Question about Toshiba 57H82 57" Rear Projection Television
Wavy Lines showing only on with DVD player
I have had a Toshiba 42" Rear Projection since 2004. This past year wavy lines move across the screen, dark images show up more. Last week I had comcast hook up HD Digital Cable and now all it clear, except the Video Tape player and the DVD player, they both still have lines. The PS3 and the new HD cable are working great. Why is this??? Can it be fixed???
Or....try better-shielded cables.
Posted on Jun 26, 2008
    Genius:
  • 1,030 Answers
This is a common problem i see at the shop it involves what is known as the hypermodule. there is a group of 11 capacitor.. these are surface mounted and very small and difficult to replace. in an ideal situation replaceing the hypermodule would be best.. but if if understand right this is no longer availble. 2nd option is sending the board in and leting a technician replace caps..3 and most difficult is replaceing the caps yourself.. i do not recomend this...i would recomend 1 and 2
Posted on May 08, 2008
Hello..Toshiba 51HC85, 2005 model. Turn on TV and verticle wavy lines appear until TV is warmed up completely. After warm up the picture is great again. Any ideas?
I've had the same problem for about the last 6 months. My workaround which was to leave the tv on 24 7 and just turn off the TWC service box. But now the symptoms are vertical dark lines going all the way across screen. My guess is that it will cost more to fix than worth it. I paid @$2000 for it new in 2004. Technology has gotten better so I may just go out and get a Samsumg for considerably less and be way better off. None of Toshiba's products had done well for me. 2 laptops, 3 tvs, etc. have taught me this.
Sep 20, 2010 | Toshiba 51H83 51" Rear Projection...
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Dark line across the top of 56HM66
I had the same problem on my tv found a simple solution its been a week and no problems so far.pull out light engine you will find round piece of tape pull it of there will be a #2 phillips screw in about 3 inches turn it clockwise and watch it vanish.i turned mine a little further to assure it would be gone.only took a couple of minutes to do dont know how long it will last though good luck
TelecomTech
jb
Oct 26, 2008 | Toshiba 42H83 42" Rear Projection...
Hitachi 53" UDX10B
Good Day, hayzlett;
Remote control unit, part number HL01643; CLU-5713TS1.
You can purchase this locally.
Good Luck, big IRISH.
Aug 08, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Toshiba 42WH36P rear projection TV has wavy lines
the problem is going to be a bad NEXT HYPER UNIT module. this is the digital scan card in the tv. try using the componenet inputs and if the tv works ok then you know that the HYPER UNIT is the problem. the reapir process for a "do-it-yourselfer" is too involved and would recommend a serivce center for this repair.
Dec 29, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba Rear Projection 42 "
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 23, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba 42 inch rear projection
Nov 23, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
Oct 07, 2007 | Toshiba 42H83 42" Rear Projection...
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
