Question about Mtd Garden
I have an MTD Yard-Man PowerMore self-propelled lawn mower, model # 12A-44MC055. The drive belt broke and was chewed up by the blade, so I bought a new drive belt and put it on. But now, the handle that engages the drive belt dangles loosely off the mower handle. It used to be taut, but now it's loose enough to swing back and forth. It still engages the drive belt when pulled, but it's obviously not acting the way it should. Any thoughts as to how I can restore the tension in the cable / handle to make it work correctly again? Thanks!
4 Suggested Answers
SOURCE: Yard Machines - Won't shift into gear
The problem most likely is the shaft on which the interlock slides back and forth on inside the transmission. The yardmachines have a continous spinning shaft which ends in a bevel gear. The is an interlock plate which is connected to the Forward Reverse shift lever, this plate slides back and forth and either engages the forward gear or the backward gear. This shaft is most likely galled up, preventing everything from sliding the way it needs to. This is not a difficult thing to fix if you are somewhat mechanical. Disassemble the transmission and check if everything slides
Posted on Jun 01, 2009
buffalonyman
  • 1865 Answers
SOURCE: Change Oil
All lawn mower engines have a drain plug for draining the oil. Look for a square nut on the side of the engine
Posted on Jun 12, 2009
  • 6468 Answers
SOURCE: I have an MTD Yardman 12a-44mc055. Suddenly, the rpm of the blade decreased, even at full throttle. It has very little power. Does not cut grass and the self propel mechanism does not work. Any though
is the blade loose?is the pulley key way sheared as well as the key on the flywheel
Posted on May 14, 2012
What spark plug does yard man 12a-556q13 take?
I don't find that model number in my book.. what kind of engine does it have.
Aug 08, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Yardman
under the deck ether running backwards are forwards depending what drive your useing but all under deck you might have to dig thrugh the grass but its there unless it broke then look for the pully on the blade shaft
May 27, 2013 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Drive belt size mtd 21 " 6.75hp mower
If you post the model number of the machine, I can probably find the belt dimensions..
Tim
Oct 16, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Have a Yard Man 21"
Hi ccidb11..
I would recommend that you spray the shaft and flywheel with penetrating oil, or WD40.
Then tap the crankshaft, with the nut loosed so it acts as a flat surface to tap on with a hammer.
What you need to do is put your puller on the flywheel and tighten it down really tight, then with a hammer hit the end of the puller (where the wrench goes) a couple of times, then retighten your puller again, and hit the end again.
You will do this until the flywheel will pop off...
Please take time to rate me
Jun 27, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Self propelled feature stopped functining. I previously replaced the wheels after the gears had worn down. Now I can't get any response to engaging the self-propelled cable.
Have you checked the drive belt? There should be a belt running from the main shaft (above blade) out to the wheel drive. You didn't list model number but I'm assuming it's front wheel drive. There should be a cover over this belt so it might be hard to see from underneath. Also there should be a cover on top going to the drive transmission. If the belt is OK, check to be sure lever is moving the transmission lever.
Oct 30, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
MTD front wheel drive self-propelled 21". Self-propelled does not work. Can it be fixed?
Yes it can be fixed. Try some basics first.
1) Check under belt drive cover for excess debris
2) Belt and Idler pulley condition
3) Control cable operation
a) rusted, frozen, broken, disconnected
Dec 03, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
SELF PROPEL FAILURE ON YARD MAN MOWER
hello
check the drive cable as not come adrift or broken
you can usually adjust the tension on top of the drive cable
also check drive belt is on the two pulleys
hope this helps
Mar 13, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
245 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
