Question about Coleman Powermate Powermate 5000W Generator
When it's started the engine revs hard as if it's powering something whilst nothing is connected. after a few seconds the overload light comes on & the engine settles down but the overload light stays on
  • Robert
    Robert Aug 31, 2010
    please supple a ser# or a mod# i will review the wiring
  • julian4fitne Aug 31, 2010
    it's a Kypor IG2000
    Scholar:
  • 97 Answers
In checking my manuals their is a rectifier that controls the 12 volt side this can be bad even though it is for the 12 volts some times the gen needs a back pulse witch acts like a exciter that kick the power in you can replace this part i do not have the part number i'm sorry but you can get them from electronics stores the part will be black 1x1x3/8 inch with a mounting hole in the center with 4 wire studs replace and try this first if the issue is not solved then the inverter unis is bad unfortunately this is a solid state sealed unit encased in a hard gel that hole unit will need to be replaced in order to cure your issue i hope this helps
Posted on Aug 31, 2010
Yamaha 2400IS Generator goes to overload when ie: 240 volt plugged in, or 700 watt angle grinder plugged in.
No idea but somebody else will probably come along with a better idea then mine, seems a lot of these generators have this thing installed on them (Has $25 hard start kit). Not sure what it does or how it works. Strangely enough you said you use it for 240 volt. Looked at the picture and didn't see a 240 volt connection.
If you are using the what look like the 120 volt circuits you can't over load the unit. Maximum current draw will cause it to go into protection mode and shut down the power load. The following is an exert from the owners manual which I got from Yamaha's site. Link at the end of this post.
Hope this helps
16
q
760-029
AE00788
Overload indicator light
The overload indicator light
comes on when an over-
load of a connected electrical device is detected, the
inverter control unit overheats, or the AC output voltage
rises. The electronic breaker will then activate, stopping
power generation in order to protect the generator and
any connected electric devices. The AC pilot light
(green) will go off and the overload indicator light (red)
will stay on, but the engine will not stop running.
When the overload indicator light comes on and power
generation stops, proceed as follows:
1. Turn off any connected electric devices and stop
the engine.
2. Reduce the total wattage of connected electric
devices within the application range.
3. Check for blockages in the cooling air inlet and
around the control unit. If any blockages are found,
remove.
4. After checking, restart the engine.
http://www.yamahamotorsports.com/assets/service/manuals/0/LIT-19626-01-23_1423.pdf
Jun 06, 2016 | Yamaha EF2400iS Portable Generator
I think it's something with the fuel line.
It's quite possible the fuel pump is starting to fail or possibly even a dirty fuel filter
Mar 28, 2014 | 1997 Honda Civic
Car starts fine then battery light comes on, after a minute or so the abs light comes on and lose all dash function......any help would be great
check your battery connections for corrosion, also see if the terminal wires to the battery are loose.
Dec 30, 2013 | 2002 Toyota Avalon
Acer Aspire 5732Z won't turn on - the light comes on for a few seconds and then turns off - whilst the light is on the disk drive will open - the screen doesn't show anything
Could be bad ram,hard drive or possibly a bad display panel or video card.Try using different ram and removing the hard drive then try it.Also,connect it to an external display and see if it shows video or not.If after trying these things it still isn't showing let me know and i'll try to help more.
Nov 22, 2011 | Computers & Internet
Motor runs for a few seconds than cuts out. No cooling
The startup capacitor is weak and that makes the overload switch kick in. You can get a 1/4 hp to 1/3 hp 3 in 1 hard start relay to fix that from graingers, or 1stsourceparts. EZ instructions.
Mar 10, 2010 | Refrigerators
My Golf Mk4 TDI's lights have started pulsing with the sound of the engine idling rough however rev counter stays pretty steady. putting a multimeter across the battery whilst ignition is off gives a...
voltage sounds kinda high for while its running. the voltage regulator in the alternator sounds like it is bad. i would replace the alternator.
Feb 03, 2010 | 2000 Volkswagen Golf
Loss of power , electrical, will run and start for now but revs
well when i have crazy stuff like that come into the shop i always find bad grounds causing the problem! it is effecting to many different parts of the car not to be a ground. you have to think what is in common with all that stuff and the only thing is grounds and battery! so check them and you should find a lose connection some where
Sep 18, 2009 | 1994 Oldsmobile Silhouette
2005 Sportster 1200 Custom - Engine Light comes on randomly.
dont know if your injected or not geussing you are sounds like an o2 sensor
Aug 16, 2009 | Harley Davidson Harley-Davidson Motorcycle...
1995 Bonneville
the problem is probably one of the battery cables. check for looseness and corrosion. especially at the positive battery connection where the two cables are stacked.
Nov 11, 2008 | 1995 Pontiac Bonneville
Coleman Powermate Powermate 5000W Generator Logo
157 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
