Question about Sport & Outdoor - Others
Directions for greatland west hampton screen house
How do i change the direction of the rotation of the blades on a model 52-DA? I understand it's done through the remote control but I don't have the instructions for the remote.
There may be a switch on the side of the wiring housing to effect reverse rotation. If the remote does not have a fan reversal button, it can't reverse rotation.
Jul 05, 2016 | Hampton Bay Dryers
Attempting to replace a hampton bay courtney (61876) ceiling fan, which is flush mounted to the ceiling and cannnot seem to get it down. The blades are off, the bottom housing disassembled and I see no...
There are 2 to 3 small screws that hold the ceiling cowl in place. Loosening and/r removing those should do the trick. The screws will be on the side of the top edge of the ceiling cowling.
Hope this helped you and thanks for choosing FixYa.
Aug 06, 2011 | Hampton Bay Heating & Cooling
I am unable to change the direction of the blades on my hampton bay fan. I am unable to locate the switch
Alexander, if you have a light kit on your fan, look just above where it's a attached to the bottom of the fan. There will be a 2 position slide switch on the side of the housing.. Up is for Winter operation, Down is for Summer operation. Turn the fan OFF and wait until the blades stop turning before switching the direction of the rotation.
Hope this helps you.
Jul 08, 2011 | Hampton Bay Heating & Cooling
Where can I get replacement blades for the EF200DA-52 ceiling fan?
Hi, W/D here.
All the big box hardware stores have replacement sets along with new hardware, if you need that too.
If they don't have what you're looking for, you can order directly from Hampton Bay at:
http://www.hamptonbaylighting.net/Hampton-bay-blades.html
Best regards, --W/D--
Feb 07, 2011 | Hampton Bay 52 In.Carriage House II in...
I have a ceiling fan that the blades are in reverse mode. Where should the switch that changes the blades direction be located?
Helo there:
providing that this has that capability the switch will be on the side of the housing of the fan or on the very top. ok?
best regards mike
Aug 15, 2009 | Hampton Bay Dryers
We have a hampton bay ceiling fan model 54cvt. We cant figure out how to change the light bulb or change the direction of the blades. We dont have a manual for the fan.
This fan is also known as the Hampton Bay Covington 54 Ceiling Fan. You need to turn the globe anti clockwise until it comes out. The full instruction manual can be found here.
http://lightingworldbay.com/hampton-bay-covington-ceiling-fan-54-cvt-manual/
If you have another fan model other than the Hampton Bay 54CVT then try here
http://lightingworldbay.com/hampton-bay-ceiling-fan-manuals/
Jun 28, 2009 | Hampton Bay 52 In.Carriage House II in...
How do I reverse the direction of the fan blades to counter-clockwise on the fan? The fan is a Hampton Bay ''Clarington'' with a remote control.
There is a small black switch on the switch housing directly under the blades. When the fan is completely off, move the switch to the opposite direction.
Mar 31, 2009 | Universal Remote Control Hampton Bay...
New Hampton Bay Ceiling fan - runs only in clockwise direction
By using the "switch" to change direction I assume you mean the small slide switch on the side of the fan housing. What you have done is correct and would not affect this switch. The switch is probably bad and you need to return the fan. Suggestion: if the switch is on the housing of the light kit and the light kit connects to the fan with a plug, you are in luck. Go get another fan, swap the light kits and return the fan. Saves you a lot of work. Good luck!
Jan 17, 2009 | Hampton Bay 24002 Ceiling Fan
Broken lcd screen westing house 37
If you have the screen it is a fairly straight forward repair, however the cost of the screen almost always will exceed the cost of replacing the set. Being as we got no model number here is a general cost of a 37 inch screen used by many manufactures, $ 895.00 plus a $300.00 core charge
Mar 06, 2008 | Televison & Video
Sport & Outdoor - Others Logo
320 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
