Question about Drills
I have an almost new Makita HP1640 corded hammer drill. After a couple hours use in Hammer drill mode, I can't slide the lever back to the normal drilling mode. Is there a trick I need to use? Or is it just plain defective? I expected better from Makita.
  • 43,501 Answers
No,
It is defective... return it... they have issues with their stuff too sometimes... but are usually dependable...
heatman101
Posted on Aug 29, 2010
Testimonial: "Thanks. I was afraid of that."
What parts should I have beforehand if my Makita HP1640 has stopped hammering.The hammer switch seems to work and engage but little or no hammer action.
Here is the parts breakdown of your drill. It is hard to say exactly what is the problem, but #10, #13, and #17 have to do with the hammer action. #15 is the hammer switch. It also could be bad. good luck on that. https://www.ereplacementparts.com/makita-hp1640-5834-hammer-drill-parts-c-97_16247_40066.html
Jan 14, 2017 | Makita Drills
My makita hr3851 hammer drill will hammer but when switched over to hammer drill it stays in hammer mode. I have replaced the lever that changes from hammer to hammer drill and it still only hammers
134527-9 http://www.ereplacementparts.com/torque-limiter-assembly-p-54984.html?osCsid=h08big45jse6abdn6tcftrcnt6
How is the healt of this piece is it worn also the other part that will work together with this part must be replaced
Or hows the part connexion 221347-1 spiral bevel gear on the 152335-6 cilinder liner ?? i think its economic not interesting for repair because of the high prices. and the problem of discontinued parts in the prospect
Jun 09, 2015 | Makita HR3851 Electric Rotary Hammer
How to remove the chuck on Makita model HP1640 hammer drill (there isn't any kind of screw inside, only a little hole) help please
Grip a large Allen key in chuck then use a thin spanner wrench on spindle below chuck to loosen.
Dec 09, 2014 | Drills
MAKITA HR3000C HOW DO I REMOVE THE HAMMER/DRILL MODE CHANGE SWITCH
The big control levers off, but the small one only comes off once you have removed the screw and have it in the down position.
Sep 27, 2012 | Makita HR3000C Electric Rotary Hammer
I have a makita drill corded sds and hammer drill, the problem is that it hammers but has stopped rotating
It could be the pin in the lever on the side or a fault in the g/box. You don't say what model it is.
Apr 25, 2012 | Makita Drills
I want to get the chuck off and put a new one on it how do i get it off ?
Hello. Here is the link to the parts breakdown (PDF file centre left) that should provide the reference you need. There is also a PDF for the owners manual if needed. Hope this helps.
Apr 04, 2011 | Makita HP1640 58Inch Hammer Drill
Hammer-drill mode switch wont move to drill position
Try rotating the chuck to a different position, and trying it again. If it catches "between gears", it won't shift.
Best regards, --W/D--
Feb 18, 2011 | Makita HP1640 58Inch Hammer Drill
Makita HP 1640 hammer drill chuck loosens grip on drill while drilling
Sounds like the chuck is worn, happens frequently when used often. Here's the link to Makita, their contact info should get you some answers as to what part number is needed as well as the closest location to you for service if required. Hope this helps.
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=316372
Jan 14, 2011 | Makita HP1640 58Inch Hammer Drill
Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
Oct 10, 2009 | Makita Drills
Drills Logo
314 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
