Question about Toastmaster 840 Indoor Grill
How do you clean this grill? - Toastmaster 840 Indoor Grill
  • 43,501 Answers
Only use dish soap and water... you may have to let it soak abit...
but do not submerse it or use abrasives on it...
heatman101
Posted on Aug 29, 2010
Need to re paint my grille
automotive paints require a good clean and well prepared surface like light waterpaper sanding to remove any oily or fatty resedu and the correct undercoat before applying a new coatings otherwise it will not last chipping or peeling will occur.
May 06, 2013 | Cars & Trucks
Grill doesn't heat to high temperature.
try cleaning the injectors they could be blocked
Aug 13, 2012 | Ducane 30400040 Stainless Steel Grill
The display show service and blinks, i Kent cleared
A leading cause of so many problems with Sub-Zero refrig's is the coil behind the top grill above the doors is clogged with dust. You can use a vacuum with a hose to clean that coil by removing the grill and cleaning it. To clean it remove the grill by removing the screws that hold that grill to the upper door frame where the grill attaches to the door frame and unhook springs from back side of the grill so it can be taken off to clean the coil.
Gene
Aug 11, 2011 | Sub-Zero 661/F Side by Side Refrigerator
Changed gas grill burner, now everything cooked is black on outside
1) Sounds like you may have a smoking issue. Find the cause of the smoke and it should resolve the blackness issue.
2) Is everything clean? if not clean grill and if you have cover over burner under grill clean that as well.
Aug 05, 2011 | Fiesta 240 Grill
How is the forman cleaned grill cleaned
The grill is cleaned carefully. The key, presuming that you do NOT have removable grills, is to NOT get water inside the unit. When you eventually kill the one that you have, get removable grills, next time. The unit will last MUCH longer.
May 25, 2011 | Microwave Ovens
My weber grill is not putting out enough heat--both burners ignite, but I can't turn them up to get a higher flame/higher temparature. The grill is about 5 years old. How can I clean the burners to get a...
follow the below procedures on how to clean the burners for your grill:
Shut off the gas. It is very important that you turn off the gas valve to your BBQ before you can begin to clean it. This is found on the hose that attaches to your propane tank, simply turn the valve all the way to the right.
Escape any remaining gas. Next turn all the burner knobs to the highest setting and allow the remaining gas, if any, to escape. Make sure you have the grill hood in the open position before doing this.
Let the Grill vent for five minute: In order to ensure that the remaining propane has ventilated properly, leave your grill open and do not begin to clean it for at least five minutes.
Brush grill bars. Using your grill cleaning brush, firmly brush the surface of the grill bars in a forwards-backwards motion with the steel from the brush sweeping across the surface. Once you have brushed the surface flip each grill bar over and brush the other side.
Saturate with grill cleaner spray and repeat. Using your grill cleaner spray thoroughly saturate the surface of the grill bars and brush both sides. Set the grill bars aside after you finish so you can access the interior of the BBQ to clean it.
Remove burner plates and clean. All gas grills have metal plates which cover and protect the flame pilots during cooking. These will typically become covered with ash, and burnt grease and sauce over time. Simply remove them from the grill and brush them down. After you have brushed them once, saturate them with the cleaner spray and brush them down again. Set the plates aside so you can finish cleaning the rest of your grill.
Clean interior of grill. The plates will only catch so much, still sauce and grease will fall to the bottom of the grill and turn to ash. Using your grill brush, jar all of this ash free. Douse it in cleaner spray so it condenses and scoop it up with the paper towels.
Clean grease catch. Many newer gas grills will come with a grease catching plate. You can usually access these through the rear of the BBQ. They generally have a small metal handle and will easily slide out. Remove this grease catch, and brush and clean it thoroughly.
Clean exterior of grill. Using your grill cleaner spray, saturate the exterior of the grill and wipe it down with the paper towels. Repeat this process until the exterior is entirely clean.
Reassemble the grill. Now you can put all the pieces back together in your grill and turn the gas valve on again.
I hope the above helps to solve your problem.
Good luck.
Aug 18, 2010 | Weber Grilling
How do you clean capt n cook grill?
Call a place that cleans grill you can damage your grill if you do not know what you are doing!
Aug 10, 2010 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
What is the best way to clean the grill?
use a good wire brush on the burners each time you use it before and after cooking. every season take the grill grates and flare reducers out and clean them well with a wire brush and or steel wool and clean out any residue in side the grill. make sure the grease catcher gets cleaned often as needed. blow out the gas manifolds with air in the spring to remove spider webs or insect webs etc. this should keep your grill working well for 10-15 years. replace the grates or flare plates when needed.also lightly clean the burners when you have the grill taken apart with steel woll then blow them out as well to keep all the openings clear. happy grilling.
May 29, 2010 | Weber Genesis E-320 Propane Grill
Ignitor on gas BBQ no longer works. Replaced battery and cleaned out chamber (light rust). I've tried to remove the ingnition housing, but the entire front panel of the BBQ needs to be removed. Suggestions...
Check to see if the probe where it sparks to the burner inside the grill is clean and not shorted by grease or other gunk and the burner itself in this area is not too heavily rusted or corroded. If not, short of disassembling the whole grill and replacing the spark module, spend $2-3 and buy one of those pistol type grill lighters. The ignition systems on BBQ grills rarely seem to last long.
Feb 24, 2010 | Grilling
Removable grilles for easy cleaning?
We just figured this out ourselves. There are four (4) screws on the back of each fan that when undone it releases the grill for cleaning. But the fun part is getting the screws back in to the little holes. But all in all we got it clean...
Jul 20, 2008 | Honeywell Dual-Action Air Circulator Fan -...
Toastmaster 840 Indoor Grill Logo
81 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oscar Netto
Oscar Netto
Mohamed Ismail
Mohamed Ismail
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
