows C:\Users\Avi\AppData\Local\Temp\LifeCamSetup\setupstb.exe' or go into windows and copy the file as above
Jan 16, 2018 | Microsoft LifeCam VX-6000 Webcam
Unable to install ms office 2007, upgrading from Office 2003
please first uninstall all the existing versions of MS Office. Then try to clean temporary files, cache and registry using tools like cCleaner (freely availavle), then install MS Office.
if you want to install only MS Office 2007, no need to install MS office 2003 and upgrade. directly install MS Office 2007.
If you want to keep both, pleas install MS office 2003 first, then MS office 2007, please dont uograde it, rather select Keep both version.
Please make sure that you have admin permission before doing all this and your system is free from any virus.
Thanks
Zulfikar Ali
May 20, 2008 | Microsoft Office Professional 2007 Full...
XP upgrade to Vista install error code 0x800705AA
This error is something to do with the "Product Key" I think I have Googled this error and this is what shows up the most? I googled ... vista install error code 0x800705AA .... so perhaps ya can follow up in this vien... Good Luck
Feb 08, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Works 8.0 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
