Question about E-Machines T6528 PC Desktop
Modem in use
Trying to help a co worker with her emachine pc. She thought the problem was with her aol dial up/broadband connection. She lives in a very rural area and still on dial up. For some reason, she was fooling around with her PC because it was too slow and she was trying to get it a little faster. The result was that now the COM3 port which her modem is connected to as PCI Bus somethingoranother is saying 'in use'. It says it is being accessed by another program. She only has dial up, no fax, no printer,etc. SOmehow someone has set her as broadband connection for AOL. I can get around that but I cannot figure out why the modem is saying it is in use. I can query the modem and it gives me this error. She had somehow changed her modem as com1 port, but I changed it back to com3 but cannot dial out due to it saying the modem is in use by another program. Any advice?
  • E-Machines Master
  • 5,568 Answers
Try the following:
-Open the Control Panel
-Open System
-Click on Device Manager
-Click on Modems
-Highlight and right click on the listed modem
-Select Uninstall
Close out anything open and Restart.
IF (!) Windows is cooperating, it should 'find a new device' and reinstall the Winmodem (it's only software and a little telephone line matching).
If Windows fails to recognize the 'new device,' you will have to manually reinstall it via the 'add new hardware' path in the Control Panel.
As with any Windows stuff - rotsa ruck!
Posted on May 08, 2008
I have a second hand Acer f1,and want to connect to broadband i have connected the ethernet cable and it is recieving ,but when i click on internet explorer i cant connect to net what do i do next ?
is your broadband live? meaning active
if it is go into device manager on pc your trying to connect with and look at devices to see if your network adaptor is active. If you need help just respond and ill walk you through process
Feb 10, 2013 | Acer Computers & Internet
Wont connect to internet
Well in case it always try you to connect through dial-up.
Check the option (connect to and change in broadband, in case you using a aol software to connect to internet
Hope this will resolve your issue.
Sep 25, 2009 | D-Link DU-562M Modem
Ethernet connection
Yes you can use the Ethernet port/card in your Pc,
your isp should provide the Modem for you for broadband, connect the computer's Ethernet cable to the broadband cable modem.
Your good to go
(( if you have a NIC network interface card ))
in the PC
All is good for you
Regards
Richard.
Apr 27, 2009 | Paradyne 6381 ADSL2+/ReachDSL Router...
I have acer aspire one without a modem
Hello there,
You say you dont have a modem....but you want to connect via dial up?
Well ok, you need to do the following:
1. Contact an ISP (people like Virgin, Tiscali, TalkTalk, etc etc etc)
2. Sign up for the package you want.
3. They will send you a modem. It wont be for dial up but broadband.
4. Connect it and off you go.
However, if you REALLY want to use the internet using dial up you will have to go find an old cheap dial up modem.
BT, Tiscali and a few others do let you use a pay per min rate for dial up, but their is no one I know of that lets you get on line for nothing at all.
The only other service I have heared of was here:
http://www.connect4free.co.uk/
And even they charge 1p per min.
So if I were you.... go broadband as its faster and in the long run, cheaper.
If this has helped you please rate it so that I know.
Thank you.
Feb 15, 2009 | Acer Aspire 5500 5570-2609 Laptop
Can't locate a Modem connection
Ok, First off, Yes, if you have a plug in the back of your computer that allows a standard phone connection wire from computer to the wall, that usually means you have a modem. If you have the ability to get Broadband internet, my suggestion is to get that instead. Its more reliable and doesnt have an automatic disconnect feature that AOL has always had. Also, if you already have broadband, then you can connect with AOL directly through the broadband connection and skip the Modem use entirely. Best i can tell you, other than if your computer is not finding the modem, that means its been either disabled or is missing the drivers.
Oct 29, 2008 | Dell Dimension 2400 PC Desktop
After aol main computer went down they told me to reoncifugre the router i dont know how to do this and as i dont have a home fone line i cnt ring them any help please?
First thing to do is try to connect to the Internet without AOL then sign on to AOL using the broadband connection. When Internet Explorer is open, even without a connection, go to Tools>Internet Options>Connections and check the 'Never Dial a Connection', Click on Advanced and check the 'Automatically Detect Settings' check box. If you are not connecting to the Internet then turn off or unplug the power to the modem, turn it back on and wait 2 minutes. If you don't connect then do the same with the router power. If you still haven't connected using just Internet Explorer, NOT AOL, then talk to your router directly:) Do this by Start>Run>type http://192.168.1.1 (Linksys) or http://192.168.10.1 (Motorola). A logon screen appears. User Name is the manufacturer's name and 'admin' is the password. A web page or dashboard will appear. For a cable modem select DHCP. For DSL select PPPoE. Static addresses can also be entered if you know what they are but probably not. When you see ip addresses listed open Internet Explorer, Firefox, Opera, Chrome or whatever browser flavor you like EXCEPT AOL. Once connected to the Internet then go to AOL. More specifics on your broadband service and hardware makes will get you more specific help if you need. Happy surfing!
Oct 15, 2008 | Computers & Internet
EMachine W5243 dial up
Strange, uninstall the modem drivers, restart then reinstall them. should fix the problem.
Sep 12, 2008 | E-Machines eMachines Desktop PC
CAN'T GET AOL DIAL UP CONNECTION TO WORK
This error message normally happens because of a corrupted driver. Reinstall the driver for your modem.If you do not have cd's that came with your computer go too acer's website to download here
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=4309542&CFTOKEN=82834010
Now if that is not the cas maybe you are incorrectly installing aol. Start up your aol. If it specifies broadband at login box change to dialup or go to setup and let aol automactically detect your modem. If problem still persists. Reinstall software when prompted make sure you select dialup. Now if you are using broadband and asking for dialup. Or go to the control panel and remove your modem driver, shut down and restart. It should put the modem back.  Any more questions post comment.
Hope this helps you
Oct 25, 2007 | Acer Aspire 3680 Laptop
Thomson SpeedTouch 576 wireless modem router
Connect your wireless modem router Sign on to AOL. Download the AOL Easy Installer for Thomson 576 Wireless Modem Router. When prompted to save the file to a location select an appropriate place (desktop is a good example). Once the AOL Easy Installer is downloaded, double click the file: ST_V1.exe This will launch the modem router installer and show the "Welcome" screen. Click the Start Installation button to continue. If you wish to cancel, click the Cancel Installation button. Read the next page carefully. The text advises to close any running programs, ensure to close your AOL software also. Click Next to continue. Please Note: Connect a DSL filter to each telephone socket that is in use for telephones, dial-up modems and fax machines, etc. If you require additional DSL filters, order online at AOL Keyword Broadband Extras. Notes: Ensure to use AOL 8.0 or above. The AOL account to be used for the modem router set up must be a General (18+) account. This installer is not supported with a modem router containing beta firmware.
Apr 24, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
E-Machines T6528 PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
