Question about GE Security Simon 3 Wireless Home Security System
Alarm going off-says front door problem, but front door is fine. How can we stop alarm from going off?
    Sniper:
  • 54 Answers
If your front door is using a wireless transmitter then the problem is most likely a mis-aligned contact. Most alarm installers will install the transmitter with built in contact on the door molding and a small magnet on the door itself. There is generally an alignment mark on the transmitter case so you know where to place the magnet. The magnet should never be placed more than 1/2 inch away from the transmitter. Be sure the alignment is correct as well as within the spacing requirements. If this was done properly another possibility is either a defective contact or in some cases a loose fitting door with excessive free play could also be causing you a problem. Make sure the door is tight when closed. If your door contact/transmitter is of a different design such as an external contact wired to the transmitter let me know the specifics (type of contact ie., hidden press fit, plunger, surface mount) and I'll give you additional information regarding what to look for. I have over 30 years experience in the alarm business and am sure I can help you.
Posted on Aug 30, 2010
2005 tahoe rear access door ajar alarm won't stop going off
I HAD THE SAME PROBLEM WITH MY REAR DOOR TAHOE 2001 ., I TOOK IT TO THE MACHANIC AND IT WAS SO SIMPLE A FUSER UNDER HOOK . $8.00 FUSER ., IF I WOULD IT KNOW . I WOULD IT DONE IT MYSELF.-- REPLACE FUSER WHERE IT SAID --HORN- ITS UNDER THE FRONT HOOK... I END IT UP PAYING $120.00 FOR THEM TWO HOURS WORK...THE LIGHTS AND THE ALARM WAS NON-STOPPING MAKING NOISE..... RIGHT..????
Sep 20, 2012 | 2005 Chevrolet Tahoe
Citroen xantia alarm & stop light on dash
PSA cars with analog instrument clusters have the STOP light to alert drivers of irregularities in engine temperature or coolant that may cause severe damage to the engine. Check your radiator coolant level and top up when it's low. Don't forget to bleed the air from the cooling system. If problem persist, check for loose connectors to the Coolant Temperature Sensor(mounted on the cylinder head) and the Coolant Level Sensor (mounted on the side of the coolant refill tank). For the alarm, check ALL door switches including those for the front hood and the rear trunk. They may be shorted to earth or one of the door becomes ajar. Next time the alarm triggers, check which door looked like it's slightly opened. If so, realign the door hook located in the door pillar.
Sep 09, 2012 | Citroen Xantia Cars & Trucks
My ford mondeo lx petrol 98' alarm goes off, sometimes more than once i have to keep going to the parking lot to open and close the door only for the alarm to stop but after some time it goes off again.
Your problem is most likely the central locking / alram switch fitted aroun the door lock inside the door void. Try using the passenger door to lock / unlock. If this stops the alarm triggering then you need to replace the switch behind the lock in the drivers door.
Feb 16, 2011 | Code-Alarm Code Alarm Transponder
Have a 2000 VW Beetle. The alarm won't turn off!
My 2000 Beetle does same thing (although not all the time). Just found an internet post that suggests there is a problem in the door lock sensor. I assume you are using a regular key - not
the keyless entry - like I am. He also said that you can disable the alarm (also disables the
keyless entry - which doesn't bother me) by leaving the front door AND the rear trunk open and
starting the car up. Seems to work so far. I will get the door lock sensor replaced and turn the
alarm system back on (not sure how yet), and let you know if that stops the problem.
Jul 24, 2009 | 2000 Volkswagen Beetle
Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Door locks not working properly.
one of the front door latches is out of adjustment or bad. when you lock it at the trunk try the front doors to see if they might still open when the alarm is set if so that is your bad latch. bad news is to replace it you will need to tear down the entire inside of door
Mar 24, 2009 | 1998 Audi A4
Won't Start
CONDENSATION FROM THE FREEZE SEEMS TO HAVE SHORTED THE ALARM MODULE REPLACE IF AVAILABLE OR BYPASS
Jan 16, 2009 | 1989 Volkswagen Jetta 2 Door
My problem is i just recently bought this 1990 Lexus LS400 and everything works fine but randomly the alarm will start going off when i open the truck or doors then i put the key in the ignition and it...
My 1991 Lexus LS 400 does something similar. When the alarm goes off I use the key to unlock the passenger side front door and it turns the alarm off. Go figure, I know it sounds funny but it solves the problem for me.
Jan 06, 2009 | Lexus LS 400 Cars & Trucks
GE Side by Side Refrigerator
Door Alarm -
To set the alarm, press this pad until the indicator light comes on.
This alarm will sound if either door is open for more than 3 minutes.
The light goes out and the beeping stops when you close the door.
Jun 01, 2008 | GE PSS26MGS Side by Side Refrigerator
GE Security Simon 3 Wireless Home Security System Logo
115 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
