Question about Black & Decker Pivot Plus Cordless Drill/Screwdriver
I KEEP MY PIVOT ON CHARGE BUT IT DOES NOT WORK
  • 90 Answers
If you know how to use a volt ohm meter you can check your charger, battery and switch.
Posted on Sep 01, 2010
My 2011 Ford Expedition Max has the right passenger wiper that does not work. The driver side one does. What would the problem be with the wiper that isn't working
  • The wipers move because of pivot linkage arms in the cowling that keep the wipers in the right position. It sounds like the pivot bushing has broken on the one side. This is not an easy fix in most cases. These pivot arms can be really hard to get to.
May 16, 2014 | Cars & Trucks
Pivot bolt
aligne preicesly and check if the bolt thread is smooth or rough
Mar 30, 2014 | Huffy Green Machine
How long do I need to charge my PD400LG pivot-driver for after using ?
if there is nothing showing up a full charge sign,
and it is not more than 18 volts just let it charge arround 30 to 60 min
Jul 04, 2011 | Black & Decker Pivot Plus Cordless...
Will my pivot plus drill work right away if it is connected to the charger?
Hi, no it wont the charger will not give it enough power on its own to allow you to use it, you need to leave it to charge as the charger only trickle charges it slowly to prevent damage being done to the battery, so you cant use it whilst its on charge as this could cause the charger to over heat.
you need to leave it on charge before you use it.
let me know if you need further assistance ok
plz rate this solution as i have a whole page on unrated posts, thanks
Sep 01, 2010 | Black & Decker Pivot Plus Cordless...
My mixer is very hard to raise and lower with the handle
tilt head? Loosen the pivot bolt and if you have help, remove and clean the bolt and with some teeny , not too teeney, brush or whateverm clean the pivot bolt holes. Especially the one in the head. With everything nice and clean, find somehigh temp wheel brg grease and lightly coat the pivot bolt. Without assembling, run the bolt through all the holes while rotating to transfer some grease into and onto them . .Like the way the bolt moves now? Good, Put the head in place aligning yhe pivot bolt holes rotating the bolt as you push it in place . Snug down the pivot bolt just enough to keep it in place . If you over tighten it you can break off one of the hole ears on the base. So, since you would see the bolt coming out if it did so choose, DON'T OVER TIGHTEN ;) hAPPY BLENDING- tHE PIVOT BOLT IS STATINARY IN THE STAND AND THE MIXER HEAAD PIVOTS ON THE BOLT.
Oct 09, 2009 | KitchenAid K45SS Classic Stand Mixer
Power is low. How to charge it?
The pivot has to be in the straight position and the charger plugs in the joint (it's hidden in the bent position)
Mar 19, 2009 | Black & Decker Pivot Plus Cordless...
this one dosn't charge. It takes batterys. how do i change them
Dec 20, 2008 | Black & Decker Pivot Plus Cordless...
Where to insert AC adaptor to charge Black & Decker Pivot Plus El
The female plug is directly in the center of the underside of the handle...Inserted the AC Charger/
That was it.
Nov 13, 2008 | Drills
Black & Decker Pivot Plus Cordless Drill/Screwdriver Logo
171 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
