Question about GE Dehumidifiers
We bought a ADEH 50 LNL1 Serial 106143 this summer. It does a great job at removing water from our basement,needing emptied every 24-36 hrs. However it is always so hot in whatever room we set it that you don't like to be in the same room. Is there anyway to adjust the heat it puts off? We lost our book that came with it. Reg Konrade
  • GE Master
  • 43,501 Answers
Unfortunately not....you see a dehumidifier puts the heat back into the room... it does not remove any heat...but... the heat from the fan motor and the compressor is added to the room... thus the heating that you are noticing...
Sorry I cannot give better news... :-(
heatman101
Posted on Aug 29, 2010
Just bought a dehumidifier in the ground level of a high ranch I am very frustrated because I dump the water every day I waas told to keep the humidity at 45- 50 but it keeps on going up This seems to be a...
It isn't necessary you run it 24 hours a day. You can set it to be on for 2 or 4 hour intervals and then it Turns OFF. However, I am a bit concerned that you have the humidity extraction level set a bit high for a basement application. 50% is more than most basements need to be. Lowering it to 35%, will remove more humidity and eventually will run for shorter periods of time. It takes several days of operation for the dehumidifier to get the humidity under control.
If you have a floor drain in your basement, you can use a hose to daring the water, rather than having to empty the bucket daily (which is not that unusual). See your Owner's Manual on how to connect a 48" length of garden hose to the dehumidifier.
I hope this helped you & thanks for choosing FixYa.
Sep 17, 2011 | Friedrich Dehumidifiers
My DDR7009REE HAS WORKED GREAT FOR A MONTH. BUT NOW IT LEAKES ON THE BASEMENT FLOOR. I SHUT IT OFF FOR 2 DAYS THINKING IT MAY HAVE FROZE UP. TURNED IT BACK ON AND IT LEAKS ON THE BASEMENT FLOOR INTEAD OF...
dehums remove humidity from air inside unit the evaporator sits in drain pan , drain pan has some sort of line or tube witch leeds to the internal collection or bucket thats what you slide out and empty when its full , ther is some sort of sensor or float switch that lets you know wen full make sure unit is draining properly inernaly and full system is working properly
Jul 03, 2011 | Danby DDR7009REE Dehumidifier
Dehumidifier makes the room too hot where it is running. does very good removing water need too empty 50 pt every 24-30 hrs.
The dehumidifier does not heat or cool, but the compressor running will produce some heat and it can make a room hotter...
heatman101
Aug 29, 2010 | GE AHG40LJ Dehumidifier
Dehumidifier not running
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 29, 2010 | Kenmore 54501 Dehumidifier
For the last month or so, the dehumidifier runs all day long and pulls very little water out of the air. The air humidity reads at 65%, with the dehumidifier set at 50%. I can smell the difference in the...
heatman101
Jun 19, 2010 | Maytag M7DH45B2A Dehumidifier
Goldstar dehumidifier model DH305Y6 is there an outlet on this model for a hose so can drain into sump pump?
I have a Goldstar dehumidifier, Model DH305Y6. I bought it about 5 years ago at a local Walmart. During the summer I run it in the basement, here in south-central Pa. When it was brand new it worked very well, for about 2 yrs. Then it began turning on & off very irregularly. At first I thought it was the sensor on the front of the coils. So I moved it to the lower left side of the coils, and had the same results. The other day the water heater in the basement developed a leak. About 300 gals. of water covered the floor. After sumping/wet-vac'ing down to a wet carpet, I pulled out the dehumidifier and plugged it in,(the filter was cleaned before put away last summer). It began its on/off cycling again. It runs for about 2-3 mins., then shuts off for about 5-10 mins. So, I took the On/Off switch apart and read the resistance. It read 48k, for the 50k switch. I turned the switch all the way left to all the way right and it went from 48k, down to about 8k. The two wires to the switch were attached to the #2 and #3 poles,(only 3 poles). I did some testing, then removed the wires and re-soldered them to the #1 and #3 poles. I put everything back together, and now it works. It runs constantly, but it works/runs just fine. I need to get the basement dry, so I will let it run until the job is done. In the Spring I will get a new 50k potentiometer,(on/off switch), and see if that works. I will post results if I remember to.
Sep 29, 2009 | Goldstar Dehumidifiers
I recently purchase a house in Northern NJ and have quite a bit of Humidity in the basement. The central AC is connected to the basement but i barely run the AC because it has not gotten that hot. I am...
dehumidifier for sure!, usually a small 200$ unit will do the job. you can even hook a hose to one to drain it so you dont have to empty the bucket all the time. as for your house, when its raining hard outside, walk around you house and see if there is any areas where water is going in beside a wall. also long eavestrough pipes away from the house helps alot
Jul 30, 2009 | Santa Fe (4025699) Dehumidifier
Water not draining in the bucket
have u checked the drain on it?? or if there is a filter might be dirty
Jul 01, 2009 | LG LHD45EL Dehumidifier
Works well but
Yup, they eat energy.
An electric dehumidifier includes a refrigeration cycle that is very similar to a window AC units and refrigerators. They cool the air in the basement to condense and collect water and remove humidity, heat the air as a required consequence of the refrigeration cycle and dump it back to your basement.
Two sources of humidity in basements include warm outside air that naturally cools due to below grade earth contact and water passing from the ground though the floors and walls and evaporating into the basement. Dehumidifiers do most of the work in the summer when higher temperatures outside enable air to hold more water content.
In the winter, cooler outside air contains less moisture by weight eventhough it may be raining and the relative humidity in basement will be less because the air is warmed relative to the outside. The lower moisture content in the winter also absorbs the water passing through the walls and floor.
From an energy perspective, you may want the humidity set NOT below 50%. This will keep humidity below the level mold desires, but prevents the dehumidifier from doing more work and eating more energy than needed. A cheap battery powered temp/humidy meter left in your basement will help. Sources that include the "mold triangle" (temperature, water & food) often separate fact from expensive hype.
If the dehumidifier doesn't keep up, consider adding a moisture barrier to the basement walls and floors such as Dry-lock and floor paints to ****** moisture entry. Moisture barriers act very similar with water as insulation does with heat. They don't eliminate the need for a dehumidifier, but they reduce the work they do and energy they eat.
Oct 02, 2008 | DeLonghi DH40P Dehumidifier
Dehumdifier won't drain
You just need to get the water flowing and start the siphoning process by taking out the water bucket while it's full of water and raising it up high enough to start the water flowing. Once the water starts flowing, you can put the bucket back and the water will keep flowing (by capillary action). If the bucket empties completely, you may have to do it again periodically to get the water flowing again.
Sep 17, 2008 | Kenmore 54701 Dehumidifier
Dehumidifiers Logo
339 people viewed this question
Top GE Dehumidifiers Experts
J.D. Browning
J.D. Browning
AZBen
AZBen
Are you a GE Dehumidifier Expert? Answer questions, earn points and help others
