Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
The flap for the ice dispencer on the freezer side of the door will not stay closed. There seems to be a part missing from the flap. Maybe a spring or something. Can I get this fixed myself for less than 50$ or will it need to be repaired by a professional.?
  • Whirlpool Master
  • 2,180 Answers
You need to send the model number so i can look up your machine to see the part numbers,there's a piston that is used to close the dispencer door,close it and don't use it,if alot of hot air gets sucked inside there it could cause big problems depending on how wide open it is.the model number is on the right side wall up near the ceiling in the fridge side or if it's older it could be down near the bottom hindge on the fridge door.send the model number,i don't know if that part is less than 50 bucks
Posted on Aug 29, 2010
Ice will not dispence thru door.
Without knowing the brand and model # I can offer the most common solution.
On most "pass the ice through the door" models there is a flapper door where the ice dispenses. The spring which holds this door closed when you are not dispensing ice becomes weak allowing the flap to stay open jsut a bit. This open space will create an ice dam in teh dispenser thus not allowing the ice to dispense. The repair is generally made by replacing the flap assembly.
All the best.
Nov 21, 2010 | Refrigerators
Bottom of ice dispencer freezes and wont let ice come out. It is a whirlpool side by side
Check the door flap on the freezer door , which opens to let the ice come thru . If this flap does not close completely , then it will let frost accumulate inside the ice bin , blocking ice from dispensing . If you had given the model number , I would give the part number for the door kit .
Aug 15, 2010 | Refrigerators
Whirpool side by side- opening for through door ice dispenser will not close all the way after dispencing ice. Causing condensation and loss of cool air. Any fix available?
Hi;there is a little plastic valve set up that return the ice flat. Fiddly joba and patients required so you don't brake anything else, that somethings sticks and won't allow flap to fully return. If that doesn't work, tape the flap up and open the freezer door and retrieve ice that way
Jul 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side with ice maker dispenser not working
Hello, we are sorry to hear that you are experiencing this problem. We would suggest checking the ice chute to make sure that there is no ice lodged in the way of the flap. If the issue persist we would suggest having a certified technician out to look at the Refrigerator. If you would like further assistance you can send your name, phone number, address, model/serial of the appliance and the date on which you purchased the Refrigerator to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 17, 2017 | Whirlpool Refrigerators
The ice dispenser door stays open. Selenoid works
This is due to a rusted solenoid plunger .You will need to remove the top freezer door hinge cover ( 1 screw ) , and disconnect the plug there . This will remove power to the dispensor . Using a screwdriver , insert it just behind the dispensor board , and twist , to pry the board off . Remove the 3 plugs there , and remove the board . Remove the 4 screws on the white cover , and slide the cover out and off . In the top right , in the dispensor area , you will see the solenoid and plunger . 3 screws hold the solenoid on . Lift the flap , and the plunger will lift off . Part number for solenoid and plunger is WR62X10055 . The closing spring is probably good , and if you are pushing the flap closed , you are moving the plunger itself , instead of it gliding inside the solenoid , to the closed position .
Nov 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
What is the part called (the little flap that closes after Ice comes throught the dispencer?
it's called an "ice chute door". Look on sears.com, select "Parts Direct", another page will come up, enter your model number of your frig, then enter, wait a few then your model info will pop up, select either the freezer door or if it has "Ice & Water dispencer" select it, wait for another page to come up, then look thru diagram for part you are looking for, then scroll down to that part number and you will be able to see actual mfg part number. There should be a "Ice Chute Repair Kit" listed as that is how they come. Search internet for best price.
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Ice Flap on my LG LSC26905TT will not close after ice dispences
ran into an LG tech today with identical problem and was told to replace a solenoid that closes the door flap.
Mar 04, 2008 | LG LSC26905TT Side by Side Refrigerator
Frost buildup on ice/water dispenser
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Aug 27, 2007 | GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
73 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
