Kodak Projector 760H. Carousel won't move forward or reverse. With remote or pressing the actual buttons.
    President:
  • 412 Answers
Chances are that your projector has a broken solenoid "link". This "Link" connects the slide change solenoid and the slide change mechanism. Over time this part becomes brittle & cracks, rendering the slide change non-functional. A pretty easy fix for an authorized repair dealer.
Posted on Nov 03, 2010
Select projector class room
The problem you describe is a timing issue. Because the 760H is so old (about 45 years old), parts availability may be slim to none.... You may be dollars ahead to buy a working projector off the internet.... Try: www.vinevalleyimaging.com
Good Luck !! Jim
Mar 26, 2014 | Kodak Office Equipment & Supplies
Kodak carousel 760h projector
Dirt or dust accumulation can retard the gear mechanism. If you get Canned Air at WalMart, blow out all open areas and see if you can dislodge the material collected inside.
Mar 25, 2014 | Office Equipment & Supplies
Yes, there is a fix. It's a pretty straight-forward adjustment. You can go to this web page: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-locale=en_US&pq-path=6499
The Service Manual there will detail the the adjustment.
Good Luck !! Jim
Mar 11, 2014 | Office Equipment & Supplies
My Kodak Carousel 760H projector will not advance or reverse using either the remote or using the "advance" or "reverse" buttons on the unit. I am able to turn the tray manually. Is...
The problem is a plastic "link" that connects a solenoid to the advance mechanism. It gets brittle with age & cracks, yeilding the problem you have. You need to have the "link" replaced.
Oct 27, 2010 | Kodak Office Equipment & Supplies
I have a very old Kodak 760H slide projector. I
Based on your description & what I know about those projectors, I suspect the solenoid "link" has broken. The "link" connects the cycle solenoid with the slide change mechanism. Over time, this plastic "link" gets hard, brittle and cracks, rendering slide change non-functional. The good news is there are still parts around to fix your projector & get another 20 years out of it. You should contact a factory-trained repair dealer to affect the repairs. Good Luck !!
Jan 18, 2010 | Kodak Office Equipment & Supplies
My Kodak 760H Carousel projector does not advance
do you hear any sounds when you press the button? if not, the button may be malfunctioning. if it doesn't make a sound or movement in reverse either, there is a bad connection between the controls and the solenoids. if it does try to advance and not move the carousel, it's a mechanical problem in the mechanism. usually due to the grease getting sticky from heat and age. take it in for a good cleaning and an adjustment. there are a few cams in there that wear out after a while, too.
Oct 21, 2009 | Kodak Office Equipment & Supplies
Bought a 760H to show some old sllides, but the tray does not advance. Is this something that can be fixed? Everything else works fine.
In a word - yes. Most anything on a Kodak Slide Projector can be fixed.
If your Carousel 760H will cycle in Reverse but not Forward, then it's an adjustment of the cycle solenoid. If the projector will not cycle slide forward ort reverse, then it is probably the cycle solenoid "Link". The "Link" connects the plunger of the cycle solenoid to the slide change mechanism. The good news: parts are available (www.micro-tools.com). You will need to seek out a factory-trained dealer to make either one of these repairs for you.
Aug 15, 2009 | Kodak Office Equipment & Supplies
Kodak Carousel Projector 760 H, Carousel will not move
Given the age of your Carousel 760H, the most likely cause is a broken "Link". The "Link" connects the cycle solenoid plunger and the slide change mechanism. The "Link" is made of plastic and gets brittle & cracks over time, rendering slide change non-functional. Parts are still available (www.micro-tools.com), but this is an involved repair is best left to a factory trained technician with a service manual.
Apr 05, 2009 | Office Equipment & Supplies
Kodak Carousel 760H wont advance or reverse
What's happened is what happens to all that style eventually. There is a small nylon link that has aged and broken in the heart of the mechanism. A very skilled amateur can repair this but it may take a professional. If you are in the USA, start at http://www.kodakparts.com/Pre_1981.html or http://www.fargo-ent.com/kodak.html if you want to try it yourself. It's the same company, basically. If youa re in Canada, go to Doug Banks http://www.photographicrepairs.com/
Dec 04, 2008 | Office Equipment & Supplies
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
Nov 23, 2008 | Kodak Carousel 4600 Slide Projector
517 people viewed this question
k24674
jasbo
jasbo
