Hi
Thanks for using FixYa. Two things may cause the “No
Signal” message to come up are - no data available for closed captioning and a
weak signal input. Your TV is in the Closed Captioning Mode. To turn it off
simply bring up the on screen menu and scroll down to the part that says closed
captioning and turn this function off! With the closed captioning block
displayed and the program being viewed is not sending out closed captioning
signals the TV will display, No signal!
If this doesn’t resolve your issue then the problem may be
with the processor failing and it is causing a random read of the EPROM to
display the not available message. I’ll suggest you to run the HDMI from the
PVR (personal video recorder) directly to the TV (mute the TV), and then run
the optical audio from the PVR directly into the receiver's optical in. The
closed captioning is something that is addressed in analog broadcasts, but not
necessarily digital broadcasts
Try using Component cables if this doesn’t make a
difference. After using components cables the issue will be resolved. Please do
accept the solution if the issue is resolved or post a comment for further
assistance.
Thanks
Rylee
That doesn't sound too good. DId you try connecting another input source such as a DVD player to the high definition input. If I am not wrong this tv has a feature - it will auto-detect it and choose the best resolution?
Thank you for your suggestions - I can't find Closed Captions on the menu might it be listed under a different name? I would like to try this as your other suggestions are too technical for me and I will have to ask my son for help in following them.
Thanks for your suggestion - I'm a "senior" lady and am not confident about unplugging ans replugging anything so will wait for my son's next visit at the end of the week and pass the problem to him. I had hoped it might just be a matter of checking settings, but it seems to be more complicated than that.
Thanks - we'll leave it there
