The drum doesnt appear to be level - Washing Machines
  • 28 Answers
If the unit is a front load: many front load washers have an angled tub towards the back. If however, it has changed from recently; you will want to look at the shocks underneath the unit to see if one is broken.
If the unit is a top load and has the tub off to the side a bit, then a off balence load may be the cause.
Posted on Aug 29, 2010
How can I check the drum life/consumption level of canon c-5185?
Hi, first you need to activate in the service mode the drum life notification
in the copier control panel:
press additional function
press 2 and 8 and the same time
service mode should appear in the screen if doesnt try again
select copier
select option
select body
select the item DLIFE-SW
press 1 in the control panel
press ok in the lower corner
press reset to finish service mode
turn the machine off from the main switch for a few seconds (5 seconds) and then on
once the machine is fully operating go to device status tab and you will see in there the level of toners and drums
May 04, 2016 | Canon Office Equipment & Supplies
6000 Series Rattle & Vibration
Sounds like the drum wheel or wheels need replaced .The twist frame thing just doesnt line up sorry ..LOL
Aug 19, 2013 | Maytag Dryers
What is the grinding noise on my 2003 Grand am front wheels, help please?
There are many things the grinding noise can be. I would start with the breaks though as that sounds like the most likely culprit. If they are grinding, odds are you have ruined your rotors and/or drums. This means that you are looking at about $50-$70 in new parts per wheel (Total of $200 to $280) to replace, assumming only the pads and rotors/drums needs to be replaced.
Please note that breaks can be a good DIY project, but this takes an intermediate skill level with some expereince. Some vehicles are easier than others. Drum style breaks can be especially tricky as they relie on a system of springs that can be challenging to work with. There is also a hydrulic system that can have issues. If you see break fluid when you take off the wheels and drums, you have much larger issues and I would recommend getting in touch with someone more qualified.
Jun 24, 2012 | 2003 Pontiac Grand Am
Maytag washer fills and washes but doesnt rinse or spin.
i would check your water level switch function, it will be located at the end of a 1/4 inch flexible tubing coming from the washer drum, my past experience indicates the replacement of this assembly will restore operation to your unit.`
Apr 16, 2012 | Maytag Washing Machines
Alesis DM6 electronic drum kit module sound problems: The mix in, display and sensors are working on the module but no drum sound is produced through the monitor or through headphones (but an ipod can be...
It appears that you have to select a "Kit" of drums when using the external triggers. It appears that the volume level for the kit and that for each voice MAY all have to be set, especially after new firmware download. Read manual about KIT volume level and selecting voice and volume level for those. Manual is NOT very clear about these things and you have to try them as this is where the probllem is.
May 08, 2011 | Alesis DM6 Electronic Drum Set
I have a 1990 chevy 4x4 automatic when it is going to shift to third it just seems to go to nutral oil doesnt smell burnt and is not low what could cause this
you have a broken overdrive drum inside the transmission, the only way to repair it is to overhaul or replace the transmission....sorry
Feb 15, 2011 | 1987 Chevrolet Blazer
Dryer was moved to install new flooring and upon returning to original location is making very loud noise when drying. Sounds like the drum rumbling. It appears to be level.
The drum could have gotten out of position. Try turning the drum by hand listening for where the noise is coming from and also try repositioning it by pulling and pushing while turning by hand.
Jan 12, 2011 | Maytag Dryers
Yamaha DTXtreme IIS Drum Moduel repair
Listen to the output with headphones to check for noise.
OFTEN the output of a drum machine is CORRUPTED by an inadequate sound system. The waveforms generated by a drum machine tax the sound systems. A bass drum output can drive the speaker cone such that it goes beyond the linear range that the speaker and amplifier can handle and this appears as "noise". The noise may sound like a buzz or totally break up.
Turn the volume down and see if EXACTLY the same noise appears at low levels. If not, then saturation of the amp and speaker is likely. Continued use while it is doing that will often destroy the speaker.
Nov 28, 2009 | Yamaha Music
Hi, when dryer is running it is noisy. It is level, all 4 legs are tight and have rubber feet attached. Noise continues after load is leveled and when only 1 or 2 small items are being dried. Appears to be...
You need to replace the 2 rear drum roller wheels and probably the rear drum felt seal. While you have it torn down inspect the front drum glides for wear.
This dryer is worth repairing.
Aug 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Code cof32
I removed Drum Unit, emptied excess toner, cleaned and installed. After short start-up code cof32 appeared.
Nov 05, 2007 | Minolta Office Equipment & Supplies
Washing Machines Logo
Top Washing Machines Experts
