Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer model GHW9200LW, THE CODE HF comes up ,tried the recommended fixes from the troubleshooting guide, but no luck
  • 28 Answers
HF = High Fill
This can be caused by using non HE detergent in your front load. Put the washer in a cold rinse for a couple of cycles to clean the excess soap and try the cycle again using HE detergent. If the problem returns you may have a pressure switch or hose that will have to be replaced.
Posted on Aug 29, 2010
  • leopoldo Sep 20, 2010
    does moving a washer from one house to another or storage for 3 months cause this error code?
  • mark1468 Sep 26, 2010
    No, it shouldn't however, if you moved into a different area that has soft water or a water softener and you didn't have one before. If your using the same amount of detergent it will cvause sudsing which can trip the HF indicator.
    Or if the washer was layed down on its side, this may allow water to infiltrated the water pressure hose and prevent the air baffle from working properly
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Whirlpool Duet washer FH code "sometimes"
well..based on what you're stating here..sounds more like a sensor, based on the duty cycle.
Jun 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F- code does not show code in book what and how to remedy the problem?
Hello there again here is some more info for you
Whirlpool Washer Troubleshooting: Error/Fault Codes Whirlpool Washer Troubleshooting has been made easier since newer Whirlpool washers generally display a consistent range of error codes (or fault codes) when problems develop so that owners and service personnel can quickly troubleshoot the problem and fix it easily. The Fault codes address a wide range errors that occur with Whirlpool washers, everything from water and power problems to basic maintenance routines. We have put together a comprehensive list of Whirlpool Error Codes for some specific and general Whirlpool Washer models to help you with your Whirlpool Washer Troubleshooting task.on next post
Oct 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer fills with water washes for about 12 min then code hf
The FH error code means that the washer has not detected any water entering it. This tip i wrote relating to the FH code covers what to checkto fix it.
http://www1.fixya.com/support/r10423905-fh_code_means_duet_epic_front_load
GENE
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet GHW9200LW - the display panel that shows cycles is flashing red - seems to have locked and can't put into any other cycle - flashes in all cycles - before this happened I started...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Sep 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool washer (model # GHW9200LW, serial #CSM 4604196) is blinking "F02," which means there is a drain problem. My husband disconnected the drain hose and cleaned it. The washer continues to blink...
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer door won't secure
Replace the wax motor and door lock mechanism.
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite HE3 Error Code
Here's a link that explains the "FH" error:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If you have questions about the information I provided, or need further assistance in trying to determine the source of your problem, please post back and let me know. I hope this helps provide an answer for you.
Jul 11, 2008 | Kenmore Elite 45986 Front Load Washer
The washer mode light keeps blinking
the machine is locked out on the control, go to the signal button on the far right side and hold the button in for four seconds and it will unlock the control and yu can select the cycle that you want
Apr 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
472 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
