I have a coleman Elect-A-Heat Mach EL R.V. Series. The water is not draining, the water built up and drained out the bottom. I am looking for diagrams to take this apart and repair it, does it have a drain that may be plugged or does it have a filter of any kind. I need diagrams to take this apart and fix this minor repair. Wayne
    Guru:
  • 587 Answers
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Posted on Aug 31, 2010
Coleman Mach 48000 series roof top A/C in my camper & recently it's been dripping heavily inside the camper. We looked at the top & inside for a clogged line & can't find anything, suggestions?
I had the same problem but it wasn't a clogged drain line, it was the gasket between the roof of the camper and the AC unit. The gasket had shrunk and pulled apart allowing rain water in. To make sure you don't have a clogged drain line when using the AC do you notice water dripping off the camper anywhere besides inside? You should have some drips somewhere on the outside.
Jul 18, 2017 | RVs
How do I fix the drain lines from my rv roof?
have to remove cover to access drain lines to clear
Jun 10, 2014 | Coleman Mach III Air Conditioner
My coleman rv ac unit is dripping condensation inside the camper, what is causing that?
It is possible that the drain hole on condensate pan is plugged and causing water to over flow pan. Remove cover from unit and check drain line.Clean coils andpan as best you can and clear drain hole. Add a small amount of bleach to water in drain pan.This will kill any algea or bacteria that may be growing in condensate water and plugging the drain. Thank you
Jun 20, 2011 | Coleman Mach III Air Conditioner
I have a coleman Mach III RV AC Unit that is leaking water after it runs. It has a trail of water off the roof so it looks like it is draining properly. Is there somehere else I should look for a...
I would remove top cover and clean all coils you can get to by using spray condensor cleaner.You can get this at most hardware stores.Just follow instruction on can and clean thourghly. Be sure you have power off to unit while you are cleaning and flushing. This should improve units effiency and by breaking down algea growth in condensate it should drain better. Thank you.
Apr 15, 2011 | Coleman Heating & Cooling
Hi i have a Coleman 8000 series aircon in 2007 model Jayco Caravan we have just been away for 4 days and it was leaking water through the vents onto the floor what causes this does anay one know as it...
Please check drain tray is not blocked.And also check Evaporator coil for dust blocking. Clean drain tray,coil and air filter. Check fan motor speed. If less speed, replace capacitor.Thanks.
Feb 21, 2011 | Coleman Mach 15 Air Conditioner
Coleman Mach AC drops condensation when shut off
Your AC's drain port could be on the opposite corner from where the water is building up. Your vehicle absolutely has to be level, this pertains to the refridgerator also. Good luck, my friend, Dana
Sep 09, 2009 | Coleman Mach 15 Air Conditioner
Coleman mach air
Time for a spring cleanning,, especially the drainnage system, filter,, front cooling coils-and the drain line! thank you-very-much!
Aug 28, 2008 | Coleman Mach III Air Conditioner
Wiring Diagram Coleman Electra Heat Mach EL
I need the motor for a mach EL air conditioner. I can not get a model number of the unit or a number off of the motor. Can someone help me. Its about a 1980 built unit.
Mar 29, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
463 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
