Question about Sta Rite STA-RITE 1 HP DURA-GLAS PUMP
I have Sta Rite 1.5 HP Model: P2RA5F-182L for my in-ground pool. I just notice that when the pump turns on, immediate this trips the breaker, the pump never begins to operate. I isolated the problem to the pump itself. The breaker has the correct Amperage rating and the pump itself by visual inspection of the electrical wiring shows no evidence of a short (The pump is 3 years old). (About 2 months ago I opened the motor to clear the impelar. When I reassembled it I kept getting a small leak when the pump was on. I tried to fix it twice but, I guess I needed to get a new seal). Could the leak me a contributor to this problem? Are the coils in the motor damaged?
  • David Spradling
    David Spradling Nov 12, 2017
    less hassle replace whole pump
  • Sta Rite Master
  • 12,237 Answers
If the seal behind the impeller is leaking theres water in the motor. you could probably replace the seal and dry it out...maybe. if the pump does turn thats probably the issue
Posted on Nov 12, 2017
5 Suggested Answers
  • 990 Answers
SOURCE: shaft seal leaks on sta rite pump?
You need to get to the shaft at the back of the motor to hold it while you use water pump pliers or the like to turn it off. It will unscrew in the regular direction but if it has a set screw to hold it in (You will find this at the center of the impeller) this will be a left hand screw so you will go clockwise to loosen it. This should get the impeller off. If not you will need to put a screwdriver in the side of the impeller and give it a hit to lossen the impeller. Good luck.
Posted on Aug 25, 2009
SOURCE: Sta-Rite 1HP inground pool pump
Any time an electrical appliance trips a breaker there is only several causes:
1 - appliance is pulling more amperage than the breaker was built for.
2 - breaker is faulty
3 - a "hot" wire is touching "ground"
4 - screws (where wire is attached) in the pump or breaker are loose
1 - If the appliance is pulling more amperage than the breaker (or wiring) will allow, then check the appliance to see what amperage it's rated at. If this is more than the breaker will allow, you'll have to plug the appliance into a circuit that will take that amperage. If the appliance rating is within the limits of the wiring & breaker, then check #2, #3 or #4 above. If everything is okay with the remaining possibilities, then you have problems within the pump. Do it yourself'ers usually have a bad time when they open an electric motor. I suggest you take the motor to a electric motor repair shop or seek help from the Sta-Rite pump Customer Service.
Posted on Jul 02, 2010
Testimonial: "Removed the breaker and its bad ,thanks for Your help"
jharwell668
  • 640 Answers
SOURCE: Have a Sta-Rite cartridge filter that is leaking
It is probably your o-ring that needs to be replaced. These are very commonly worn in these types of pool filters. It should be part number PLM100 or PLM150 and should be fairly easy and inexpensive to find and replace.
Posted on Apr 26, 2011
john224
  • 1378 Answers
SOURCE: I have a P2RA5F-182L Sta-rite
Contact me thru www.arrowmotor.net; we stock the part you need. To ensure you get the correct version it would be helpful if you took a digital picture so you can send it in an email.
To answer your question, yes - you could strip all the wires back and bypass the terminal board but in the long run it will make it much harder to install the part since you will need to put all new terminal ends on including a female pin style that requires a special crimper.
John
Posted on May 12, 2011
Installed new pump unit starts and runs for 15 minutes then trips breaker what should I check
When the pump nears the 15 minute mark, check the housing to determine whether it is running hot. Also listen for changes in pumping sounds as something may be causing restriction.
Nov 22, 2013 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
I have a P2RA5F-182L Sta-rite pool pump which the white plastic connector for the power leads has total been broken (it has the 220/110 switch integrated into it). Can i bypass this and straight wire it...
John
May 12, 2011 | Sta Rite STA-RITE 1 HP DURA-GLAS PUMP
Where can a find a new pump CHEAP? Current pump is Model C48L2P104 (18 years old). Serial 1B93. Voltage 230 HP 1.5 RPM 3450/1725 Amps 9.2/2.5 Frame 48Y Dura-glas H/L
A new motor and pump parts (if needed) would be cheaper than a whole new pump. Your motor is part number UQS1152R or if you just want a single, high speed motor you could use USQ1152 to replace it. You will likely need a seal and seal insert as well; part number 100 (it may have letters in front like AS100, PS100, etc) and J3-2. A whole new pump you should shop for part #P2RA5YF-182L.
For a quote on the parts from us you can contact us using thru our website at www.arrowpools.net. Otherwise, google those numbers to locate your best deal.
John
Jan 04, 2011 | Sta Rite Sta - Rite Duraglas In - Ground...
I noticed that my the spa water level got really low. My pool pump is has stopped working. The breaker was tripped and I reset and it tripped again. Is the pump fried?
Probably the heater. Turn the heat off and try it. There should be a flow switch to prove pump is on before the heater works, but sometimes if you're running low, it will work intermittent. Do you know how it got low? evaporation? Is the pump leaking? If the pump is leaking, and has leaked for awhile it may have shorted out the motor. While running the pump low on water will damage the mechanical seal that keeps the water in the pump, it should not affect the motor itself.
Oct 19, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Sta-Rite 1HP inground pool pump Every time the pump turns on it trips the breaker, after taking the motor appart and lubing it up I could get it going but once off for a period of time on startup it will...
Jul 01, 2010 | Sta Rite STA-RITE 1 HP DURA-GLAS PUMP
To purplewg re my Sta-Rite pool pump: I haven't disassembled anything yet, because I'm trying to get an accurate dx before delving. If I take the thing apart, I'll have to replace the seal, and I'd rather...
SOUNDS LIKE BEARINGS .. SEARCH YOUR LOCAL AREA FOR POOL PUMP MOTOR REPAIR GUY, SEE IF THEY OFFER FREE TESTING REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 17, 2010 | Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
Sta-rite problem
Pump is heating up and kicking the breaker try cleaning the pump filter and let me know by posting to this solution.
Sep 29, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
I wired a new dura-glas pump as a 115, and it popped the breaker. I put the black wire on 1 and the white on 2. Should I have wired it as 230? Should I switch the black and white wires, even though the...
The wire placement does not matter assuming you have a 115 volt supply with a three wire cord/cable and they are comming in as blk=hot, white=neutral and copper=ground.
Tripping a breaker would be from a shorted hot wire so look for a place where it touches the white or ground wires or the metal of the motor. Another cause would be if you really have 230V across the black and white and you connect it to a motor set for 115V. Is the breaker that turns off the circuit in question a signle wide or a double wide breaker. A double wide would be 230V.
Jul 31, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
Sta Rite STA-RITE 1 HP DURA-GLAS PUMP Logo
409 people viewed this question
Top Sta Rite Garden Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
