Question about Whirlpool LER5636P Electric Dryer
Dryer will not turn on. I jiggled the prong that goes into the door switch and it worked one more time. Now it will not work.
  • Whirlpool Master
  • 2,290 Answers
When you push on the door switch does it click,if not it's broke and the dryer wont run,the part number is 3406107 and it's 15 to 20 bucks.let me know how you make out and next time send the full model number,there where 10 other machines with the numbers you sent but had another number and letter but i'm sure the part number i gave you is correct
Posted on Aug 29, 2010
  • Whirlpool Master
  • 43,501 Answers
The door switch is a normal part that fails...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Dryer quit won't start wife ran both washer/dryer same time put new breaker in still nothing?
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Apr 18, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
My Amana Dryer ned7200tw has been working great till the last couple months. Lights come on, I can choose setting with the knob but nothing happens when I push the button to start.
If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Mar 27, 2015 | Amana NED7200TW Electric Dryer
Product code is KISITD1. Its temperamental. Doesn't always start. Today it stopped working 20 mins into a 60 min cycle. Then it started for a cpouple of times , now it wont work at all. Have taken it...
Mar 21, 2015 | Dryers
My LD505e dryer won't turn rn on at the switch.
Hey GOD IS GOOD !!!!
Feb 15, 2015 | Dryers
The dryer does not work. Error code 6 flashes appears.
Jan 05, 2015 | Dryers
I have a Hotpoint Dryer NVLR333ETOWB, I opened the door mid cycle, to check on load, make sure it was drying, I shut the door, and when I turn the start knob, all I get is a buzz, and the dryer does n
Sep 29, 2014 | Dryers
Why won't my dryer work?
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Aug 23, 2014 | Dryers
Why won't my dryer turn on?
May 15, 2014 | Kenmore HE5 Electric Dryer
Dryer will not start, has power to unit,timer seems to be working....door closes and locks as it should...
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor 2 heavy red wires (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 16, 2009 | Dryers
I HAVE A DRYER THAT WAS WORKING FINE, THEN TURNED OFF. I PUSHED THE BUTTON AND IT WOULDN'T TURN BACK ON. NEXT MORNING TRIED AGAIN AND IT TURNED ON FOR 5 MINUTES THEN SHUT OFF. WON'T TURN BACK ON. I THINK...
Would first check the door switch. This can be done by finding door switch, with door open hold in switch and jiggle around while pushing the start switch. If it tries to start, replace the switch.
Mar 24, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
29 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
